Stormin 9,986 #1 Posted October 27, 2019 Once upon a time, in the dim and distant past, I made myself a snowplough/dozer blade. The build is to be found here :- Unfortunately due to Photo****it the photo's are not very good, if viewable at all. Yesterday I thought it was about time I sorted out the non existent index mechanism. The lever I had already made. So I rescued it from it's hiding place. Also had a scrat about for things to make the other parts I needed. Some chain. A gash gate/door hook retaining eye and other bits. Not photo's taken during the process, but the following one's should be self explanatory. That much does work. Now all I have to do is find/make a lever to operate the location pin. 7 4 Share this post Link to post Share on other sites
ebinmaine 74,572 #2 Posted October 27, 2019 Looks great Norm! 1 1 Share this post Link to post Share on other sites
Tractorhead 9,214 #3 Posted October 27, 2019 Cool work Norm! 👍 1 Share this post Link to post Share on other sites
Stormin 9,986 #4 Posted November 4, 2019 Got a couple of bicycle brake levers from a scrap farm bike. Bit of a mod to were it fitted to the handle bar and connected it up. After drilling a hole through a 6mm set screw to thread the bicycle cable through. Hit a snag here. The lever not being straight fouled the handle when pulled right back. So I shortened the lever. Finally I did away with the R clip that held the chain to the location pin. Threaded the hole 6mm and secured the chain. Might throw some paint at it sometime. Also see if I can find a straight steel lever to fit. Maybe not pretty but it works and it cost me nowt. PS. Sorry about the poor quality of a couple of photo's. I need a Trina. 3 2 2 Share this post Link to post Share on other sites
Sparky-(Admin) 23,772 #5 Posted November 4, 2019 Great bit of fabricating you did there Norm! How much snow do you get in an average winter? Share this post Link to post Share on other sites
SylvanLakeWH 29,337 #6 Posted November 4, 2019 Excellent job! I am looking into the same issue! Appreciate the detailed photos - will help me out! Share this post Link to post Share on other sites
Stormin 9,986 #7 Posted November 4, 2019 30 minutes ago, Sparky said: Great bit of fabricating you did there Norm! How much snow do you get in an average winter? Thankyou to your first comment, Mike. As for how much snow we get, the answer is very little. As in nothing to speak of. Never had enough to measure. We are low down on the Solway Plain and just a couple of miles or so from the coast. 10 metres above mean sea level. Go 10 miles inland and there can be quite a bit at times and further on up on the low fells, much more. 1 Share this post Link to post Share on other sites
Pullstart 68,181 #8 Posted November 4, 2019 8 hours ago, Stormin said: PS. Sorry about the poor quality of a couple of photo's. I need a Trina. @ebinmaine you see this? 3 Share this post Link to post Share on other sites
Tractorhead 9,214 #9 Posted November 4, 2019 That‘s allway‘s the main issue Norm, it have firstly to work. a „optical finetuning“ can later also be done, if needed. Found several years ago a Company they build Springs on your requirements. Aaaah, good idea, will visit them tomorrow. Share this post Link to post Share on other sites
ebinmaine 74,572 #10 Posted November 4, 2019 1 hour ago, pullstart said: @ebinmaine you see this? I did now. @Stormin Well played sir. I'll see what I can do for you. 1 Share this post Link to post Share on other sites
ebinmaine 74,572 #11 Posted November 4, 2019 Just show this to her. Her response: 1 1 Share this post Link to post Share on other sites
ebinmaine 74,572 #12 Posted November 4, 2019 She is flattered. 1 Share this post Link to post Share on other sites
