Seacrestbf
B 80
Seacrestbf
Hello
When we try to push the machine with out it running or in gear. The rear wheels are locking up. Is there a release valve? I have to push it from the storage area to the shop, the motor is rapping.
Thank you
  • Like 4
Ed Kennell
There is no release valve in a gear drive transmission.     Just make sure both the hi/lo and the tranny shifters are in neutral.   Also check the brake drum to be sure the band is releasing.
  • Like 5
KC9KAS
@Seacrestbf That is a very nice looking B-80!
953 nut
:text-yeahthat:      As Ed said, could have been the parking brake. Do the brake adjustment as stated in the manual, page 16.
Seacrestbf
If you push it slow and it stops after a foot or 2, then wait, you can roll it again, then wait, then roll a
few more feet. ??  Seems like it builds then realses pressure??
ebinmaine
sort of sounds like it's stuck in a gear....
fiddle around with both shifters.
Might be building engine compression, then releasing it... ?
Ed Kennell
Yes, like EB says, it must be stuck in gear.   Did you place the HI/LO shifter in neutral?   Does it roll freely when you depress the clutch?
Edited by Ed Kennell
WHX??
Disconnect the drive belt and brake and see if you have the same symptoms. This pretty much narrows it down to the tranny or not. Does the tranny shift into all gears easily including hi-low range? Next step will be to pull the shifter and look for Mr H but we'll worry later about that bridge.
One thing fer sure that is a nice lookin B :handgestures-thumbupright:
WHX??
Second thought guy pull the shifter first and look for neutral... maybe save the hassle of pulling belt guards.
Seacrestbf
Thank you Everyone for you comments.
stevasaurus
Nice looking B-80.  It does not mater if it is in hi or low range, if the other shifter is in neutral and the brake is released it should roll.  My guess is that you have some ice in the transmission case if it has set all winter.  Use a 100w light bulb, hot air drier, a salamander heater, space heater etc.  It should not take too much now that spring is here.  :)
   If it is ice, you will want to drain and flush the trans.  :occasion-xmas:
   Also, there is no way you are stuck between gears.  Being an 8 speed, you have the newer shift rails with the stop in the detente spring that only lets you be in one gear at a time.  Even if you had a bad differential, (pinions, axle gears), you would not be able to push it 2 feet over and over after stopping.  Almost has to be ice.  Try thawing it out and let us know.  :)
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
