Sean 6 #1 Posted December 14, 2019 I am thinking about putting a large marine Saab Diesel engine into my wheel horse 314-8. Will the frame be able to handle around 450 pounds of engine? I am asking as I have never seen it done due to the scarcity of the engine. 2 Share this post Link to post Share on other sites
Razorback 1,220 #2 Posted December 14, 2019 7 minutes ago, Sean said: I am thinking about putting a large marine Saab Diesel engine into my wheel horse 314-8. Will the frame be able to handle around 450 pounds of engine? I am asking as I have never seen it done due to the scarcity of the engine. Hmmmmmm..... this will be interesting. I like the idea, and I will be interested to hear from others about how the WH would handle the weight. How much does a front loader weigh??? I LOVE the idea of a WH smelling like DIESEL!!!!! Share this post Link to post Share on other sites
Razorback 1,220 #3 Posted December 14, 2019 And..... If that doesn't work out....... let me put it in my Speedex 1631!!!! 1 1 1 Share this post Link to post Share on other sites
Sean 6 #4 Posted December 14, 2019 (edited) It’s a big motor the flywheel alone weighs 200 and it’s running 83 foot pounds of torque Edited December 14, 2019 by Sean Share this post Link to post Share on other sites
Sean 6 #5 Posted December 14, 2019 Which is why I’m asking it would be tons of fun to mess around with Share this post Link to post Share on other sites
Razorback 1,220 #6 Posted December 14, 2019 (edited) Wow!!! How are you going to fit that in the WH???? Even IF the frame can handle it?? I am curious of how the hood will be modified to cover it?? Edited December 14, 2019 by Razorback Share this post Link to post Share on other sites
Sean 6 #7 Posted December 14, 2019 If the frame can handle it the motor would sit up off the frame rather than down in Share this post Link to post Share on other sites
Sean 6 #8 Posted December 14, 2019 (edited) And the hood might fit if I raise it up about 8 inches Edited December 14, 2019 by Sean Share this post Link to post Share on other sites
ebinmaine 77,082 #9 Posted December 14, 2019 @Sean I think it'd hold it if the 'horse frame and front pivot are in good condition. The pivot can easily be weld reinforced with a collar and longer pin too. As stated above... Think FEL.... But remember an FEL keeps more weight towards the rear by mounting more to thread of the tractor. This would be a super cool project to watch!! Share this post Link to post Share on other sites
pfrederi 19,796 #10 Posted December 14, 2019 You better hit the gym and start working on your arms you are going to need them to steer that thing. 1 Share this post Link to post Share on other sites
ZXT 2,401 #11 Posted December 14, 2019 to ! @19richie66 is doing a Yanmar 2 cyl diesel swap on a GT-14, and he is beefing the frame up to handle the added weight. I'm not sure what his weighs, but I would assume it is lighter than yours. Probably wouldn't be a bad idea to beef it up some.. Seems like a lot of weight for 80 ft.lb of torque! If I were going to install something that heavy, it would probably be an aluminum 5.3 LS.. It would have 300+ ft.lb! 1 3 Share this post Link to post Share on other sites
SALTYWRIGHT 861 #12 Posted December 14, 2019 have2 men stand on the front of your tractor and see if you can steer it. I put a diesel in my 417-8 and 1054 that were very light. that saab diesel is too heavy. russ 1 Share this post Link to post Share on other sites
19richie66 17,793 #13 Posted December 14, 2019 (edited) If you built it like a Senior frame, probably. Regular wheelhorse frame, I doubt it. Be a cool project anyways. My engine is 187lbs. Not much more than a cast iron K341 Edited December 14, 2019 by 19richie66 Share this post Link to post Share on other sites
SylvanLakeWH 30,485 #14 Posted December 14, 2019 (edited) Of course it can be done! Just need frame and steering enhancements to address added weight... @SALTYWRIGHT had the right idea regarding steering...add 450 lbs to front and see what happens with steering... Edited December 14, 2019 by SylvanLakeWH Share this post Link to post Share on other sites
bc.gold 3,406 #15 Posted December 14, 2019 16 hours ago, Sean said: It’s a big motor the flywheel alone weighs 200 and it’s running 83 foot pounds of torque Fresh or salt water, open or closed circuit cooling system/ Share this post Link to post Share on other sites
Sean 6 #16 Posted December 14, 2019 (edited) Air cooled so water tank or radiator isn’t necessary for it Edited December 14, 2019 by Sean 1 Share this post Link to post Share on other sites
bc.gold 3,406 #17 Posted December 19, 2019 (edited) On 12/13/2019 at 9:23 PM, Sean said: I am thinking about putting a large marine Saab Diesel engine into my wheel horse 314-8. Will the frame be able to handle around 450 pounds of engine? I am asking as I have never seen it done due to the scarcity of the engine. When the Internet came to be we had to redefine scarcity. Is your engine clockwise or counter clockwise rotation. Edited December 19, 2019 by bcgold Share this post Link to post Share on other sites
Cvans 1,009 #18 Posted December 22, 2019 (edited) Having installed a Lister-Petter LT1A in several WH tractors without any frame reinforcement I'd say your going to be fine. The LT1A is a heavy single cylinder air cooled and with the electric starter should be right in the 200 lb range. The last install was in a 12hp Charger Auto. Ran this combination for a number of years and am now in the middle of installing it in a C-160 8spd. Here is a photo of it in the Charger along with a photo of the engine. Edited December 22, 2019 by Cvans 1 2 1 Share this post Link to post Share on other sites
Sean 6 #19 Posted December 22, 2019 That’s pretty awesome what kind of torque is that old lister running? Share this post Link to post Share on other sites
Cvans 1,009 #20 Posted December 22, 2019 The first WH I had it in was a ranger 10hp 8 spd. if I remember correctly. You couldn't stop it. In high range second gear it would dig a hole. It literally gutted the transmission. Then after installing it in a hydro it wouldn't do that but the hydro did an excellent job of absorbing the power impulses and the hydraulic lift was wonderful for raising implements. The problem came when it was cold outside the thick oil (ATF) sucked up a lot of power. I use this for yard and garden work and the manual transmission is a better combination so that's where I'm headed again. This time hopefully with a heavier gearbox and a little more common sense as to what I hook it up to. Share this post Link to post Share on other sites
bc.gold 3,406 #21 Posted December 22, 2019 (edited) Awesome engines I have a Petter PJ2 and a SR2 Edited December 22, 2019 by bcgold Share this post Link to post Share on other sites
ebinmaine 77,082 #22 Posted December 22, 2019 6 hours ago, Cvans said: what I hook it up to Oh ... I hope there is a build thread coming up... 2 Share this post Link to post Share on other sites
Cvans 1,009 #23 Posted December 22, 2019 I'll try but I get into what I'm doing and completely forget about photos. Right now I'm waiting on seals and gaskets for it. I'll start another thread so I don't hijack this one. Sean have you made anymore progress with your Saab? 1 Share this post Link to post Share on other sites
Sean 6 #24 Posted December 22, 2019 I am working on re timing it as one of the valves was opening at the wrong time. Once that is done the reinforcement of the frame will be started and then it’s down to mounting on the frame. 2 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #25 Posted December 22, 2019 On 12/14/2019 at 7:53 PM, SylvanLakeWH said: Of course it can be done! Just need frame and steering enhancements to address added weight... @SALTYWRIGHT had the right idea regarding steering...add 450 lbs to front and see what happens with steering... Maybe not that much, if you work with a similar counterweight. but the main question in my opinion was, if the Rearaxle can last that added Load. found @pfrederi‚s idea funny with the Gym.. 😂 maybe a rework of the Frontaxle with flat Ballbearings can reduce the steering force. or a Servo will implemented 🤔 To improve the stability of the frame itself, a flat steel can be welded sideway‘s left and right along the original Frame and redrilled with needed holes after that. 😎 should improve the stability massive. Share this post Link to post Share on other sites
