oliver2-44 11,105 #51 Posted May 25, 2020 @Shynon Did you get the seal for the Cessna pump from a OEM Cessna dealer, or just match it up somewhere. I’m looking for a place to get an overhaul kit for the larger Cessna pump on my old Oliver backhoe Share this post Link to post Share on other sites
Shynon 7,517 #52 Posted May 26, 2020 2 hours ago, oliver2-44 said: @Shynon Did you get the seal for the Cessna pump from a OEM Cessna dealer, or just match it up somewhere. I’m looking for a place to get an overhaul kit for the larger Cessna pump on my old Oliver backhoe My local Carquest auto parts store Share this post Link to post Share on other sites
RandyLittrell 3,942 #53 Posted May 26, 2020 On 4/10/2020 at 7:59 PM, Shynon said: Well got some new steel hydraulic lines made, plumb in pump. Filled with oil and finished up the quick attatch. Gotta let the paint dry. Maybd some new loager decals from @Vinylguy. Did you make the steel lines yourself or have them made? I have a johnson 10 loader that I may need to do the same as you have. Thanks! Randy Share this post Link to post Share on other sites
Shynon 7,517 #54 Posted May 26, 2020 @RandyLittrellI had them made by a local ag repair shop, pretty spendy for 4 lines, but I guess hydraulic hose would have been the same. I think it looks better with the steel lines 2 Share this post Link to post Share on other sites
RandyLittrell 3,942 #55 Posted May 26, 2020 20 minutes ago, Shynon said: @RandyLittrellI had them made by a local ag repair shop, pretty spendy for 4 lines, but I guess hydraulic hose would have been the same. I think it looks better with the steel lines I agree! I had to have a hose made and it was pricey, so I wondered if you made your own so you could tell how to do it!! I have a smashed line on my loader now, but it works just fine. Thanks!! Randy Share this post Link to post Share on other sites
Shynon 7,517 #56 Posted May 28, 2020 Quick attatch forks almost done. Need to finish up some welding and paint. Lifts 6.5feet high 1 7 1 Share this post Link to post Share on other sites
Tractorhead 9,215 #57 Posted May 28, 2020 2 hours ago, Shynon said: If not as Lift needed, it can be also misused with a bit wood and a Basket as a backboard.😎👍 2 1 Share this post Link to post Share on other sites
Tractorhead 9,215 #58 Posted May 28, 2020 Looking cool btw.👍 1 Share this post Link to post Share on other sites
Pullstart 68,577 #59 Posted May 28, 2020 Awesome work Tom! 1 Share this post Link to post Share on other sites
