12 hp Kohler
My new gt14
ztnoo
3 hours ago, Aldon said:
And it adds Bling!!!!
That's Super Bling, with whip cream and a cherry on top!
  • Haha 1
12 hp Kohler
I have been making some progress on the gt14. I have wanted to post an update for a while but have been too busy between school, work and all of my projects.
So... I took it for a test drive and the hydro seems to work pretty good. I am a little worried about the hydraulic lift because it lifts super slowly. I know it’s not supposed to be fast but it seems slower than usual. Opinions? Does the hydraulic cylinder need rebuilt? I haven’t put any weight on the 3pt yet so I don’t know if it is strong or not.
I pulled the gas tank and cleaned it up, I am going to try to do repairs on it soon. I didn’t realize how bad it was cracked till I pulled it out. Here are a few pictures of it after I cleaned it up a bit. I am going to clean it up a bit more and see if I can repair it.
0DBF66C1-9A40-4299-BA1D-8A62177DAC26.jpeg.38028658e950bfe8d9e29fabc7ddb0a6.jpegE1E4957C-E1C0-40F4-BED0-0271DCD19390.jpeg.4fd2466852fb4153364b440a5b840250.jpeg
i pulled the carburetor out and it is shot. The choke plate is bent and the throttle shaft is broken, that explains why it was running a little rough. I have a different carburetor that I am going to rebuild and put on.
Picked up transmission fluid and a filter a couple weeks ago. I am going to try and put it in this weekend.
I also pulled the 3pt off to clean it up and replace some hardware.
I will post another update when I make a little more progress. I am gonna try to have it at least running and driving for the big show in June.
  • Excellent 3
Pullstart
Good to see your progress Robbie!  That tank is pretty rough.  I’m not saying it can’t be fixed, but it won’t be quick!  Once it’s sealed up, I’d suggest epoxying some fiberglass material onto it to help hold it together.  As for the hydraulic cylinder, try putting weight on the 3 point and see if it drops at all.  Slow movement wouldn’t really be the cylinder’s fault unless the seal is leaking internally.
12 hp Kohler
I am gonna try and heat the plastic a little bit and bend it back to shape, then I am going to try to jb weld the crack.
If anyone has an old style gt 14 tanks please pm me. I know they are uncommon but it’s worth a shot.
dells68
Look up plastic welding on here.  Several folks have had good luck using zip ties as their filler material and blending it with the original plastic to create a permanent repair.  I’m with @pullstart on using some good epoxy and fiberglass cloth.  I’ve done it myself on plastic and it creates an extra level of insurance after you repair the plastic.
12 hp Kohler
I will look into it, thanks for the good info.
RandyLittrell
Another option if it doesn't work to fix it and you want to use a different tank like @19richie66 would be to cut out the front portion of the tank and mount it to the nose, then put a different tank in behind it. That way it would still look original from the outside.  Just a thought.
Randy
  • Like 4
12 hp Kohler
Changed the hydro fluid and filter on the GT last weekend. Rebuilt the carb and put it back on yesterday. Now i am just waiting for the gas tank to be finished. I took it to an Amish guy that does plastic welding, i am just hoping its done in time for the big show.
  • Like 4
  • Excellent 2
kthack657
Great tractor, I have a 73 GT14, the one tip I have is be very careful with the gas tank, or change out the front end to a newer model (where it was iron the whoke way around...
The gas tanks are pretty difficult to find...good luck with your tractor!!!!
  • Similar Content
    • Rob R
      By Rob R
      I finally broke something serious on my GT14 the Lift arm that is attach (by chain) to the plow snapped off at the receiver arm top which is attached to the Hydro cylinder on the bottom. It appears the broken arm was welded there (see pics) my big question is how do get the "H" arm which is mounted on each side of the tractor by the steel plates the go up from the tractor frame out. I took off the four mounting bolts for it but it is tightly fit in aforementioned side plates I can move it up and down but cannot get it out. Is it relatively easy to remove one of the side plates and if yes which side is the easiest the pedal side left side (from the back) or the right side (from the back). Has anyone from the square experienced this problem, does anyone have this lift assembly. Any and all comments welcomed. p.s. I have used this beast for 10 years with zero major issues guess the stress of the lifting finally got to the arm which obviously is under tremendous pressure......Rob
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
