Lagersolut 793 #101 Posted December 17, 2019 (edited) 44 minutes ago, AHS said: @Lagersolut I like the C-101. My Dad still has one.. hold on.. there’s me on it in ‘85!💪👍😄 The C-101 in my picture was my fathers . He used it mowing 2 acres until I built my place in '94 , that same year he bought a simplicity told me I could have it if not he was selling it . Long story short I used it until it was springing leaks and smoking the wife wanted me to junk it ...wasn't having any of that ....bought the 2005 315-8 classic GT and fully restored the C-101 . ....fast forward to 2019 the herd is up 2 more with a 310-8 and a 416-8 ....and soon to be introduced a freebie a guy was having trouble with ran out and bought a green one ......lol Edited December 17, 2019 by Lagersolut 3 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #102 Posted December 17, 2019 Got the plow back on Cinnamon after Trina painted the face of it the other day. This plow has weak springs so I pulled a couple extra off the pile and made up some longer pins. Then mounted the bracket and plow to Trina's 867. I installed the bolens weights on her tractor as well. We now have 2 plow tractors!! 7 4 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #103 Posted December 17, 2019 1 minute ago, ebinmaine said: Then mounted the bracket and plow to Trina's 867. I spy something laying on the bubble wrap... Wonder where they ended up ... 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #104 Posted December 17, 2019 @WVHillbilly520H those awesome brackets will be on the Cinnamon Horse at some point. I didn't get a pic of it but I had to make up a short link extension to put on the 867. Being a short frame there's 2 positions you can put the long frame plow. Trina liked the position of the plow controls with the frame in the most forward mount holes. The existing center link was bent at the right angle but was about 1" too short. I used a short piece of flat stock and drilled 2 holes. Bolted it to the plow frame and pinned it to the tractor link. 1 Share this post Link to post Share on other sites
MikMacMike 494 #105 Posted December 17, 2019 28 minutes ago, ebinmaine said: Got the plow back on Cinnamon after Trina painted the face of it the other day. This plow has weak springs so I pulled a couple extra off the pile and made up some longer pins. Then mounted the bracket and plow to Trina's 867. I installed the bolens weights on her tractor as well. We now have 2 plow tractors!! Ahhh now I understand what you meant by second spring. Looks like thats the way it came from the factory too ebinmaine. Are those springs hard to stretch? Share this post Link to post Share on other sites
ebinmaine 77,322 #106 Posted December 17, 2019 7 hours ago, MikMacMike said: Ahhh now I understand what you meant by second spring. Looks like thats the way it came from the factory too ebinmaine. Are those springs hard to stretch? Normally yes. Not mine. That's why I added 2.... Keeps the plow from tripping forward as easily. 1 Share this post Link to post Share on other sites
AHS 1,594 #107 Posted December 17, 2019 @ebinmaine what is that? Lying in the bubble wrap? Share this post Link to post Share on other sites
ebinmaine 77,322 #108 Posted December 17, 2019 1 minute ago, AHS said: @ebinmaine what is that? Lying in the bubble wrap? Those are spacers that go between the bottom of the axle and the snow plow bracket to lower the rear of the plow frame thereby raising the front of the plow frame. They'll give me a little extra clearance at the front of the blade while driving around and make it easier to navigate my rough terrain. 3 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,623 #109 Posted December 17, 2019 10 hours ago, ebinmaine said: Is that how you run your plow? With the plow blade leaning forward? Just curious as i have messed around with mine and have settled on the next holes "up" for the springs to mount in. Wonder if having it lean that far forward made the springs less effective 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #110 Posted December 17, 2019 11 minutes ago, Sparky said: Is that how you run your plow? With the plow blade leaning forward? Just curious as i have messed around with mine and have settled on the next holes "up" for the springs to mount in. Wonder if having it lean that far forward made the springs less effective I run mine in the third hold down so that I keep most of the plow in a more forward lean. It's tough to see but the bottom two or three in still has a back tilt to it. I've found that if I put it in the second hole it digs into my dirt driveway too much. Plows snow great but also plows more dirt. 2 Share this post Link to post Share on other sites
ebinmaine 77,322 #111 Posted December 17, 2019 12 minutes ago, Sparky said: Wonder if having it lean that far forward made the springs less effective To some extent, yes that's definitely true. but the two springs that were on their were both twisted and bent. I didn't have another new good set so I doubled up instead. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #112 Posted December 17, 2019 3 hours ago, ebinmaine said: I didn't have another new good set so I doubled up instead. I'm about to double spring the 56" I just bought to put on the 520. 1 Share this post Link to post Share on other sites
ebinmaine 77,322 #113 Posted December 17, 2019 21 minutes ago, WVHillbilly520H said: I'm about to double spring the 56" I just bought to put on the 520. I'll be super curious to know what your impressions are after you have plowed with that... I'll be able to let you know what I think of the cinnamon plow tonight or tomorrow Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #114 Posted December 17, 2019 2 hours ago, ebinmaine said: I'll be super curious to know what your impressions are after you have plowed with that... The way things look that won't happen till February... 3 Share this post Link to post Share on other sites
ebinmaine 77,322 #115 Posted December 18, 2019 So my wonderful little honey has been chomping at the bit to use the snow plow on her horse. Chomping at the bit. Horse. See what I did there? I made a horse joke and I didn't even mean to. Well yesterday we got a little less than 2" of snow so off she goes! Took her a little bit of getting used to because the plow is in the front not on the belly like the grader blade. Like pretty much anything after just a few minutes she had it figured out.. She got up on the incoming part of the driveway which has a slight Hill to it and was pushing the snow down to the flat to me. I was then pushing it off in front of the house with the rest of what I was clearing. When the upper driveway was done she went down in the backyard and was even able to clear snow in front of and beside the shed. This past summer we had done some changing of the contour out there to enable us to use a plow and it seems to be working quite well. This all happened after dark and both of us were busy so there's no pictures yet. Next time I get home before dark I'll try to throw together a short video. Trina had an absolute blast. She told me at least three or four times how much fun it was. I may have created a monster and you all are partially to blame. 4 4 1 1 2 Share this post Link to post Share on other sites
MikMacMike 494 #116 Posted December 18, 2019 2 hours ago, ebinmaine said: So my wonderful little honey has been chomping at the bit to use the snow plow on her horse. Chomping at the bit. Horse. See what I did there? I made a horse joke and I didn't even mean to. Well yesterday we got a little less than 2" of snow so off she goes! Took her a little bit of getting used to because the plow is in the front not on the belly like the grader blade. Like pretty much anything after just a few minutes she had it figured out.. She got up on the incoming part of the driveway which has a slight Hill to it and was pushing the snow down to the flat to me. I was then pushing it off in front of the house with the rest of what I was clearing. When the upper driveway was done she went down in the backyard and was even able to clear snow in front of and beside the shed. This past summer we had done some changing of the contour out there to enable us to use a plow and it seems to be working quite well. This all happened after dark and both of us were busy so there's no pictures yet. Next time I get home before dark I'll try to throw together a short video. Trina had an absolute blast. She told me at least three or four times how much fun it was. I may have created a monster and you all are partially to blame. Awwwwww Life is so much more when your partner n best friend is right there with you. All this time shes watched you turn work into fun and now she gets to enjoy it right with ya. THATS what life is all about my friend. Mike 1 2 Share this post Link to post Share on other sites
Pullstart 68,871 #117 Posted December 18, 2019 23 minutes ago, MikMacMike said: Awwwwww Life is so much more when your partner n best friend is right there with you. All this time shes watched you turn work into fun and now she gets to enjoy it right with ya. THATS what life is all about my friend. Mike You stick around long enough, you’ll realize that Trina (she has a black belt, so I call her BBT) seems to get her hands on more work than EB when it comes to tractors... maybe any work! She’s a tough cookie. 3 Share this post Link to post Share on other sites
ebinmaine 77,322 #118 Posted December 18, 2019 8 minutes ago, pullstart said: You stick around long enough, you’ll realize that Trina (she has a black belt, so I call her BBT) seems to get her hands on more work than EB when it comes to tractors... maybe any work! She’s a tough cookie. ABSOLUTELY TRUE Share this post Link to post Share on other sites
Lee1977 7,551 #119 Posted December 18, 2019 2 hours ago, ebinmaine said: So my wonderful little honey has been chomping at the bit to use the snow plow on her horse. Chomping at the bit. Horse. See what I did there? I made a horse joke and I didn't even mean to. Well yesterday we got a little less than 2" of snow so off she goes! Took her a little bit of getting used to because the plow is in the front not on the belly like the grader blade. Like pretty much anything after just a few minutes she had it figured out.. She got up on the incoming part of the driveway which has a slight Hill to it and was pushing the snow down to the flat to me. I was then pushing it off in front of the house with the rest of what I was clearing. When the upper driveway was done she went down in the backyard and was even able to clear snow in front of and beside the shed. This past summer we had done some changing of the contour out there to enable us to use a plow and it seems to be working quite well. This all happened after dark and both of us were busy so there's no pictures yet. Next time I get home before dark I'll try to throw together a short video. Trina had an absolute blast. She told me at least three or four times how much fun it was. I may have created a monster and you all are partially to blame. Two inches she could have moved that with the grader blade. A few years back I move about 4" with my grader blade. I normally just let it melt only take a day or two here. [/uril} 3 Share this post Link to post Share on other sites
ebinmaine 77,322 #120 Posted December 18, 2019 9 minutes ago, Lee1977 said: Two inches she could have moved that with the grader blade. A few years back I move about 4" with my grader blade. I normally just let it melt only take a day or two here. Definitely. We had about four inches of wet snow a week or so ago and she was able to move that with the grader just fine except for not being able to steer. Old smooth sawtooth style front tires were pretty much only good for going straight forward. She wants to be able to use it a lot more often and on bigger storms so the mid-mount blade had to go. We have to scrape EVERY storm unless we know for sure it's going to be very warm the next 2 days after. Otherwise, dirt drive turns to ice. 2 Share this post Link to post Share on other sites
Al C. 1,429 #121 Posted December 18, 2019 (edited) My wife wants me to show her how to use the plow ... says it looks like fun. I keep telling her it is very very complicated !Not sure how long that will work. Edited December 18, 2019 by Al C. 2 6 Share this post Link to post Share on other sites
Lee1977 7,551 #122 Posted December 18, 2019 2 minutes ago, ebinmaine said: Definitely. We had about four inches of wet snow a week or so ago and she was able to move that with the grader just fine except for not being able to steer. Old smooth sawtooth style front tires were pretty much only good for going straight forward. She wants to be able to use it a lot more often and on bigger storms so the mid-mount blade had to go. We have to scrape EVERY storm unless we know for sure it's going to be very warm the next 2 days after. Otherwise, dirt drive turns to ice. Don't remember have steering problems. The big Kohler planted the front. I was pushing it up in a pile did have trouble backing up if I went to high up on the pile, but the 312 just climbed over like it was there. 1 Share this post Link to post Share on other sites
Dirtpoor 131 #123 Posted December 18, 2019 I just got this I used it once very surprised at how well it did for the condition of this tractor. 5 1 Share this post Link to post Share on other sites
AHS 1,594 #124 Posted December 19, 2019 I moved from the snow plow to a snowblower! Kinda sorta refurbished! New chain, bearings all throughout, new sprockets, along with the auger sprocket. New paint on the chute, auger box... everything but the auger! I was working on it this month, and it was cutting it close! Boy... don’t she throw the snow!!😁💪👍 6 3 Share this post Link to post Share on other sites
MikMacMike 494 #125 Posted December 19, 2019 I like the idea of the long shoot, Ive never tried one but they look like they would work better then the shorties? Share this post Link to post Share on other sites
