Goldann520 242 #1 Posted November 6, 2018 (edited) Hey guys, @WVHillbilly520H, @ACman, and all of you I've forgotten. I finally landed another 520h! This one not a 96, so my handle not correct. Sold out all my wh stuff and this came up for $400. Couldn't pass up. This one 946 hrs. Think it's older than my 96 was. Great 48" deck too. Be back with updates later. All 4 hubcaps, original seat. Don't remember the machining on the front axle for the belt clearance on my 96 ? Edited November 6, 2018 by Goldann520 More info 4 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #2 Posted November 6, 2018 My '95 and anniversary both have the belt clearance in the front axle. Share this post Link to post Share on other sites
Vinylguy 4,771 #3 Posted November 6, 2018 A 1990. Nice find Share this post Link to post Share on other sites
Goldann520 242 #4 Posted November 6, 2018 Thanks @Vinylguy, saves me looking it up. @WVHillbilly520H, nice hearing from you again. 90 1st year of swept axle? Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #5 Posted November 6, 2018 9 minutes ago, Goldann520 said: Thanks @Vinylguy, saves me looking it up. @WVHillbilly520H, nice hearing from you again. 90 1st year of swept axle? Yes 88-89 straight axle unless it's a HC. Share this post Link to post Share on other sites
roadapples 6,987 #6 Posted November 6, 2018 Ahhh, what year did they start the shifter on the column... Share this post Link to post Share on other sites
Vinylguy 4,771 #7 Posted November 6, 2018 (edited) 15 minutes ago, roadapples said: Ahhh, what year did they start the shifter on the column... 90 on the 520 I think Edited November 6, 2018 by Vinylguy 1 Share this post Link to post Share on other sites
Goldann520 242 #8 Posted November 7, 2018 Got him running tonight, oh, that onan sound! All 5 gauges work, wow! Thats a 1st. Noticed a drip of fluid under high pressure line under trans. Needs a little electrical work. (No lights and amp gauge not showing proper charge. Between red and yellow on gauge. Any ideas?) @WVHillbilly520H, @Vinylguy. Took forever to get the fuel system primed, no gas in it anywhere. Pto stuck and won't engage. Normal stuff. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,281 #9 Posted November 7, 2018 A good set of wiring diagrams for this tractor Garry 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #10 Posted November 7, 2018 9 hours ago, Goldann520 said: Got him running tonight, oh, that onan sound! All 5 gauges work, wow! Thats a 1st. Noticed a drip of fluid under high pressure line under trans. Needs a little electrical work. (No lights and amp gauge not showing proper charge. Between red and yellow on gauge. Any ideas?) @WVHillbilly520H, @Vinylguy. Took forever to get the fuel system primed, no gas in it anywhere. Pto stuck and won't engage. Normal stuff. The voltage regulator would be my first guess after double checking all electrical plugs/connections... 1 Share this post Link to post Share on other sites
