pfrederi 18,577 #1 Posted March 15, 2019 I burn coal so other than a small amount of wood I need to start it and have a bit for the Chiminea I do not cut much. Now I have 10 big ash trees down and some more to come. My question is what do you use to hold the smaller logs 3-5" in diameter 4-8' long that you want to cut to stove length? Share this post Link to post Share on other sites
Mikey the Monkey 700 #2 Posted March 15, 2019 (edited) Your left foot. Careful not to get a chainful of foot or earth. Also a good situation for a buzzsaw Edited March 15, 2019 by Mikey the Monkey Spelling 2 Share this post Link to post Share on other sites
pfrederi 18,577 #3 Posted March 15, 2019 5 minutes ago, Mikey the Monkey said: Your left foot. Careful not to get a chainful of foot or earth. Also a good situation for a buzzsaw I was trying to get them up some so I didn't cut into the ground which here is mostly rocks.... Share this post Link to post Share on other sites
ebinmaine 71,995 #4 Posted March 15, 2019 I can't get a picture of it right now cuz it's buried in snow. We have a double ended sawhorse so to speak. Each end is an X They are held about 30 inch apart by cross boards. Put the log in the X and it keeps it well off the ground and away from nasty things that chains don't want to get into. Share this post Link to post Share on other sites
stevasaurus 23,237 #5 Posted March 15, 2019 Paul, I've got one of these. The yoke holds the wood and actually lifts the wood off the ground while you cut. You push down on the handle and the saw moves into the wood, lefts it a touch and cuts it while you are standing up. You can just move to the next cut when done without touching the wood. Great for up to 5 or 6" pieces. Easy on the back and it cuts quick. I use it a lot, and I have sharpened it only a few times. You never saw dirt with this, just walk around and cut. This thing is amazing. Click on the link and watch the short video. Mine is not cordless, which makes if cost less. https://www.lowes.com/pd/WORX-JawSaw-20-volt-Lithium-Ion-6-in-Cordless-Electric-Chainsaw-Battery-Included/4740252 1 Share this post Link to post Share on other sites
Mikey the Monkey 700 #6 Posted March 15, 2019 Once I get a little pile started I thrown the 3 to 6 footers on the pile and cut them up there. That keeps them off the ground and in a neat pile. Use your head, be careful and don't be in a hurry Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #7 Posted March 15, 2019 7 minutes ago, pfrederi said: I was trying to get them up some so I didn't cut into the ground which here is mostly rocks.... 7 minutes ago, ebinmaine said: Put the log in the X and it keeps it well off the ground and away from nasty things that chains don't want to get into. Every 4-6' I just put a sawn block of wood under the "log" (or roll said log onto sawn block) this will keep it up out of the dirt/rocks and you don't have to lift it very high to boot the use of a "cant hook" comes in handy as well especially with the bigger diameter logs don't cut all the way through then roll it over to finish...or a chain and a FEL will get them hanging high. 5 Share this post Link to post Share on other sites
classiccat 548 #8 Posted March 15, 2019 as far as getting uniform length, I plan to use this trick the next time I'm out back cutting. 1 Share this post Link to post Share on other sites
ebinmaine 71,995 #9 Posted March 15, 2019 Here's the top half of our log cutting sawhorse. 2 Share this post Link to post Share on other sites
ebinmaine 71,995 #10 Posted March 15, 2019 13 minutes ago, classiccat said: as far as getting uniform length, I plan to use this trick the next time I'm out back cutting Got to admit that's a pretty good idea. The Safety Administrator in me is a little bit bothered by the fact that that wire is close to your carrying hand but if you watch what you're doing it should be fine. I can see the logic in wanting firewood that is all the same length but we don't worry about it here. We cut ours around 14 or 15" and it either Stacks up or it does not. If it won't stay it gets flipped around or tossed on the top of some other pile. Trina's pretty good at playing Tetris while stacking firewood. 1 Share this post Link to post Share on other sites
classiccat 548 #11 Posted March 15, 2019 (edited) 4 minutes ago, ebinmaine said: Got to admit that's a pretty good idea. The Safety Administrator in me is a little bit bothered by the fact that that wire is close to your carrying hand but if you watch what you're doing it should be fine. I can see the logic in wanting firewood that is all the same length but we don't worry about it here. We cut ours around 14 or 15" and it either Stacks up or it does not. If it won't stay it gets flipped around or tossed on the top of some other pile. Trina's pretty good at playing Tetris while stacking firewood. Would a long wire tie be more suitable for retaining one's digits and eyeballs? Edited March 15, 2019 by classiccat Share this post Link to post Share on other sites
ebinmaine 71,995 #12 Posted March 15, 2019 8 minutes ago, classiccat said: Would a long wire tie be more suitable for retaining one's digits and eyeballs? Well, let me just put the standard legal disclaimer on here first. I am not now nor have I ever been an engineer in either the plastics or metal industry and I have no knowledge other than common sense and life experience as to the break strength force of these materials. But yeah. I would be more comfortable with something made out of plastic that I know the chain would cut through instead of whip-around at me. 1 Share this post Link to post Share on other sites
pfrederi 18,577 #13 Posted March 15, 2019 I had thought about the old fashioned cross buck but isn't the last piece going to be the length of the stand which is too long 30" or do you make a 16 inch stand??? The works thing Steve mentioned is nice but probably more than I can justify. May get the cant hook as I will need something when I get the big logs. Thanks for all the info!!! Share this post Link to post Share on other sites
ebinmaine 71,995 #14 Posted March 15, 2019 6 minutes ago, pfrederi said: isn't the last piece going to be the length of the stand which is too long 30" or do you make a 16 inch stand??? I always have an extra set of hands here so I just have Trina hold that last piece in place. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #15 Posted March 15, 2019 6 minutes ago, pfrederi said: I had thought about the old fashioned cross buck but isn't the last piece going to be the length of the stand which is too long 30" or do you make a 16 inch stand??? The works thing Steve mentioned is nice but probably more than I can justify. May get the cant hook as I will need something when I get the big logs. Thanks for all the info!!! This may even work better for you...https://www.northerntool.com/shop/tools/product_200612315_200612315 1 Share this post Link to post Share on other sites
Stormin 9,984 #16 Posted March 15, 2019 (edited) Anything under 6" diameter goes through my saw bench after, if a long piece, has been shortened with the chainsaw. At home that's done with them on a wooden pallet along with bigger stuff. In the field resting on another or rolled over. Edited March 15, 2019 by Stormin Share this post Link to post Share on other sites
pfrederi 18,577 #17 Posted March 15, 2019 I like the cant with stand. The other half doesn't come outside unless the temp in in the 70s ...so no extra hands. 1 1 Share this post Link to post Share on other sites
ztnoo 2,300 #18 Posted March 16, 2019 https://www.northerntool.com/shop/tools/product_200640336_200640336 https://www.northerntool.com/shop/tools/product_200612314_200612314 https://www.northerntool.com/shop/tools/product_200612316_200612316 1 Share this post Link to post Share on other sites
Pullstart 66,194 #19 Posted March 16, 2019 @pfrederi this stand was built for cutting up small logs and slab wood. 2 Share this post Link to post Share on other sites
ztnoo 2,300 #20 Posted March 16, 2019 For any of you wood burner, forester, or arborist types out there in the vast and diverse woodlands of the US, you might want to take a look at this site: https://www.bartlettman.com/ 1 1 Share this post Link to post Share on other sites
