ebinmaine
Anything special I need to know to disassemble an HH60?
ebinmaine
We're going to take apart the Tecumseh from my Honey's 657 so I can replace the crankshaft.
Any little tricks or tips I need to know about?
squonk
download.jpg.9ae782dce02e6bb1d9a7c938b58093d5.jpg  :occasion-xmas::occasion-xmas::occasion-xmas:  :banana-dreads:                                             :ychain:
  • Haha 2
ebinmaine
by General principle I don't disagree Mike but that's why I need to take this apart in the first place
  • Haha 1
pfrederi
MANUAL explains it all
ebinmaine
Couldn't find the right one. This phone is terrible for searching on.
SylvanLakeWH
While I agree with the basic tools presented:
Handle could be a bit longer...
Usually need more than 3 beverages...
Typically do not dance before, during or after...
:twocents-02cents::ychain:
  • Haha 1
pfrederi
or here  you need to get a better search phone...
ebinmaine
I agree with that wholeheartedly...
But, let me say two things about that.
1, I only just got this phone a few months ago and I'm kind of stuck with it for another year-and-a-half.
2, and most importantly, it's probably not the phone but the operator.
:P
elcamino/wheelhorse
based on my mechanical skills , take it to a machine shop or find an old guy that likes to tinker with motors.
WHNJ701
sell the tecumseh for parts and find a k181
Edited by jabelman
520hC-120
I NEED one and can’t find it :angry-steamingears:
I have an 854 with unoriginal blown engine that I’m doing a complete restoration on
It’s now down to frame with tranny off and engine ready for sandblasting
ebinmaine
Nope.
Low hours on the whole tractor and Trina wants to keep it as it was.
It ran great before I broke the crankshaft.
I'm attempting to install a replacement module for the points so we won't need to remove the flywheel again.
ebinmaine
Well after a few months of delay I'm finally getting back around to replacing the crankshaft in this engine so we can get it put back on Trina's 657.
I've tested the ignition system and determined that the points were oxidized and that was the cause of it failing to run last year after the restoration on the tractor.
I've gone through the manual and it looks like a fairly simple disassembly.
Of course I only have to take apart enough to get the crankshaft out and not the valves or piston I guess.
I'm sure I'll come up with several more questions as I do this but the one that comes up for me immediately is that the manual states the cam and crank gears must match and I understand the logic of that.
Is this to say that I must remove the crank gear from the one that is in the engine and swap it to the replacement? Or is that not really a big deal?
@pfrederi or other Tecumseh folk, what say you?
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case broke a small piece off (about 1” long by 1/4” wide) on one side of the center flange and was repaired with JB Weld.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $325 Or Best Offer - Deck/Blade/Weights/Parts alone are worth that!
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • CeeBee
      By CeeBee
      Good shape. Electric Start. Kept in a shed. Need the space now. Includes Manual. Pickup only.
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Nathan
      By Nathan
      Can anyone help finding year of this tecumseh motor off a 603. I need a carburetor.
    • The Tuul Crib
      By The Tuul Crib
      Here's a crazy question I had to ask anyway. I have an old HH 60 that has no spark. Obviously something with the magneto. There is no way to recharge these correct?  I have cleaned all connections and still no spark any helpful suggestions lmk
      Thanx
