pyroplegic 55 #1 Posted January 6, 2019 Got a 416H yesterday needs a starter to start with. haaa 4 Share this post Link to post Share on other sites
Wishin4a416 2,610 #3 Posted January 6, 2019 Some very able machines there. Enjoy! Share this post Link to post Share on other sites
WHGuy413 2,859 #4 Posted January 6, 2019 I have a 416H. I almost died when the dealer told me the cost of a starter. Make sure your sitting down when you find out. Are you positive it's the starter that's bad? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted January 6, 2019 I'm sure someone here has a starter for it . I would check fleabay as well, Share this post Link to post Share on other sites
pyroplegic 55 #6 Posted January 6, 2019 Im going to replumb the fuel system too, what fuel line do yall suggest Share this post Link to post Share on other sites
pyroplegic 55 #7 Posted January 7, 2019 its a 92, what else can you tell from the serial number?? Share this post Link to post Share on other sites
Jake Wilkerson 38 #8 Posted January 7, 2019 Maybe you have a starter and alternator shop local and can get it rebuilt? 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #9 Posted January 7, 2019 (edited) Are usually go to O'Reillys or AutoZone to get the quarter inch fuel line. Edited January 7, 2019 by The Tool Crib 1 Share this post Link to post Share on other sites
chip61 666 #10 Posted January 7, 2019 I don't know where you are in VA, but there is a decent starter/gen shop here in Richmond. 1 1 Share this post Link to post Share on other sites
953 nut 70,347 #11 Posted January 7, 2019 1 hour ago, The Tool Crib said: Are usually go to O'Reillys or AutoZone to get there quarter inch fuel line. 3/4" ???? Are you running a top fuel dragster? I use 1/4" rubber fuel line, think most do the same. 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #12 Posted January 7, 2019 I have a good working starter from a 520-H model 41-200E02 that should match the Onan 16hp engine in your model 51-160E02. Lacated in N/W PA but can ship anywhere. $55 + ship.... Interested: send me an off-site email.. I am: daveoman@windstream.net 1 Share this post Link to post Share on other sites
bc.gold 3,406 #13 Posted January 7, 2019 (edited) Deleted by author. Edited January 7, 2019 by bcgold Share this post Link to post Share on other sites
ebinmaine 81,150 #14 Posted January 7, 2019 9 hours ago, pyroplegic said: Im going to replumb the fuel system too, what fuel line do yall suggest I've switched over to using blue see through line I bought from Lincoln at A to Z tractor. I have also used tygon but it's pricey. I like to be able to see the fuel moving. 3 Share this post Link to post Share on other sites
ohiofarmer 3,529 #15 Posted January 7, 2019 Onan starters are right in a location where they get dirt and dust in them. every couple of years, i have to take mine off and clean and lube the thing and all is good. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #16 Posted January 7, 2019 6 hours ago, ohiofarmer said: Onan starters are right in a location where they get dirt and dust in them. every couple of years, i have to take mine off and clean and lube the thing and all is good. My Anniversary 520 hasn't had the starter off since I bought it new, I guess it depends how its taken care of. Share this post Link to post Share on other sites
pyroplegic 55 #17 Posted December 11, 2019 (edited) "Update* Put on new;Battery, Starter, spark plugs, ignition coil,,fuel lines,,fuel oil & air filters, key switch, turn the key relay clicks,oil pressure light flashes, nothing happens. Jump to the starter engine turns over, Key switch passes continuity, test switch activates warning lights. we think we are missing some safety switch.the seat switch is shorted from previous owner, I need help please. Im a gear head and Wheel Horse fan, in Fredericksburg Va. My problem is I'm quadriplegic from a motorcycle accident in 2005, and cant wrench like before. I hope that there is a similar gear head out there, locally, who would work on this with me. Message me for further discussion. Edited December 11, 2019 by pyroplegic 2 Share this post Link to post Share on other sites
Pullstart 71,520 #18 Posted December 11, 2019 I hope someone will come through for ya! @WVHillbilly520H @dells68 Anyone close by? 1 Share this post Link to post Share on other sites
AHenry014 128 #19 Posted December 11, 2019 Are you depressing the brake? Is the PTO engaged? Share this post Link to post Share on other sites
pyroplegic 55 #20 Posted December 11, 2019 Yeah the pto is disengaged. Share this post Link to post Share on other sites
peter lena 10,109 #21 Posted December 11, 2019 pyroplegic, your getting close and you barely started ! love the response and reply's , good used starter , local starter / and alternator shop, your service on the horse , i can sense the want to help here , we are pulling for you , pete Share this post Link to post Share on other sites
953 nut 70,347 #22 Posted December 12, 2019 23 hours ago, pyroplegic said: I hope that there is a similar gear head out there, locally, who would work on this with me. Message me for further discussion. Howard, @857 horse lives in that general area. If he can't help he may know someone who can. 1 Share this post Link to post Share on other sites
