ebinmaine 81,000 #1 Posted September 8, 2018 (edited) I found this the other day in the pile of auction take home stuff. The gentleman that passed away was a professional machinist and did a lot of mechanical repairs and had a full-service machine shop. I gather that it is some kind of a coupler but what is it for? Edited September 8, 2018 by ebinmaine 1 Share this post Link to post Share on other sites
19richie66 17,937 #2 Posted September 8, 2018 We use them to couple engines to pumps. It absorbs some of the vibration between the two and it can be slightly out of alignment and not hurt either of the shafts. 5 3 Share this post Link to post Share on other sites
ebinmaine 81,000 #3 Posted September 8, 2018 Makes sense. Very small shaft diameter for anything that a Kohler would have used. Only 5/8". I wonder what this guy had this thing for?? Share this post Link to post Share on other sites
pfrederi 21,246 #4 Posted September 8, 2018 Probably an electric motor hooked to almost anything. 3 1 Share this post Link to post Share on other sites
ebinmaine 81,000 #5 Posted September 8, 2018 6 minutes ago, pfrederi said: Probably an electric motor hooked to almost anything. Yepp. I'll bet that's it. He had a plethora of electric motors too. Share this post Link to post Share on other sites
c-series don 12,571 #6 Posted September 8, 2018 That is the EXACT coupler I needed to fix my log splitter. Just bought one a couple of months ago! 4 1 Share this post Link to post Share on other sites
ebinmaine 81,000 #7 Posted September 8, 2018 4 minutes ago, c-series don said: That is the EXACT coupler I needed to fix my log splitter. Just bought one a couple of months ago! Well now you know where to find one next time... Need a spare? 2 Share this post Link to post Share on other sites
peter lena 10,098 #8 Posted September 8, 2018 we used to use them on the poly dextrose flow system, and the hopp 2 miller beer concentrate ,typically drive the positive gear pumps, the poly was like thick honey and was very susceptible to blowing out seals over any pressure and cooling issue. the lovjoy coupling was simple and dependable for making a pump swap easier, base was jigged to precisely lock in pump, making alignment a non issue , for a rebuilt spare to install. not used on larger pumps or gear drives, but they were definitely the way to go in a pump staging room with dozens of mountings and matching flow piping. old school , pete 3 Share this post Link to post Share on other sites
oliver2-44 11,787 #9 Posted September 8, 2018 1 hour ago, 19richie66 said: We use them to couple engines to pumps. It absorbs some of the vibration between the two and it can be slightly out of alignment and not hurt either of the shafts. Yep, used them at the hydro plants to couple electric motors to bearing lube oil pumps 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #10 Posted September 8, 2018 Use them at the factory I work at also when they didn't have the correct I.D. I would machine (bore out and rebroach) to size needed some times just one half as new motors would come in shaft "upsized" , they sell them at TSC as well. 2 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #11 Posted September 8, 2018 I have 4 oil skimmers (at work) that are electric motor driven and the "Love-Joy" connects to the gear box! 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #12 Posted September 8, 2018 @ebinmaine You better quit going to auctions or you will need another shed for your whatisits. 5 Share this post Link to post Share on other sites
ebinmaine 81,000 #13 Posted September 8, 2018 27 minutes ago, elcamino/wheelhorse said: @ebinmaine You better quit going to auctions or you will need another shed for your whatisits. HAHAHAHAHHAHAHAHA !!!! I have no problem with that. 1 Share this post Link to post Share on other sites
squonk 48,250 #14 Posted September 8, 2018 30 minutes ago, elcamino/wheelhorse said: @ebinmaine You better quit going to auctions or you will need another shed for your whatisits. Speaking from expeirence? Yup Lovejoy connector. Needed one half of one when replacing a bearing in a Hobart dish machine. I call up the supply house and ask for a 1/2" Lovejoy connector. They had no clue. 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,688 #15 Posted September 8, 2018 Yep, a shaft coupling that is very forgiving to misalignment and vibration. Easy inexpensive replacement of the rubber spider by sliding the halves back. 1 Share this post Link to post Share on other sites
ebinmaine 81,000 #16 Posted September 8, 2018 If any of you can use it it's yours for the cost of the freight. It's not something I'm ever going to use. Share this post Link to post Share on other sites
Sarge 3,473 #17 Posted September 9, 2018 That style of coupling was my original idea for fixing the weak point in the D series drive system - the Sundstrand uses an odd 17 spline shaft that is very small and the original coupling was cast iron. Over time, they wear, and when it lets go the whole thing is junk. I had talked to LJ Fluid power about having their shafts made with a more common keyed bore to use those very Lovejoy couplings versus the stock, NLA cast iron parts and rubber puck - but they want to stick to stock for some reason. A lot of D's get parted/scrapped because of the factory weak point - I'd like to figure out a solution that has replaceable parts. Sarge 1 Share this post Link to post Share on other sites
oliver2-44 11,787 #18 Posted September 9, 2018 @ebinmaine What size is the shaft hole in that coupling. I’m slowly acquiring parts for a tractor driven Ice cream maker. I need a way to “easily” couple and uncouple it to a reduction drive off the tractor Share this post Link to post Share on other sites
peter lena 10,098 #19 Posted September 9, 2018 how about a Falk design t flex coupling ? https://www.google.com/search?q=pump+coupling+spring+grid&tbm=isch&tbo=u&source=univ&sa=X&ved=2ahUKEwiEtcLq963dAhWHY98KHUfqDRkQsAR6BAgFEAE&biw=1024&bih=662#imgrc=zjac4y39zB2yNM:&spf=1536496699121 , is there a picture or more detail of your issue ? we used dozens of different coupling types to work with repetitive failures, sounds like the thrust impact, could be lessened ,with the spring grid. pete Share this post Link to post Share on other sites
ebinmaine 81,000 #20 Posted September 9, 2018 18 minutes ago, oliver2-44 said: @ebinmaine What size is the shaft hole in that coupling. I’m slowly acquiring parts for a tractor driven Ice cream maker. I need a way to “easily” couple and uncouple it to a reduction drive off the tractor In the picture that shows the end you can see it stamped .625. I haven't physically measured this piece but according to online listings that means it should have a 5/8 inch bore. Share this post Link to post Share on other sites
Daron1965 644 #21 Posted September 9, 2018 tractor driven Ice cream maker. I would like to be invited to the ice cream party. 1 Share this post Link to post Share on other sites
