Pullstart
Shop project...
Pullstart
6 hours ago, wallfish said:
We can see your breath in the video. Do we need to revisit that used oil burner project? :ychain:
I spend so little time at a time in the shop, I haven’t fired it once this season.  I don’t want to get it all hot and bothered and try to shut it down on schedule or in a rush.  Perks of afternoon wrestling coaching :lol:
  • Haha 1
Pullstart
@adsm08 I honestly don’t see the problem you’re seeing.  This is an amazing slush box!
In theory, wide open throttle past 85 mph from a stand still launch might find itself looking for answers on what to do next… but that’s just in theory…
Also, I made the swap and saved $2,700 over the intended repairs of the 6 speed.
Pullstart
adsm08
Hey, if it works and holds up great. I just know the issues I see with the Ford 10 speeds, and I keep reading about how the Chevy ones end up being worse and nobody can get the parts.
I do agree that when they work right they are great transmissions. It's when they don't that its a problem. There is a 3-clutch drum at the core of the unit, made of aluminum, with a sleeve pressed into the middle to seal the paths through the main shaft, and nothing but an interference fit to keep it in place. The heat cycles eventually let the sleeve walk and it will partially block the clutch apply passages to those three clutches. Ford redesigned their drum to put a land in theirs to keep the sleeve in place. From everything I've read Chevy threw their hands in the air and put everything pertaining to these transmissions on back-order.
Pullstart
13 hours ago, adsm08 said:
The heat cycles
 @Chris T turned me on to the fact that most of these transmissions have thermostats in them now, warming the fluid up to 200+ by design.  I grabbed an $18 bypass plug from Amazon and have not seen more than 155 degrees after some hard driving and launches.  Let’s hope that the heat cycles stay lower than normal and keep all those parts in place 🤞
adsm08
Let's hope.
The Ford version does not have a thermostat, or a bypass, unless you have the tow package. Most of them use heat exchangers instead of true coolers, and run at the same temp as the engine, between 180 and 212.
Pullstart
11 hours ago, adsm08 said:
Let's hope.
The exterior 30 row cooler and AN fittings were cheap enough together, it would be a wonderful upgrade for anyone.  The Suburban vs a Truck issue was the fact that the whole bumper cover and grill need to be removed.  It’s not a terrible job, but most folks wouldn’t want to go that far I fear.
  • Similar Content
    • DennisThornton
      By DennisThornton
      1947 Empire (Jeep) Tractor
      The Empire tractor consisted of military power components from World War II-era jeeps. It had a 4-cylinder, 40 hp Willys-Overland engine, a Model T-84 Spicer 3-speed transmission, Spicer transfer case with high and low speeds, Willys rear end, steering column and gearbox. It also had PTO, individual clutch-type rear brakes with a stop provided for parking and a rear belt pulley. The fuel tank and an Empire-style seat were mounted on a large operator's platform (made from Navy ship decking). Its simple, basic gauges (ammeter, oil pressure and temperature), ignition switch and starter button also came from the jeep. The Empire tractor was originally made for exportation in the Lend-Lease Program after World War II.
      If I had to mention a couple of things that made the Empire Tractor really unique, one would be the straight bar hitch that pulled from under the center of the tractor (patented) thus making an overturn nearly impossible. The other selling point was, of course, the Willys engine and drive train made famous in the Jeep during World War II. The Empire was a well equipped tractor, very reliable and versatile with its wide range of speeds. Today this tractor draws a lot of attention at shows and is very sought after by collectors commanding higher than average prices.
      $5k
    • CRE1992
      By CRE1992
      Well fellas I decided to buy a jeep wrangler as a new toy. I have always been into the off-roading scene since I was a kid. I always loved trucks, jeeps, atvs. Recently a friend of mine traded his mustang for a lifted wrangler and its a blast to go off-roading in or wheeling as they like to put it.
      I couldn't help myself and wanted to join in so I bought a 1993 with 153,000 miles on it with a ton of add ons for a great price. It has a 5.5" suspension lift, a 2' body lift and rides on 35" tires. She has 4.56 gears which are awesome for crawling, 4wd low range and 1st gear and you don't even have to touch the gas pedal. It is a 4.0L 6 cylinder engine back by a 5 speed manual trans. The rear drive shaft is a custom cv drive shaft with a slip yoke eliminator. The rear axle is a ford 8.8 limited slip with disc brakes out of a ford explorer. The frame is perfect not a spec of rust and was coated with POR-15.
      She does have her fair share of issues but I am working on getting those straightened out! I just had the front drive shaft rebuilt and balanced. I ordered all new extremely heavy duty shocks. I need to fabricate 2 custom rear shock mounts as the "custom" ones that were on it broke off lol. She needs 2 new leaf spring packs in the rear. Some body work. A good cleaning after this weekend. Some fender flares. Etc!
      If anyone has any good oh crap off-roading or wheeling stories with their jeeps or pictures please share. After this past Sundays experience I could probably top them lol.
      I hope you enjoy the pics and the video my jeep was the main attraction. (I did not edit the video a friend did, so turn down the volume or the music might scare you)
      LINK FOR VIDEO: http://s1201.photobucket.com/user/silveradostud/media/Jeep%20Fun/IMG_31371_zps0e82da88.mp4.html
