wallfish 20,091 #26 Posted January 19, 2019 5 hours ago, Mows4three said: Is there any frame attachment point that helps take the load off of the transaxle or is it all mounted to the transaxle? It's integrated with the sub-frame for the loader but the only place that attaches to the frame is the mid Tach A Matic. The rest is attached to the trans but in multiple locations on it. Top, axles and the rear draw bar location. 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 86 #27 Posted April 14 On 1/17/2019 at 4:29 PM, Kurt-NEPA said: This is what I did to balance out a two stage blower on my 520H. It has worked well. It has 125lbs. of barbell weights and about 30 lbs of hitch weight. Can you post more photos of how you built this bracket? Looking to do the same on my 312. I found a whole box of these weights under my deck, left behind from the previous owner. 1 Share this post Link to post Share on other sites
peter lena 9,910 #28 Posted April 14 @lynnmor https://www.google.com/search?q=isolation+pads&rlz=1C1CHBF_enUS866US866&oq=isolation+pads+&gs_lcrp=EgZjaHJvbWUyCQgAEEUYORiABDIHCAEQABiABDIHCAIQABiABDIHCAMQABiABDIHCAQQABiABDIHCAUQABiABDIHCAYQABiABDIHCAcQABiABDIHCAgQABiABDIHCAkQABiAB always use an isolation pad with any casting mount , greatly reduces the heavy solid stress on the area , use that UNDER THE REAR END TONGUE MOUNT POINT , when I see the ridiculous amounts of weight added to a regular frame set up , it will track to the next weakest area , another thing , it would be easy to duplicate original frame design , with much heavier stock , regularly see , hydros with cracked , fractured framing , recently saw another destroyed , horse , pete 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 86 #29 Posted April 14 3 minutes ago, peter lena said: @lynnmor https://www.google.com/search?q=isolation+pads&rlz=1C1CHBF_enUS866US866&oq=isolation+pads+&gs_lcrp=EgZjaHJvbWUyCQgAEEUYORiABDIHCAEQABiABDIHCAIQABiABDIHCAMQABiABDIHCAQQABiABDIHCAUQABiABDIHCAYQABiABDIHCAcQABiABDIHCAgQABiABDIHCAkQABiAB always use an isolation pad with any casting mount , greatly reduces the heavy solid stress on the area , use that UNDER THE REAR END TONGUE MOUNT POINT , when I see the ridiculous amounts of weight added to a regular frame set up , it will track to the next weakest area , another thing , it would be easy to duplicate original frame design , with much heavier stock , regularly see , hydros with cracked , fractured framing , recently saw another destroyed , horse , pete I plan to come up with a way to make a bracket that goes into the 2 inch reciever. I fure having the weight put down on the whole trans is way safer then on the standard pin hitch. 1 1 Share this post Link to post Share on other sites
lynnmor 8,855 #30 Posted April 14 8 hours ago, peter lena said: @lynnmor https://www.google.com/search?q=isolation+pads&rlz=1C1CHBF_enUS866US866&oq=isolation+pads+&gs_lcrp=EgZjaHJvbWUyCQgAEEUYORiABDIHCAEQABiABDIHCAIQABiABDIHCAMQABiABDIHCAQQABiABDIHCAUQABiABDIHCAYQABiABDIHCAcQABiABDIHCAgQABiABDIHCAkQABiAB always use an isolation pad with any casting mount , greatly reduces the heavy solid stress on the area , use that UNDER THE REAR END TONGUE MOUNT POINT , when I see the ridiculous amounts of weight added to a regular frame set up , it will track to the next weakest area , another thing , it would be easy to duplicate original frame design , with much heavier stock , regularly see , hydros with cracked , fractured framing , recently saw another destroyed , horse , pete As you can see the bolts holding the transmission halves together are rather far apart and the factory hitch puts all of the weight on the right side. After cracking one case half I won't be adding a lot of weight behind the axle where it can bounce and add dynamic force to the static load. 2 1 1 Share this post Link to post Share on other sites
Handy Don 16,770 #31 Posted April 15 22 hours ago, 1987_WHEEHORSE312 said: I plan to come up with a way to make a bracket that goes into the 2 inch reciever. I fure having the weight put down on the whole trans is way safer then on the standard pin hitch. Many posts here with examples of brackets strongly mounted to support rear weights. 2” receivers, and so forth and Wheel Horse Parts and More (a vendor supporting this site) offers a nice one as well. 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 86 #32 Posted April 15 3 minutes ago, Handy Don said: Many posts here with examples of brackets strongly mounted to support rear weights. 2” receivers, and so forth and Wheel Horse Parts and More (a vendor supporting this site) offers a nice one as well. Do you mind leaving a link for their part? I am interested 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,601 #33 Posted April 15 8 minutes ago, 1987_WHEEHORSE312 said: Do you mind leaving a link for their part? I am interested https://www.wheelhorseforum.com/forum/141-wheelhorse-parts-and-more/ 1 Share this post Link to post Share on other sites
Handy Don 16,770 #34 Posted April 15 Sure. https://wheelhorsepartsandmore.com/product/heavy-duty-removable-receiver-hitch-with-axle-mounting-hardware-if-you-do-not-have-a-104659-bracket/ This one assumes you do not have a the rear axle bracket that holds a front blade or a tiller--there is another version for if you do have one. Click around on their catalog and you’ll find lots of interesting stuff. Some members have found hitches they liked on eBay and Facebook Marketplace, too. 1 Share this post Link to post Share on other sites
ebinmaine 79,272 #35 Posted April 15 9 hours ago, Handy Don said: (a vendor supporting this site) @76c12091520h has a nice trailer hitch too. I have a couple here. Highly recommended. 1 1 Share this post Link to post Share on other sites
peter lena 9,910 #36 Posted April 16 @1987_WHEEHORSE312 where are you located in ct ? I am in ledyard , might get together for a shoot the breeze ? pete Share this post Link to post Share on other sites
DLF 74 #37 Posted April 19 On 4/15/2026 at 7:07 PM, ebinmaine said: @76c12091520h has a nice trailer hitch too. I have a couple here. Highly recommended. We need pictures! You know the rules, " No pictures it didn't happen". Lee1977 Share this post Link to post Share on other sites
ebinmaine 79,272 #38 Posted April 19 @DLF @Lee1977 Here's a link. Share this post Link to post Share on other sites
