Herder 2,355 #1 Posted January 1, 2020 So in the process of building one of these transmission dollies this old girl showed up and snuck her way into the shop. Well that's not really how it happened. Don't worry it's not mine, a friend picked this up and it's sat for years. Cant turn my nose up at chance to make a buck or two. Boy it is GREEN!! Started with the top end. Removed the head and de-carboned everything, oiled the valves and cylinder. No slack in the piston and one of the cleanest engines I see. The carburetor is tomorrows project. 5 1 Share this post Link to post Share on other sites
Pullstart 68,200 #2 Posted January 1, 2020 So are you getting it functioning for him then? Don’t let that thing try to sneak in the stall with the Horses, A Deere Horse would be a funny color combo! 1 1 Share this post Link to post Share on other sites
ebinmaine 74,588 #3 Posted January 1, 2020 1 hour ago, pullstart said: A Deere Horse would be a funny color combo Mixing red and green together makes the color Brown.... i should NOT have to remind you what else is brown... 1 1 Share this post Link to post Share on other sites
Herder 2,355 #4 Posted January 1, 2020 58 minutes ago, pullstart said: So are you getting it functioning for him then? Don’t let that thing try to sneak in the stall with the Horses, A Deere Horse would be a funny color combo! That's the plan. Get it up and running, go through everything and send it on it's way. She looks pretty comfortable in the shop. I had a 110 with a brigs many years ago. It wasn't built like this one. Share this post Link to post Share on other sites
Pullstart 68,200 #5 Posted January 1, 2020 6 minutes ago, ebinmaine said: Mixing red and green together makes the color Brown.... i should NOT have to remind you what else is brown... Colossus? 2 1 Share this post Link to post Share on other sites
ebinmaine 74,588 #6 Posted January 1, 2020 8 minutes ago, pullstart said: Colossus? Well Yes Nicely done sir 1 Share this post Link to post Share on other sites
JCM 10,313 #7 Posted January 2, 2020 Red Green Orange Brown Blue Tractors in those colors It's all good. Hope I didn't miss any. Oh Pinkish. 1 Share this post Link to post Share on other sites
ebinmaine 74,588 #8 Posted January 2, 2020 19 minutes ago, JCM said: Red Green Orange Brown Blue Tractors in those colors It's all good. Hope I didn't miss any. Oh Pinkish. Yellow & white. Bronze. Light pastel green. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #9 Posted January 2, 2020 The older Deere are a decent GT as well as the Yellow and White & Red IHCC then Blue Ford/Jacobson , Orange Simplicity and Allis Chalmers and the color wheel and brand name could go on, FIL has near mint JD 212 hiding out in the barn like Jim @JCM said it's all good up to the latest plastic and aluminium wanna be tractors they are producing now. 1 Share this post Link to post Share on other sites
Herder 2,355 #10 Posted January 2, 2020 It is well built, heavy duty. I must say the way it steers and the size of the front end components are impressive. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #11 Posted January 2, 2020 55 minutes ago, Herder said: It is well built, heavy duty. I must say the way it steers and the size of the front end components are impressive. Yep and most won't admit it but those Deere the PTO set up as well transaxle drive is very similar to our beloved WH ... now as far as the transaxle itself? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,649 #12 Posted January 2, 2020 Deere never put in a Briggs in a 110, so either it was a 111 or a LA110. All of the 110s had in them were either a 8 hp Kohler or a 10 hp Kohler. The 112 is basically a 110 with a larger engine in it. It originally came with a 10 hp Tecumseh, but later Deere offered them with a Kohler starting in 1969 with the 10 hp Kohler K-241, and then in 1972 all 112s came with a 12 hp K-301 in them. The square fender 110/112 were built from 1968 to 1974. That one has the integral hitch, which is Deere's term for a sleeve hitch. I don't see the manual lift lever, so that one may be an electric lift. I don't think it's an hydraulic lift tractor as I don't see the pump. 1 Share this post Link to post Share on other sites
Herder 2,355 #13 Posted January 3, 2020 On 1/2/2020 at 6:50 AM, WVHillbilly520H said: Yep and most won't admit it but those Deere the PTO set up as well transaxle drive is very similar to our beloved WH ... now as far as the transaxle itself? Could you educate me on the transaxle, I know nothing about them. Type of fluid and amount and what to look for. Would appreciate it. Thanks. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #14 Posted January 3, 2020 37 minutes ago, Herder said: Could you educate me on the transaxle, I know nothing about them. Type of fluid and amount and what to look for. Would appreciate it. Thanks. I honestly have no experience with them other than sitting on them ... Or conversing with other JD owners... @T-Mo most likely can help you out there. 1 Share this post Link to post Share on other sites
Mudrig150 353 #15 Posted January 3, 2020 Peerless 2300, 4 speed with creeper gear, uses 64 oz of SAE EP 80W90 oil. 1 Share this post Link to post Share on other sites
Mudrig150 353 #16 Posted January 3, 2020 On 1/2/2020 at 7:12 AM, T-Mo said: Deere never put in a Briggs in a 110, so either it was a 111 or a LA110. All of the 110s had in them were either a 8 hp Kohler or a 10 hp Kohler. The 112 is basically a 110 with a larger engine in it. It originally came with a 10 hp Tecumseh, but later Deere offered them with a Kohler starting in 1969 with the 10 hp Kohler K-241, and then in 1972 all 112s came with a 12 hp K-301 in them. The square fender 110/112 were built from 1968 to 1974. That one has the integral hitch, which is Deere's term for a sleeve hitch. I don't see the manual lift lever, so that one may be an electric lift. I don't think it's an hydraulic lift tractor as I don't see the pump. It is. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #17 Posted January 3, 2020 What I do know is Cub Cadet also used a Peerless 4spd forward transaxle in their lower priced entry level models (482 and 582 Special) that were also Briggs powered... Those Peerless weren't as dependable as the original Cub transaxles... But JD spec may have been heavier duty/built. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,649 #18 Posted January 3, 2020 Some have used 120/140 gear oil if the transmission was a bit whiny - the heavier gear oil seems to help quieten them down some. Share this post Link to post Share on other sites
Herder 2,355 #19 Posted January 3, 2020 5 hours ago, Mudrig150 said: Peerless 2300, 4 speed with creeper gear, uses 64 oz of SAE EP 80W90 oil. Thank you. Could you tell me is there another safety switch besides the neutral safety switch. Currently I know that one is not working and I am not get power to signal wire going to the starter relay switch. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,649 #20 Posted January 4, 2020 There should be a pto safety switch also. Here is a diagram from the service manual that might help: late sf electrical.tiff Share this post Link to post Share on other sites
Herder 2,355 #21 Posted January 4, 2020 5 hours ago, T-Mo said: There should be a pto safety switch also. Here is a diagram from the service manual that might help: late sf electrical.tiffUnavailable Thank you T. Dam Deere's owner dropped off the service manual for it today. It's what I needed for sure. A lot of the electrical components are in poor condition form sitting outside. I found that the rectifier has a burnt connection and was thinking that could be contributing to the problem. The electrical is a pain to get too. Everything is under the fuel tank and battery tray or hidden behind a shield. I will NOT be buying a Deere anytime soon!!! They are not built like a Wheel Horse. 2 Share this post Link to post Share on other sites
wildman 205 #22 Posted January 4, 2020 3 hours ago, Herder said: The electrical is a pain to get too. Everything is under the fuel tank and battery tray or hidden behind a shield. I will NOT be buying a Deere anytime soon!!! They are not built like a Wheel Horse. This is why i sold my Deeres and went with wheel Horse 1 Share this post Link to post Share on other sites
