pazephyr
Deck attachment, 520H Wheelhorse
pazephyr
Greetings, First time here. I don't know many technical terms. I'm a farm girl so bear with me.  I purchased a used 520 H wheelhorse in 1998 (it had 200 hundred hours on it so it much be a 96 or 97) and for the most part have kept it running by just practical maintenance.  i took it in for general going over and tires/ seals etc.  1) I have a 42 inch deck. When I lower the deck to its lowest level it all but shaves the ground.  I noticed the lift bar has 2 small holes and the oval slider hole.  The lift chain is in the small hole nearest the rear wheels. Is this correct?  My belt barely clears the deck mount.  I have tried to research all this and can't find a helpful site. #2) My throttle will not stay put, l have to hold it up or it goes back to crawl.  I see all the parts but need an easy fix. Can you guide me or give to the help i need. I tried Toro site and Y tube but I'm just not very technical. thank you. Pazephyr
varosd
The throttle issue is common
you will need to get behind the “Dash” plate. The rivet loosens up
i removed the throttle knob with a claw back a hammer and 2x4 wood. Unscrew the throttle from the dash. I just squeezed the rivet with channel locks. Some preen (beat on it) with a hammer. Some drill out the riveting and put a nut and bolt. Better than the usual bungee cord throttle engineering you see.  Welcome to RS
  • Thanks 1
lynnmor
Here is the owners manual, it might not be the exact model you have but the adjustments are the same:  Manual
Put a small screw thru the throttle rivet with a locknut on the opposite side.  Tighten till the throttle holds.
  • Thanks 1
Cee245
Hi @pazephyr,
If you post pictures of model numbers or general pictures then we are more able to help you out.
Welcome to red square!
Ed Kennell
The lift chain should not be connected to the deck.   It should be connected to the lift bar as shown in the manual and these pictures.
The lift bar pin is then inserted into the slot in the deck carriage bar.
IMG_0017.JPG.fe7fb13cf565ba3ff4fb2b196634f976.JPGIMG_0021.JPG.9a2f47790b864fd5a6fb282283eb664a.JPGIMG_0024.JPG.9d1302ad4d5c702a35151dce9b5c5684.JPGIMG_0025.JPG.e1e32f2c45fa712211f2b92df557a977.JPG
BTW,  :text-welcomeconfetti: to the :rs:.   Hope this helps.
gwest_ca
Lift linkage
https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/73520-520-h-toro-520-h-garden-tractor-sn-5900001-5900177-1995/hydrostatic-lift-linkage-assembly/
Mower deck may be a different model but will attach the same. Click on the pictures
Garry
pazephyr
Wow, thank you all!!  Very helpful!...I will see what i can do!
  • Similar Content
    • tpsnowbanks
      By tpsnowbanks
      My double pulley deck drive spindle seized up and shredded the shaft.
      Looking for a replacement assembly.
      My rig is 310-8, 1986ish.
      The deck is 36" rear discharge. Similar vintage but has no identifying tags.
      The drive spindle on this one is front and center, not the older version with the tall spindle near the back.
    • Jayzauto
      By Jayzauto
      Toro - WheelHorse Deck Chutes available.  Fit 42” & 48” Side Discharge Decks.  These are New & Restoration Quality.  I have 2 available.  $50ea/BRO
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
