ebinmaine 80,748 #126 Posted June 27, 2023 4 minutes ago, p38js said: We all have a direction it’s just some of our line zig zag more than others Mine looks more like you gave a toddler a crayon and a blank wall... Then coffee. 5 Share this post Link to post Share on other sites
SylvanLakeWH 32,556 #127 Posted June 28, 2023 As with the other one... Been 2 days... ain't you done yet??? 2 Share this post Link to post Share on other sites
WHX?? 58,162 #128 Posted June 28, 2023 I'll just say from a purist standpoint......but i will add ... 4 Share this post Link to post Share on other sites
BOB ELLISON 2,983 #129 Posted June 28, 2023 6 hours ago, Pullstart said: And who could not enjoy this masterpiece by @BOB ELLISON! This rode on the bed in the camper on the way home! Yep that's one I made 3 or 4 years ago. That was a lot or work but I loved trying different things. I sold it at the big show to a young man. 1 3 Share this post Link to post Share on other sites
Tractorhead 9,217 #130 Posted June 28, 2023 9 hours ago, BOB ELLISON said: Yep that's one I made 3 or 4 years ago. That was a lot or work but I loved trying different things. I sold it at the big show to a young man. It looks fantastic 👍 Share this post Link to post Share on other sites
peter lena 10,070 #131 Posted June 28, 2023 @ p38js likin it , had to ask , in above , kool bits picture , that electric clutch , are those , WIDE RUBBER SIDE SHIELDS ?, what a re grease opportunity . carefull removal , very thin flat edge , remove both sides , wipe out carb cleaner wet clean cloth for finish , repack with a hi temp anti sling grease , reseal , bet it works better / stay crazy . pete Share this post Link to post Share on other sites
peter lena 10,070 #132 Posted June 28, 2023 (edited) @Pullstart likin it , had to ask , in above , kool bits picture , that electric clutch , are those , WIDE RUBBER SIDE SHIELDS ?, what a re grease opportunity . carefull removal , very thin flat edge , remove both sides , wipe out carb cleaner wet clean cloth for finish , repack with a hi temp anti sling grease , reseal , bet it works better /pete Edited June 28, 2023 by peter lena duplication of reply Share this post Link to post Share on other sites
Handy Don 17,480 #133 Posted June 28, 2023 17 hours ago, ebinmaine said: Mine looks more like you gave a toddler a crayon and a blank wall... Then coffee. Or sugared, highly caffeinated soda. Best served at a birthday party of a dozen or more seven-year olds! 1 Share this post Link to post Share on other sites
Pullstart 71,259 #134 Posted July 26, 2023 It was a tire day at the auction! I found these 18x8.5-10 fronts that match the rears and are still quite massive. 1 Share this post Link to post Share on other sites
Pullstart 71,259 #135 Posted April 15, 2025 Rylee’s been a busy girl. Not a ton of tractor time. But her 875 is sitting in the shop after plow day. It gets me brainstorming. 3 1 Share this post Link to post Share on other sites
Pullstart 71,259 #136 Posted April 15, 2025 If anyone recalls, I built this exhaust system for Steve, my C-81 back in 2020 or so. After I removed the engine and sold the roller to @jeremi3210 for pulling, the exhaust has been hanging out back. It’s no Bud Andrews muffler, but it sounded great on that 8 hp Kohler. I’d imagine a Briggs 16 twin should be able to breathe through it too! 2 Share this post Link to post Share on other sites
Pullstart 71,259 #138 Posted April 15, 2025 It may need a little adjustment, based on the idea that this 875 has stirrups and not floor boards, but it is an option. 1 Share this post Link to post Share on other sites
ebinmaine 80,748 #139 Posted April 15, 2025 14 minutes ago, Pullstart said: me brainstorming Oh noooooooo 3 Share this post Link to post Share on other sites
Pullhosen’s Pony Express 98 #140 Posted April 15, 2025 With the hydro pump and the filter, this surely won’t fit as originally designed, but might be usable for parts. I have more exhaust headers I can chop for the rest of the pipes too. 1 Share this post Link to post Share on other sites
p38js 444 #141 Posted April 15, 2025 Kevin, my original idea was to run duals out the back and try to keep the pipes tucked up under the frame, the way you have them looks pretty sweet! Might have to run fire proof britches 1 3 Share this post Link to post Share on other sites
953 nut 69,379 #142 Posted April 16, 2025 19 hours ago, Pullstart said: It may need a little adjustment, based on the idea that this 875 has stirrups and not floor boards, but it is an option. Also. 875 is a short frame. 2 Share this post Link to post Share on other sites
Pullstart 71,259 #143 Posted April 16, 2025 Rylee likes this pipe idea. Not having any plans for which machine will go to the Big Show, I was thinking it would be wise to maybe do some work on it when my time allows, and she can help when she’s available. 1 1 Share this post Link to post Share on other sites
WHX?? 58,162 #144 Posted April 16, 2025 18 hours ago, p38js said: Might have to run fire proof britches 4 Share this post Link to post Share on other sites
Ed Kennell 47,377 #145 Posted April 16, 2025 19 hours ago, p38js said: Might have to run fire proof britches Kevin may have a HOT DEAL on his tent stove PJs. 4 Share this post Link to post Share on other sites
Pullstart 71,259 #146 Posted April 22, 2025 I decided to play a little last night. After all, this is the 60th anniversary of the 875, the first hydro! 2 2 Share this post Link to post Share on other sites
ebinmaine 80,748 #147 Posted April 22, 2025 I like the thought process. You going to true duals or a collector? How's the heat soak in various areas? Share this post Link to post Share on other sites
Pullstart 71,259 #148 Posted April 22, 2025 36 minutes ago, ebinmaine said: I like the thought process. You going to true duals or a collector? How's the heat soak in various areas? I’m going to plan to Y it right near where I left off. Little steps to make that happen well. I believe this exhaust can support an 800 hp circle track car. With the air blowing across the pipes, I imaging it’ll do alright with little load on it. 1 1 Share this post Link to post Share on other sites
Pullstart 71,259 #149 Posted April 22, 2025 I think this will flow! 2 2 1 Share this post Link to post Share on other sites
