Countdown To Christmas!
Gas Man
KT 17 No Spark
ZXT
8 minutes ago, Gas Man said:
I guess with hydraulic lift, it would be the same?
I don't want to give bad information, but I believe it should be. I think past the lift handle, everything is the same between hydraulic and manual lift.
Gas Man
I looked at it last night!  It may not be exactly the same, but it was easy to pick out after you pointed me in the right direction!!  Thank you!!
While you are reading... Why does the Crank Case Vent tube have so much pressure on my KT17? It feels like it is connected to an air pump!!!  My first thought is that the engine is worn out and it has severe "Blow By."  While I have only put a couple hours on it since I got it out of the barn, it does not smoke much at all, but after it heats up it runs real rich and occasionally on 1 cylinder.  I disconnected the breather from the air cleaner and it runs MUCH better.  I ran a compression check on it a while back and the numbers were lowerer than I had hoped for, although I can't remember them.  I want to think it was around 90 ish.
  • Similar Content
    • Rhondajoy79
      By Rhondajoy79
      Briggs 11 horse keeps going through coils-
             Hello, I hope you all can help. We have a b-115. When we got the tractor we had to rewire it, and changed the stator, the point, condenser, and coil. He mowed the yard 2 times and then we put it up for the winter. We got it out to get it ready for this mowing season and it wouldn't start, Dad tested everything and said there was nothing at the coil. Ordered new coil, put it on it started and was fine. He mowed the yard twice and it is bad again. Dad checked everything and said he can't figure it out. If any body could help, as I don't know anything about them. He is 72 and very frustrated that he can't figure it out. I would appreciate any help to get this figured out for him. He has all the manuals available(thank you all by the way for that.) and he is just poking in the dark at this point. Thank you in advanced.
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
    • Mithral
      By Mithral
      So my Kohler CH18S had a coil problem.  One coil tested out bad.  So I replaced both coils while I have things apart, ... and now I have a coil grounding issue.
      When the kill wire is connect to both coils, the engine will not start.
      If I remove both kill wires the engine will start, and will consequently stop when I reconnect the wires.
      If I remove one kill wire from either coil, the engine will start and run on one cylinder, until I reconnect the second kill wire and then the engine stops.
      If I disconnect the kill wire going to the wire harness, it makes no difference to the above.
      It appears that the kill wire connected in series from one coil to the other coil is grounding out from coil to coil.
      I have no idea why this might be.  Unless I simply got the wrong coils.
      So I thought I would ask advice before I go rewiring myself a separate kill switch while I have everything opened up.   Or I guess I could fall back to just choking it to turn off.  Hmm....
    • richm1386
      By richm1386
      Quick story and a couple of questions concerning replacing the ignition coil on my '89 416-8 with Onan P216 engine.
      So I got this old tractor from my Dad when he replaced it and it was running okay until a few weeks ago. Was picking up sticks and hauling them out to the wood pile when I idled down the tractor and then it stalled out (which happens all the time.) I tried starting again and it would not turn over. The starter would go and go but no ignition. I spent a lot of time on these forums and found some really good info including the service manual. I used that diagnose the problem and figured out the coil was bad. I ordered a new off brand coil and condenser from Amazon for $40 swapped them in last night and it fired almost immediately. Plus since I had taken the shroud off and disconnected the throttle cable it was idling well at very low throttle. I've still got to reassemble everything properly but it seems like the coil was the culprit.
      That said I've got a couple questions.
      1. Anybody have any luck with non-Onan coils?The one I got from Amazon seems well made but it is literally some no name part. I figured for $40 it was worth a shot.
      2. Does it matter which spark plug attaches to which plug on the coil? I forgot to take a photo before I disassembled.
      3. Could a failing coil cause very hard starts and stalling at low idle? I'm asking because as I said above the tractor has been very hard to start for years. Almost always needed to choke it. It would also stall out if you idled down nearly every time. Just the brief testing with the new coil that I've done, both of these issues seem much better. Also I used my Dad's replacement (early '90s 416-h with same engine) for this tractor while working on mine and it started and idled very easily. It looks like it might have a replacement coil as well. Just wondering.
      Thanks all.
    • Redwheel
      By Redwheel
      I have a commando v8 with the Kohler kv181s, I have found most prices to put it back to running, but I need to know what the coil was as it was external, part numbers , and any pictures anyone would have of how it was wired , I know a lot of people are replacing but I'd like to keep it original.  Thank you ,
