ebinmaine 75,781 #1 Posted June 12, 2018 On my honey's tractor is the old style ignition switch that sends All the battery current through itself. It's a bit dark colored and I'm Not a fan of those so I'd like to replace it and change to a switch with a separate solenoid. Is there a wiring schematic that shows how? Thanks! Share this post Link to post Share on other sites
rjg854 12,636 #2 Posted June 12, 2018 I'm sure 953nut will be along, he seems to have all those diagrams. I may even have one I saved for this same purpose. Share this post Link to post Share on other sites
rjg854 12,636 #3 Posted June 12, 2018 I'm not positive that's the right diagram, I seem to remember the one Richard sent me had a 5 pin switch. Share this post Link to post Share on other sites
953 nut 63,075 #4 Posted June 12, 2018 This is basically the same as the one @rjg854 gave you. Share this post Link to post Share on other sites
pfrederi 19,278 #5 Posted June 12, 2018 I am pretty sure the Techy in the 657 is a Magneto system. The above diagrams will fry the magneto. If the switch works just do a little rewiring. Use the existing switch to control the solenoid. Run a heavy wire from Battery + to one solenoid heavy terminal and then a heavy wire from the second solenoid heavy terminal to the starter motor. Then a 14/16 ga wire from the Ignition switch S terminal to the small solenoid terminal. 1 Share this post Link to post Share on other sites
ebinmaine 75,781 #6 Posted June 12, 2018 @rjg854 and @953 nut thank you for the responses. I should have been more clear. My apologies. @pfrederi is correct that I do have a Tecumseh in this tractor. Thank you Paul for that. This switch does work so we'll just keep using it and wire as you stated. Share this post Link to post Share on other sites
953 nut 63,075 #7 Posted June 12, 2018 3 hours ago, ebinmaine said: @rjg854 and @953 nut thank you for the responses. I should have been more clear. My apologies. @pfrederi is correct that I do have a Tecumseh in this tractor. Thank you Paul for that. This switch does work so we'll just keep using it and wire as you stated. I guess we fell into this old trap. Share this post Link to post Share on other sites
ebinmaine 75,781 #8 Posted June 12, 2018 1 minute ago, 953 nut said: I guess we fell into this old trap. Myself included. If the techy croaks it'll get a Kohler popped in. Share this post Link to post Share on other sites
953 nut 63,075 #9 Posted June 12, 2018 I just posted all three basic wiring diagrams, The first one is your system with a solenoid. As Paul @pfrederi said , the old switch will work fine or you can go to the new 5 post if you wish. Share this post Link to post Share on other sites
ebinmaine 75,781 #10 Posted June 12, 2018 1 minute ago, 953 nut said: I just posted all three basic wiring diagrams, The first one is your system with a solenoid. As Paul @pfrederi said , the old switch will work fine or you can go to the new 5 post if you wish. Thank you sir! Very much appreciated! Share this post Link to post Share on other sites
