Retired Wrencher 7,045 #1 Posted November 3, 2019 I want to Thank stevasaurus- ebinmaine for helping me with this 12" link set up. I have had many plows but never set up like this. The 12" link was easy to install. I have a pick that says it all with pushing leaves. Nothing left behind. Truly awesome. Just have to put the chains on I will after leaf season. Hope you enjoy the picks. 5 11 Share this post Link to post Share on other sites
ebinmaine 81,283 #2 Posted November 3, 2019 Well done Gary 1 Share this post Link to post Share on other sites
Retired Wrencher 7,045 #3 Posted November 3, 2019 2 hours ago, ebinmaine said: Well done Gary Thanks Eric as you can see by the leaves shot snow should be the same? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #4 Posted November 3, 2019 I’ve never had a snow rig with the ability to apply down pressure. Good luck with it! 1 Share this post Link to post Share on other sites
ebinmaine 81,283 #5 Posted November 3, 2019 5 minutes ago, Sparky said: I’ve never had a snow rig with the ability to apply down pressure. Good luck with it! Comes in super handy Mike. I wouldn't have 1 any other way. If you drive over the snow before you get a chance to plow it helps a lot in scraping up where the vehicle has compacted. I use it almost every time I plow out by the mailbox. 2 Share this post Link to post Share on other sites
stevasaurus 23,892 #6 Posted November 5, 2019 You will love that set up!! 1 Share this post Link to post Share on other sites
Stormin 9,988 #7 Posted November 5, 2019 Going to do that mesel'. Thanks for the idea, lads. 1 Share this post Link to post Share on other sites
Retired Wrencher 7,045 #8 Posted November 5, 2019 2 hours ago, stevasaurus said: You will love that set up!! Thanks Steve as you can see I like all ready by the leaves it pushed. I just whished I did more research on this years ago. Does your 857 have this set up? Share this post Link to post Share on other sites
Retired Wrencher 7,045 #9 Posted January 23, 2024 On 11/5/2019 at 2:27 PM, stevasaurus said: You will love that set up!! It works very well Steve since 2019. Still works well. 1 Share this post Link to post Share on other sites
peter lena 10,126 #10 Posted January 23, 2024 @Retired Wrencher nice se up , some penetrating oil on that blade surface , will stop rust , and make snow sliding easier , do quite a bit of road edge plowing when we have snow , what's that ? pete 1 Share this post Link to post Share on other sites
peter lena 10,126 #11 Posted January 24, 2024 @Retired Wrencher , just back in , from plowing wet slop , had about 3" , rain was light , always want to move it while you can , plow mine to sun angle area , so mid day , its melting into corner road drains. have also used a spray on graphite on blade , pete Share this post Link to post Share on other sites
Brockport Bill 2,553 #12 Posted January 24, 2024 2 hours ago, peter lena said: @Retired Wrencher , just back in , from plowing wet slop , had about 3" , rain was light , always want to move it while you can , plow mine to sun angle area , so mid day , its melting into corner road drains. have also used a spray on graphite on blade , pete hey Pete -- i have always treated my plow blade so snow won't stick -- i have used various products -- wd40 - pam - car wax - as well as some specific sprays marketed for snowblowers, plows etc non stick products -- Was wondering which strategy or product have you found most effective for treating plow blades, blowers etc so snow slides off? Share this post Link to post Share on other sites
stevasaurus 23,892 #13 Posted January 24, 2024 (edited) Yes, I have the link on my 857 !! That horse has a designated blade on it now. I switch between blade and mower deck on my 876, and my 702 is designated for a mower deck. Life is good. Edited January 24, 2024 by stevasaurus 1 1 Share this post Link to post Share on other sites
peter lena 10,126 #14 Posted January 24, 2024 @Brockport Bill thanks for the shout , used a spray on graphite , made for mower decks , that really hangs in there ,also used various penetrating oils , that leave a slick finish , always felt the increased slide / push was like extra , HP . of course you have to have the right snow conditions , always experimenting with something . think the oil is easiest , to apply and keeps things slick , stop rust . we all have different snow , you are on the right track , with any slide help .blowers was operational running ease , correct drive chain tension , chain lubrication , also detailed in the , auger drive belt set up , pulley frame behind blower , grease every metal / metal , point , re greased the idler pulleys , increased the spring pull , with a heavier spring , also used Pam , inside of chute , for snow release . blower would turn over , at PTO belt drive area , very easily . made a " plastic snow slide " slide gasket for bottom of chute . pam spray , moved with total ease . went after , every movement point and looked for gains . pete 1 Share this post Link to post Share on other sites
Roger R 473 #15 Posted January 24, 2024 WD-40 Has spray on silicone, which I have been using on the blower discharge chute with some success 2 Share this post Link to post Share on other sites
Retired Wrencher 7,045 #16 Posted January 25, 2024 (edited) On 1/23/2024 at 2:26 PM, peter lena said: @Retired Wrencher nice se up , some penetrating oil on that blade surface , will stop rust , and make snow sliding easier , do quite a bit of road edge plowing when we have snow , what's that ? pete This summer for the first time since 2019 when I bought the tractor and plow as a set. I put marvel on it to stop it from rusting. The hole plow that is and frame. Edited January 25, 2024 by Retired Wrencher 1 Share this post Link to post Share on other sites
peter lena 10,126 #17 Posted January 25, 2024 @Retired Wrencher thats one of the first things I do after getting another project , looking at years of neglect ,that oil soak , will either retain patina or allow you to draw out a paint shine , like to leave lubrication on to feed metal , while I,M doing other stuff . then get back to it , as mechanical / electrical issues are corrected . like its working in secret . always experimenting with something . grandson over today , for ideas / make up, to shorten plow swing arm, shorten the seat reach . you can't do that , Pete 1 Share this post Link to post Share on other sites
