Ed Kennell
More Whatizits
Ed Kennell
4 minutes ago, LengerichKA88 said:
Marines don’t surrender.... I will think of something.
Don't mind the burning wood smell, that’s me.
Can I get positive confirmation that they’re fabric and wax or other wise coated? (Worth a shot 😂)
wax
4 minutes ago, Stormin said:
Now what would grandma singe? :scratchead:
Hair? In ears? Up Nose?
ears, nose  nope
LengerichKA88
Are they for candling ears?
paper tubes coated in wax to be slower burning and more rigid?
Edited by LengerichKA88
Ed Kennell
Norm is just about there....probably close enough to google the correct answer.
LengerichKA88
Either that or they were lit at one end and held at the other to be a slow burning, no open flame way of getting unsightly hair from hard to reach and see at the same time places.
*ear waxing sticks
Ed Kennell
*ear waxing sticks
You and Norm are sooo close, you both deserve an answer.   Here Ya go.     Thanks for all the interest.
P4220347.JPG.049844e81b270f61b4d6b8ff78600c8c.JPGP4220348.JPG.f747360e798cbef39b51f426bfc443f6.JPG
Get rid of Grandma's split ends.   Do not sip moonshine while using this product.
Edited by Ed Kennell
  • Haha 3
  • Confused 1
formariz
Grandma had hairy ears?Oooh.
  • Haha 2
ebinmaine
Not for long Cas.
guys if you would please excuse me for a couple hours I have to run down to the salon or barber shop and get a flaming stick of wax stuck on the inside of my cranial cavity for a few minutes
  • Haha 2
LengerichKA88
2 minutes ago, ebinmaine said:
Not for long Cas.
That’s exactly what my barber does
I don’t have that done though 😂
I had thought about split ends but dismissed it because I couldn’t think of how you’d actually use it. That was a good one  @Ed Kennell. Now I’m gunna try and dig something up.
  • Haha 1
formariz
All right that was a good one. Learning every day here. Lets try this one again. Not so tricky as last one.Don't ask Grandma she will have no idea. Grandpa maybe. And no its not a body hair remover.
LengerichKA88
Is the wheel sharpened or dull?
ebinmaine
You know what I have at my house? You wouldn't believe it. Different types of scissors. Razors, stuff like that.
I can actually remove hair from all of the aforementioned places without even setting myself on fire.
  • Haha 4
Stormin
Looks dull to me and not round.
formariz
Wheel is perfectly rounded and smooth.
Ed Kennell
Does it need a motor to operate?
Stormin
I think it's for putting grooves something?
formariz
No, it's a hand tool.
formariz
It's a  "groovy" tool but does not make grooves.
Edited by formariz
formariz
Lets see. Choice between a cut or a burn. OK I choose cut.Not easy controlling a fire.
  • Haha 1
wallfish
5 hours ago, Ed Kennell said:
I don't want to stress any one over the brink  like @wallfish.
Did you like that one Ed?
  • Haha 1
Ed Kennell
Does the wheel turn to perform the operation, or does the work piece slide on the metal guides?
formariz
Wheel can turn "if" desired and work piece does slide on metal .
Ed Kennell
Is the wheel eccentric so it can be adjusted in and out of the slot?
formariz
Wheel is perfectly round and does not move except for rotating "if" desired.
formariz
I am feeling much better now. Felt a little defeated with Grandma's therapeutic cup.
  • Haha 1
Ed Kennell
I think the other players must be burned or singed out.
