Similar Content
By CasualObserver
Owners manual for the two cylinder snowmobile engines.
12 pages 1.38MB
1970 399 Safari snowmobile model 9-0041 - 2-cylinder
1970 440 Safari snowmobile model 9-0051 - 2-cylinder
1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
By CasualObserver
Owners manual for the Single cylinder snowmobile engines.
12 pages 1.33MB
1970 295 Safari snowmobile model 9-0011 - 1-cylinder
1970 309 Safari snowmobile model 9-0021 - 1-cylinder
1970 309W Safari snowmobile model 9-0061 - 1-cylinder
1970 355 Safari snowmobile model 9-0031 - 1-cylinder
1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
By Rick3478
For Sale NOS M12S Short Block, still in the original box. I bought it pre-emptively when Kohler was phasing out the Magnums. Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap. Neither of those things happened, the darn things just keep running.
Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake. Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
And it's heavy, so it's not practical for me to ship. Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
Asking $800 or might consider trade for a good center mount grader blade.
By mcfarmall
Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams. A starter, some new gaskets, and miscellaneous parts. New drive belt and all the belt idler assemblies. Engine runs but smokes. Great restoration candidate or a spare engine for you pullers out there. Call, text or email for a private showing. No offers considered unless made in person. Buyer responsible for transportation. Many more pictures to send to interested persons.
By t_furl43
A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
