71_Bronco 1,072 #126 Posted June 23, 2020 9 hours ago, ebinmaine said: Got that all put back on along with the fuel line from pump to carb. What are you using for fuel line? Is that the blue-colored tubing from Tractor Supply? Or the Stens True-Blue fuel tubing? Thanks Share this post Link to post Share on other sites
ebinmaine 80,170 #127 Posted June 23, 2020 (edited) On 6/23/2020 at 6:54 AM, 71_Bronco said: Stens True-Blue I bought this particular roll from Lincoln at A to Z tractor but I'm sure there's multiple places where you can get it. We don't use ethanol in any of our machines but I've repaired a tractor or two for people that still do. This stuff is more ethanol resistant than rubber. Also, I like the fact that I can see through it for diagnostic reasons. Or, if I'm just being a dingbat and did not put fuel in the tractor. Not that that has ever happened before. Edited June 28, 2020 by ebinmaine Correct autocorrect 2 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #128 Posted July 4, 2020 Electrical finished. Battery installed. 4 Share this post Link to post Share on other sites
ebinmaine 80,170 #129 Posted July 5, 2020 IT'S ALIVE !!!!! 8 2 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #130 Posted July 8, 2020 One of the interesting points about this tractor is that there were areas like the throttle linkage and carburetor which were rusted tight. But there are areas like the rear hitch pin that are completely free and moving. Odd. ..... Well tonight I popped the rear hitch out and dumped the transmission fluid. So clean it was kind of a waste but I'd rather have the new stuff in there. Filter is/was a VERY aged AC Delco PF20. 2 Share this post Link to post Share on other sites
Stepney 2,356 #131 Posted July 9, 2020 Funny thing about hydros. Always seems the hitch is loose, as I've said before. They always seem to weep just a bit .. guess it's a perk in the long run. Seen way more bad hubs on hydros too ... buuut, the hubs are never rusted on either, now are they? 4 Share this post Link to post Share on other sites
ebinmaine 80,170 #132 Posted July 9, 2020 (edited) On 7/8/2020 at 9:58 PM, Stepney said: bad hubs Yeah these are.....ummmm..... A little loose. I'm hoping to slow down the wear process a little bit by using hubs with two set screws. Edited July 25, 2020 by ebinmaine Share this post Link to post Share on other sites
ebinmaine 80,170 #133 Posted July 12, 2020 Been fiddling with the transmission pulley. It was so crusty the belt was riding way too high and was faaaar worse on one side. I took a cold chisel and knocked down the majority of the rust. Then some 40 grit sandpaper and smoothed it a bit more. Sits nicely now. 5 Share this post Link to post Share on other sites
ebinmaine 80,170 #134 Posted July 13, 2020 Last night I cut a hole in the fuel tank shelf so I could install a metal tank. Got that bolted in. 3 Share this post Link to post Share on other sites
ebinmaine 80,170 #135 Posted July 25, 2020 IT MOVES ON ITS OWN!!! 4 3 Share this post Link to post Share on other sites
pfrederi 21,008 #136 Posted July 26, 2020 Get her some serious weights and chains on narrow tires and you will be amazed how much and how fast she will move snow. 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #137 Posted July 26, 2020 2 minutes ago, pfrederi said: Get her some serious weights and chains on narrow tires and you will be amazed how much and how fast she will move snow. Which reminds me... What do you use for front tires? Share this post Link to post Share on other sites
pfrederi 21,008 #138 Posted July 26, 2020 Just now, ebinmaine said: Which reminds me... What do you use for front tires? Just what you have on there now with roller chain. Also some front weight. 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #139 Posted July 26, 2020 Got the fender pan and it's bracket off the tractor. Drained the transmission. Put the frame and transmission on blocks and removed the rear wheels/tires. Here's a couple pics: Note the hole through the axle. And the taper to the same axle. Wow... The Rh side hub and axle are gouged out something awful. All good. Part of the knowledge I had at purchase. I should have hubs and axles here in the parts department. 2 Share this post Link to post Share on other sites
ebinmaine 80,170 #140 Posted August 2, 2020 @Stepney came by for a visit today. One of the things he gave me a hand with was to get the transmission removed and split. Inside of it looks great other than the parking pawl being badly bent. Need to order some gaskets and a limited slip spring from @wheelhorseman Lowell and get it back together. 5 Share this post Link to post Share on other sites
Pullstart 71,029 #141 Posted August 2, 2020 Good stuff EB! Do you plan on a saddle of some sort, or riding bareback? 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #142 Posted August 2, 2020 1 hour ago, pullstart said: Good stuff EB! Do you plan on a saddle of some sort, or riding bareback? There will be a saddle. Not sure which one yet. I've got a couple in the shed. 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #143 Posted August 4, 2020 Suggestions on freeing up a sticky throttle cable? I put it in ATF for the night. Also ordered a couple choke cables for this and the Raider. Share this post Link to post Share on other sites
Ed Kennell 46,855 #144 Posted August 4, 2020 2 hours ago, ebinmaine said: Suggestions on freeing up a sticky throttle cable? I have saved several by cutting the bends off at the carb end, then work the wire out of the sheath and soak it in ATF. Polish the wire, reinstall and rebend the carb end. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #145 Posted August 28, 2020 On 8/4/2020 at 10:40 AM, Ed Kennell said: I have saved several by cutting the bends off at the carb end, then work the wire out of the sheath and soak it in ATF. Polish the wire, reinstall and rebend the carb end. Ed, thanks for that suggestion. Worked like a charm soaking it in ATF. 1 Share this post Link to post Share on other sites
ebinmaine 80,170 #146 Posted August 28, 2020 Hoping to get a little workshop time this coming weekend. Supposed to rain all day Saturday. I've got most of the parts I need for the transmission. Got this from our friends Lowell and Joette. 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #147 Posted August 28, 2020 1 hour ago, ebinmaine said: Hoping to get a little workshop time this coming weekend. Supposed to rain all day Saturday. I've got most of the parts I need for the transmission. Got this from our friends Lowell and Joette. I've got one of those in my 5060 transmission that I swapped into my Commando. Looks good so far, though that steel pan doesnt look very comfy 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #148 Posted August 29, 2020 Eric I would check with LJ fluid power up in Michigan for all the O-rings and seals that she will need. Cost me around 45 bucks and well worth it! I have a donor trans sitting here if you need anything off at let me know. Looking forward to the day to have mine moving which now is hopefully towards fall. 1 Share this post Link to post Share on other sites
Pullstart 71,029 #149 Posted August 31, 2020 On 8/29/2020 at 3:55 PM, The Tuul Crib said: Eric I would check with LJ fluid power up in Michigan for all the O-rings and seals that she will need. Cost me around 45 bucks and well worth it! I have a donor trans sitting here if you need anything off at let me know. Looking forward to the day to have mine moving which now is hopefully towards fall. Do you have a parts list from them Randy? Share this post Link to post Share on other sites
Pullstart 71,029 #150 Posted August 31, 2020 On 8/28/2020 at 1:52 PM, ebinmaine said: Hoping to get a little workshop time this coming weekend. Supposed to rain all day Saturday. I've got most of the parts I need for the transmission. Got this from our friends Lowell and Joette. That LSD ring looks heavier than the one in @stevasaurus’ video. Is it my imagination or did they make it heavier? Share this post Link to post Share on other sites
