AHS 1,701 #1 Posted December 6, 2019 Duh! I need a Wheelhorse; one for snowblower, one for plow, one for lawnmower, and one for grader... I wish! I need to switch the plow to my kinda refurbished snowblower. New paint in the blower box, new paint on the chute, all new bearings, new blower sprocket, 2 new idler idler gears, a new chain. Auger is not painted ( that will happen this July!) too late in the season, snow can come at any moment now! Oh does anyone have a chain guard in the front they wanna sell me? 6 Share this post Link to post Share on other sites
ebinmaine 80,967 #2 Posted December 6, 2019 I've said many times. Jokingly but serious also. I can totally justify one tractor for every implement. 11 1 Share this post Link to post Share on other sites
AHS 1,701 #3 Posted December 6, 2019 50 minutes ago, ebinmaine said: I've said many times. Jokingly but serious also. I can totally justify one tractor for every implement. I’m getting tired of changing attachments! 1 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #4 Posted December 6, 2019 Like this... 2 Share this post Link to post Share on other sites
peter lena 10,091 #5 Posted December 6, 2019 AHS, nice work on the blower refit, i use LUBRIPLATE CHAIN AND CABLE SPRAY LUBE ON MY BLOWER WITH great results, i spray it down before and after use, ensuring its never lacking for lubrication. also fitted a SERATED WASHER on the side chain adjustnent point , ensuring no adjustment creep , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,967 #6 Posted December 6, 2019 21 minutes ago, AHS said: I’m getting tired of changing attachments! Boy wouldn't it be handy if you knew where there was a pile of Wheelhorse parts. It would be really nice if you knew where there was some c-series stuff that you could have so you could build your very own c160... like if you were to trip over a 16 horse somewhere. Like down at my house... 2 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #7 Posted December 6, 2019 1 minute ago, ebinmaine said: Boy wouldn't it be handy if you knew where there was a pile of Wheelhorse parts. It would be really nice if you knew where there was some c-series stuff that you could have so you could build your very own c160... like if you were to trip over a 16 horse somewhere. Like down at my house... Got a 312-8 down here with extra frames and hood... ... 1 Share this post Link to post Share on other sites
AHS 1,701 #8 Posted December 6, 2019 15 minutes ago, ebinmaine said: Boy wouldn't it be handy if you knew where there was a pile of Wheelhorse parts. It would be really nice if you knew where there was some c-series stuff that you could have so you could build your very own c160... like if you were to trip over a 16 horse somewhere. Like down at my house... I know!! Its just getting down there! 1 Share this post Link to post Share on other sites
AHS 1,701 #9 Posted December 6, 2019 24 minutes ago, peter lena said: AHS, nice work on the blower refit, i use LUBRIPLATE CHAIN AND CABLE SPRAY LUBE ON MY BLOWER WITH great results, i spray it down before and after use, ensuring its never lacking for lubrication. also fitted a SERATED WASHER on the side chain adjustnent point , ensuring no adjustment creep , pete Show me the serrated washer... I’m entrigued.. @peter lena Share this post Link to post Share on other sites
ebinmaine 80,967 #10 Posted December 6, 2019 4 minutes ago, AHS said: I know!! Its just getting down there! If the old saying Time Is Money Were true, I'd be broke. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #11 Posted December 6, 2019 2 hours ago, AHS said: Show me the serrated washer... I’m entrigued.. @peter lena Many different styles... Share this post Link to post Share on other sites
AHS 1,701 #12 Posted December 6, 2019 Plow off, snowblower on, and it works! New seat on and old seat linkage on, instead of that new garbage that they call seat linkage! The seat was moved to far forwards and the seat bolts were odd, ( not 7” x7 1/2) and the key switch for not mowing backwards, I connected those wires together a long time ago!👍😄 I’m ready to go snow blowing! 1 Share this post Link to post Share on other sites
AHS 1,701 #13 Posted December 6, 2019 Ok the serrated washer must be for the bottom idler gear! Duh! Ok!😄 Share this post Link to post Share on other sites
roadapples 6,987 #14 Posted December 6, 2019 Your side wings are backwards... 3 Share this post Link to post Share on other sites
peter lena 10,091 #15 Posted December 6, 2019 AHS , as hillbilly above showed the serated washer , https://www.google.com/search?sxsrf=ACYBGNQGyWfRJiE69Q8IId4C3k0_nV8kiw:1575660673640&q=serrated+washer+fastenal&tbm=isch&source=univ&sa=X&ved=2ahUKEwiegfS14aHmAhUnVt8KHTyFDA4QsAR6BAgHEAE&biw=1024&bih=625 is meant to hold solid a sliding mount point . the bottom foward idler gear is also the sliding chain adjustment point , those serated teeth will lock into the related metal work and hod your adjustment . i also see that you have the same seat that i have 3 of for my horses. i am using those two empty bolt holes on mine to make up a bracket for led light flash mount for nighttime plowing. pete Share this post Link to post Share on other sites
AHS 1,701 #16 Posted December 6, 2019 33 minutes ago, roadapples said: Your side wings are backwards... Oops! I was in a hurry! I will switch them!😁 Share this post Link to post Share on other sites
AHS 1,701 #17 Posted December 7, 2019 4 hours ago, peter lena said: AHS , as hillbilly above showed the serated washer , https://www.google.com/search?sxsrf=ACYBGNQGyWfRJiE69Q8IId4C3k0_nV8kiw:1575660673640&q=serrated+washer+fastenal&tbm=isch&source=univ&sa=X&ved=2ahUKEwiegfS14aHmAhUnVt8KHTyFDA4QsAR6BAgHEAE&biw=1024&bih=625 is meant to hold solid a sliding mount point . the bottom foward idler gear is also the sliding chain adjustment point , those serated teeth will lock into the related metal work and hod your adjustment . i also see that you have the same seat that i have 3 of for my horses. i am using those two empty bolt holes on mine to make up a bracket for led light flash mount for nighttime plowing. pete That seat is comfortable! The 3 seconds I got to sit it! I can see the use for the serrated washers...I made the chain to tight and then loosening it is a nightmare...it’s either too loose or too tight! Until Arthur got on there! 1 2 Share this post Link to post Share on other sites
WildmanC120 615 #18 Posted December 7, 2019 Where did you get the 2 idlers for the single stage and did they come with bearings??? I could use some as mine are wicked shot. Share this post Link to post Share on other sites
Darb1964 1,174 #19 Posted December 7, 2019 Think about changing the wear blade on your plow, I heard that somewhere? Share this post Link to post Share on other sites
AHS 1,701 #20 Posted December 7, 2019 9 hours ago, WildmanC120 said: Where did you get the 2 idlers for the single stage and did they come with bearings??? I could use some as mine are wicked shot. At the old wh dealer, they are $37.00 a piece. It comes as one complete package the idler wheel with the bearing @WildmanC120 Share this post Link to post Share on other sites
AHS 1,701 #21 Posted December 7, 2019 10 hours ago, WildmanC120 said: Where did you get the 2 idlers for the single stage and did they come with bearings??? I could use some as mine are wicked shot. I can get them for you, if there’s not an old WH dealer in your area. I’ll just mail them to you. Share this post Link to post Share on other sites
lynnmor 9,051 #22 Posted December 7, 2019 Check this out for original sprockets. 1 2 Share this post Link to post Share on other sites
peter lena 10,091 #23 Posted December 7, 2019 LYNNMOR ,excellent choice for sprockets , great price too! i was just about to say T/S for sprockets ,as i see them there all the time, DARB1964 , you can pick up that size flat steel stock at lowes or H/D , I MADE UP A NUMBER OF THEM YEARS AGO , when i was working . easy swap , pete 2 Share this post Link to post Share on other sites
Darb1964 1,174 #24 Posted December 7, 2019 Peter Lena thanks mine is getting to the point of replacement. The steel companies around me don't sell small pieces any more. 1 Share this post Link to post Share on other sites
ebinmaine 80,967 #25 Posted December 7, 2019 22 minutes ago, Darb1964 said: Peter Lena thanks mine is getting to the point of replacement. The steel companies around me don't sell small pieces any more. The steel companies around me don't sell small pieces either but we have several fabricators of custom trucks phone repair shops that will... HD and Lowe's in my area don't sell a piece big enough for a 48 inch plow blade at the brick and mortar store although you may be able to order it online and have it shipped to store. Share this post Link to post Share on other sites
