Pullstart
Shop project...
Pullstart
6 hours ago, wallfish said:
We can see your breath in the video. Do we need to revisit that used oil burner project? :ychain:
I spend so little time at a time in the shop, I haven’t fired it once this season.  I don’t want to get it all hot and bothered and try to shut it down on schedule or in a rush.  Perks of afternoon wrestling coaching :lol:
  • Haha 1
Pullstart
@adsm08 I honestly don’t see the problem you’re seeing.  This is an amazing slush box!
In theory, wide open throttle past 85 mph from a stand still launch might find itself looking for answers on what to do next… but that’s just in theory…
Also, I made the swap and saved $2,700 over the intended repairs of the 6 speed.
Pullstart
adsm08
Hey, if it works and holds up great. I just know the issues I see with the Ford 10 speeds, and I keep reading about how the Chevy ones end up being worse and nobody can get the parts.
I do agree that when they work right they are great transmissions. It's when they don't that its a problem. There is a 3-clutch drum at the core of the unit, made of aluminum, with a sleeve pressed into the middle to seal the paths through the main shaft, and nothing but an interference fit to keep it in place. The heat cycles eventually let the sleeve walk and it will partially block the clutch apply passages to those three clutches. Ford redesigned their drum to put a land in theirs to keep the sleeve in place. From everything I've read Chevy threw their hands in the air and put everything pertaining to these transmissions on back-order.
Pullstart
13 hours ago, adsm08 said:
The heat cycles
 @Chris T turned me on to the fact that most of these transmissions have thermostats in them now, warming the fluid up to 200+ by design.  I grabbed an $18 bypass plug from Amazon and have not seen more than 155 degrees after some hard driving and launches.  Let’s hope that the heat cycles stay lower than normal and keep all those parts in place 🤞
adsm08
Let's hope.
The Ford version does not have a thermostat, or a bypass, unless you have the tow package. Most of them use heat exchangers instead of true coolers, and run at the same temp as the engine, between 180 and 212.
Pullstart
11 hours ago, adsm08 said:
Let's hope.
The exterior 30 row cooler and AN fittings were cheap enough together, it would be a wonderful upgrade for anyone.  The Suburban vs a Truck issue was the fact that the whole bumper cover and grill need to be removed.  It’s not a terrible job, but most folks wouldn’t want to go that far I fear.
Pullstart
Update on the 10 speed.  I bit the bullet and spent $400 on HP tuners credits to be able to tune this vehicle.  It took $200 for the ECU and $200 for the TCM.  Unfortunately, I’ve spent the $200 for the ECU before so a buddy could tune the engine.  The sad part is that I can’t use his credits, because it’s locked to the vehicle and the tuning device.  His tuning device is 40 minutes away and not worth the time to go back and forth, try this and that, change, etc.  It’s a process to refine the tune and may take days or even weeks.
With all that said, final gearing between the 6 and 10 speeds say that once I hit 8th gear, it’s like the old 6th gear.  9 and 10 are additional overdrives and though the engine has an additional 200+ hp, it often feels like it’s lugging along at rural highway speeds.  At wide open throttle, it sometimes feels like the rpm shift point settings are fighting with the speed based shift point settings and it gets stuck thinking what’s right.
Yesterday, I tuned in different line pressures, torque converter lockup and tightness (adjustable stall based on computer thoughts!?!?), and torque management to refine the way the engine and transmission communicate.
Today I spread out the shift points to make it wind up a bit more before shifting.  She liked yesterday.  She doesn’t like today as much.  Dully noted.
Pullstart
This was a wild one.  2009 Chevy 2500 HD, Duramax/Allison/4x4.
What came first?  Chicken or egg?  Driveshaft or transfercase?  Back in November or December, this drivetrain left the chat at interstate speed.  Bang!  POW!  To the moon Alice! The driveshaft was never found, the transfercase blew into three pieces.  The impact broke the transmission bellhousing and the rear engine plate as well.  There was carnage everywhere!  You’d think that state boy would have come to check us out after sitting a couple hours on the side of the road, but it must have been nap time.  😴
  • Sad 3
Pullstart
Carnage galore, indeed.  This back engine plate is the turbo oil drain, rear main seal, and also a coolant passage from left to right side of the engine and through the engine oil cooler.  It’s busy.
To remove the engine plate, we needed to pull the lower oil pan, drain coolant and oil of course, the left side turbo up pipe, a coolant line and elbow, lots of gaskets and potential leak points.  There’s a rear cover installation kit, and we utilized it.
  • Sad 3
Pullstart
The amount of oil on the road and under the truck confirms the case was full.  The driveshaft yoke was still in the transfercase output housing, the remnants of the u-joint still in the rear axle.  There was some signs of impact on the skid plates up front, but the insurance adjuster denied any claim.  We can’t confirm nor deny what happened.
I didn’t charge any labor, he’s my bud.  I’m proud of his accomplishments, he’s moving into his new first house at the end of the month, and he works hard.
Repair components, every vehicular fluid:  $3,500
3” lift kit for emotional support and extra tire clearance: $500
ER visit to remove debris from eye rather than wear safety glasses (I tried telling him!): $150
20 pack of safety glasses: $20
Lessons learned, memories made, time in the shop: priceless.
Alignment scheduled for Friday morning, then the boy will have his truck back.
  • Sad 2
Pullstart
Time to clean up shop for plow day!  Just kidding, I have tons of work to get done before then!  :lol:
  • Haha 3
squonk
On 2/5/2026 at 7:01 PM, Beap52 said:
Well Kevin, quite the project you've got going.  Certainly not one I would take on--for lack of tools and knowledge.  I'm looking forward to the remaining videos.
Having just replaced most of the seals in my 92 pickup, We decided to replace the flexplate and that became a challenge.   Ultimately, we had our local auto parts store order four flexplates and non of them exactly replaced the original.  Chevrolet dealership said they might be able to get one but it would be four hundred dollars and didn't know how long to get it therefore,  "order from parts store".  My original flexplate had six holes all of the replacements had six holes but three of the holes were offset apparently so they could be used for different applications.  The dealership said three  bolts were all that are needed.
I laid the new and old flex plates on the top of my cast iron table saw top using shims to represent the flexplates being bolted to the back of the engine and there was a 50 thousands difference so we ordered a flexplate shim from the flexplate manufacturer.   The rookies at the auto parts store didn't realize there was such a thing as a flexplate shim.  The cheap flexplates were $48 the shim $35 dollars.  I ended up using a heavy duty flexplate an it was three times the price of the cheaper ones.
We weren't swapping parts just replacing the flexplate.  I am amazed that the parts seem to be working out so well for you.
By the way, I kind of puckered up when you grabbed ahold of that transfer case over your head.   Trust me, most of us won't be doing that at 73 years of age.
I remember the days of cast iron transfer cases and wonky transmission jacks!
  • Like 4
Pullstart
On 4/6/2026 at 10:57 PM, Streetrodchev said:
what is the casting number on the driver side bell housing area of the block?
Jeff asked some questions about this engine I’ve got in the shop to do some cleaning up on.
Is this a Dart block?
ebinmaine
I'm no authority whatsoever but that sure does look high performance. I like it.
Achto
Posted (edited)
Now come on Kevin !!! :angry-tappingfoot: Not only does it look like a Chevy engine, it says Chevrolet right on it. There is no way that engine came out of a Dodge Dart. :lol:
Edited by Achto
  • Haha 5
Streetrodchev
That could be an aftermarket block.
Easton Rich
That is a Dart block I believe. Great blocks, but quite pricey. I haven't read very far back but that looks to be a pretty stout small block.
19richie66
@Pullstart I need that for my truck. :handgestures-thumbupright:
  • Haha 2
953 nut
Dan, :confusion-confused:   Dan, :confusion-shrug:   Dan!   :hide:    I was going to use that line but even a guy like me has higher standards than that.     :ychain:
  • Haha 3
Pullstart
Plow day complete, pool shed complete, waiting on fence materials, it’s a good day to work on an engine!
ARP head studs swapped in place of bolts, torqued to 80 ft lbs rather than not close to 65, blue loctite on block side threads.  New rear main seal and oil pan gasket, fresh paint cooking next to the oil fire.
Once it gets set up a bit, I’ll roll it over and finish assembling the top end
  • Like 5
Pullstart
  • Heart 1
Pullstart
On 7/10/2018 at 8:39 PM, Pullstart said:
A little fab project I picked up this week, this belongs to a Yukon Gear and Axle sales rep in the area, doing some prep for his next Colorado trip in a couple weeks...  Should fund another Wheel Horse project!
I saw this rig a week ago.  Funny running into it, his daughter wrestles like mine.
Pullstart
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
