Daron1965 644 #1 Posted December 27, 2018 I have been looking at disc harrow attachments for my 312-8. The local stores offer Brinly smooth disc, and Agri Fab notched disc. I plan on using it to disc up my already plowed plots, and then run between rows of the larger plot. Is one better than the other? What do you use, and how does it work? Thank you. 1 Share this post Link to post Share on other sites
ebinmaine 77,538 #2 Posted December 27, 2018 Perhaps @PeacemakerJack @Achto @WHX21 and the other plow dogs would like to throw some information in here... I don't do any ground engagement work but I do like seeing the information. Share this post Link to post Share on other sites
Achto 31,132 #3 Posted December 27, 2018 (edited) Both discs have similar construction so I guess the choice is down to the type of blades that you want. Here is a good read to help you decide. http://www.amcomfg.com/in-the-market-for-a-disc-harrow/ I would think for the use that you described a smooth disc would be fine. Disc do a good job, they will require you to add some weight to them though. A double gang set up works better but greatly reduces you turning radius as you will not be able to pick it up at the end of the row. Edited December 27, 2018 by Achto Share this post Link to post Share on other sites
WHX?? 55,228 #4 Posted December 27, 2018 If you can find the older Brinly ones the better. Most of the cheaper ones don't have heavy steel in them and get banged up rather easily with concrete blocks bouncing around on them. I have a older Brinly and a newer one I pull in tandem and there is no comparison. The disc depends on the type of soil you have. In sand country here we use smooth. Notched is better if you are in clay and do a better job with cornstalks. Run diagonal to plowed furrows if possible. Rough ride but better results. King Cutter has a well built one but the price reflects it! I would see what TSC offers as well. https://www.northerntool.com/shop/tools/product_200311181_200311181 Made for atv use tho. I seldom use a horse any more as my size of plot it takes too long.... unless one wants extended seat time Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #5 Posted December 28, 2018 Older Brinly, sometimes , or Cub Cadet branded as well. 1 Share this post Link to post Share on other sites
WHX?? 55,228 #6 Posted December 28, 2018 That's what I'm talking Jeff .. you can still get ones that are built like a $hi! brickhouse but pricey..... 1 Share this post Link to post Share on other sites
squonk 45,608 #7 Posted December 29, 2018 I like my disc all shiny and clean! 2 3 1 Share this post Link to post Share on other sites
6wheeler 675 #8 Posted January 13, 2019 On 12/29/2018 at 12:33 PM, squonk said: I like my disc all shiny and clean! Mike, that is just too pretty. You should load that up and run out here in say, May. I will help you get all that nasty black paint off those blades . A tandem disc definitely works better than a single gang. I like the notched blades in my clay ground here. I have a tandem three point Brinly disc that I made out of 2 discs. It goes on my D-250. I have to put 100lbs of front weights on it to keep the front end on the ground when it is lifted. 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #9 Posted January 13, 2019 On 12/27/2018 at 5:02 AM, Daron1965 said: I have been looking at disc harrow attachments for my 312-8. The local stores offer Brinly smooth disc, and Agri Fab notched disc. I plan on using it to disc up my already plowed plots, and then run between rows of the larger plot. Is one better than the other? What do you use, and how does it work? Thank you. Here you go straight from our classifieds... Share this post Link to post Share on other sites
