ebinmaine
Can I just heat shrink this wire to save it?
ebinmaine
Look at the used to be red wire on the left and you'll see a bunch of frayed rope looking stuff. I'm wondering if I can just snap the end off and slide a piece of heat shrink down over it and then re-terminal the end.
Can't see why I can't do that. Just wanted to run it by you folks....
Cvans
If it were me I'd try it but find some way to keep it away from those fins.
McGrew
It might work for for a while, but those frayed wires will increase the resistance of that wire, and will heat up at that point.  If it were mine, and replacing the entire wire is not an option, I would cut out the bad section and solder in a new section.
Racinbob
It would probably be fine but I'd suggest replacing the wire, The frayed look is just the insulation but you do need to get it away from the heat. Ya gotta cut the wire to get the shrink wrap on it so why not just replace it? :)
ebinmaine
Yeah, sure will.
That's the mag wire so I don't know where it should sit but I'll double triple check it.
I've got crimping down to a science and always use good quality connectors with heat shrink ends.
I haven't tried to solder a wire.
Maybe a bout time I learned...
I'll take another look at it sometime.
I'm not sure there's enough wire out to cut/replace without removing the flywheel which I do NOT want to do.
But... Valid point... That piece does need to go.
Sarge
I mostly buy non-insulated terminals and dual wall shrink boot w/adhesive - that is how I've done 95% of the wiring jobs the last 30yrs or so. Much simpler to crimp a wire, fire up the mini butane torch and use some good quality rosin core solder to flow out the connection - plus, it prevents corrosion later in the copper joint. Learned the hard working on big rigs and trailers that non-soldered connections will fail in a fairly short time, regardless of shrink boot or none, if moisture can get to the connection point, it's over. While hot, I also dip the connector in a tub of NoOx, it will flow into and protect any type of terminal used on our equipment. I've had the connection tabs rot clean off of lights but the terminal part will not fail - the stuff really makes a difference. You can use the black dielectric grease from auto/hardware stores, it's not quite as good but NoOx is very tough to find/buy.
Sarge
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $300 Or Best Offer.
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • wh315-8
      By wh315-8
      My show tractors for October Festivals.
      RJ59, 1045, 657 w/sickle bar, 10HP and D200. Just love the attention and hearing the stories of grandpa or growing up had one. Always can see the joy these Horses bring to the spectators. Than telling them the WH history story along with Speedex story always intrigues them.
      Than of course there is always someone that needs to get one out of the way.
      Last year it was the 1045 and the PO was so excited to learn I got her running and been mowing my grass all summer. Of course I had to let him drive her around.
      This year it’s a 702 I think I getting this week.
      So many were engrossed by the Sickle Bar never knowing such was available on garden tractors.
    • ebinmaine
      By ebinmaine
      A HUGE thank you to Tony @Docwheelhorse for settin' me up here.
      The generosity of some of our members never ceases to amaze me.
      This here is another 1974 C160, but with the rare Tecumseh HH/OH160 OHV engine. Made one year only.
      It's rough. Very much in need of a full disassembly and restoration.
      When it came here it was missing one tie rod and the other was broken off one end.
      Today I popped used tie rods on and Trina used her 867 to drag it from the drive to the shed.
      The engine wouldn't move.
      Tin was near chock full of skeletal mouseseses and their house.
      Cleaned that out and the engine spins freely now.
      So progress has been made.
      It'll be a good long while before we get to this one but I just couldn't turn it down considering the rarity.
    • Nathan
      By Nathan
      Can anyone help finding year of this tecumseh motor off a 603. I need a carburetor.
    • ebinmaine
      By ebinmaine
      We're going to take apart the Tecumseh from my Honey's 657 so I can replace the crankshaft.
      Any little tricks or tips I need to know about?
