classiccat
1981 Wheel Horse C85
Sparky
Very nice redo of your C85!
  Makes me want to do-up my C105...just can’t bear to think of the looooong downtime Ill have if I strip er down.
Jim H
On 6/25/2018 at 7:10 AM, classiccat said:
Hi Jim H, welcome to Red Square!
I assume you mean a rebuild kit for the K181.  I haven't actually done a full tear-down of the engine (only the upper half).  I ordered all gaskets/hardware piece-by-piece from wherever I could find it (amazon, fleabay, partstree, etc.).  I'm a little picky when it comes to head gaskets... make sure they have a compression ring.  The 1st one (OEM!) didn't have it.  The Stens one (465-310) I ordered did...go figure!
 It already has a 0.030" piston in it.  Fortunately it only smokes at start-up...probably due in large part from me using 5W30 syn.
Jim H
Late on a reply - I had the engine rebuilt by a mechanic here in GA. Took him forever because he wouldn't use any parts he didn't check out and order specifically. Good but he left the tractor outside and I had never left it in the weather so now I am probably going to have to tear it apart and paint it. I am looking for some information on the clutch though. Have you replaced a clutch or did a new drive belt clear up issues? Mine is squeaking when i start the tractor but put a bit of pressure on the pedal and it stops. Just resting my foot on the pedal is enough to stop the squeak...Thoughts?
  • Sad 1
classiccat
That’s too bad about your tractor Jim.
Back on post 149, another member recommended a fix for the noise / rattle I had when I posted a video a few replies back;  swapping out the clutch pulley cleaned up the noise.  I replaced the belt when I 1st bought the tractor... smoothed out the shifting ALOT!
ebinmaine
That was my first thought as well.
Remove and inspect the pulley's bearing.
Any looseness... Replace it.
If it's just dry, lube it.
Mikey the Monkey
@classiccat hows that beautiful c-85 doing? and when will you be doing another fantastic resto for our enjoyment and viewing pleasure?
classiccat
Thank you for the kind words Mikey!
The old C85 is tucked away for the winter...winterized & protected in a dry shed.  I do have to finish restoring the old saddle I purchased from a member... Vinyl:Gorgeous!(supple like leather) however the seat-pan: not-so-much.
The minute I finished this tractor project last year, I jumped into restoring my old boat ('75 Starcraft SuperSport) which I plan to complete this spring (mid-april).
Once that's done I'll probably take a resto-sabbatical but would love another tractor project.
I'd like to do an old Sundstrand hydro for mowing (something like a 1276/1277 or even a C161)...tear-down/rebuild/repair but preserve the patina. :thumbs:
Edited by classiccat
Pullstart
We’d love to see a resto thread on that Starcraft in the non-tractor discussion!
classiccat
Thanks Kevin!
I'd probably have to condense the 94 page thread (and dig-up the original images that photobucket is holding hostage) that I have running over on iBoats that was started in 2013. :text-lol:
We had a pretty good pace going however a career change / relocation kicked my legs out for a few years.
  • Similar Content
    • CS-17
      By CS-17
      Sold!!!
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • PWL216
      By PWL216
      I took off the drive belt today and brought it to Tractor Supply, measured it there and it was 1/2” x 81”. It’s old and stretched out so I bought an 80”. It went on fine but the tractor isn’t shifting into gear properly. Looking here and on the web, it seems the correct part number is 7473 and the size is 5/8”x82”. Is that correct? Maybe the PO had used the wrong size?
    • D_Mac
      By D_Mac
      So last fall I got this Dynamark riding mower for free. Engine ran but when you stepped on the clutch/brake it wouldn't disengage. Looking at it I noticed it was a new drive belt. I figured PO got the wrong belt so I looked up what I thought would be the correct belt and ordered it. When it came I removed the belt that was on it and it looked to be the exact same size as the new one. Put new one on and same thing. That was an 82 inch belt. So I looked again and saw that a similar model had an 85 inch belt so I ordered one of those..... close but no cigar ! Now I ordered an 86 inch and are waiting for it. In the mean time I noticed water had gotten into the gas tank. The gas cap was the style with a gage but the bubble is busted off. Since the cap goes through the hood on top water leaks in. I need a new cap but having the same issues finding correct one. I don't need one with a gauge just one the screws on tight. Any help works be appreciated as I am finding multiple part numbers.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim!  Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Okay engine Guru's, newbie needs some help! Rebuilding older 8 horse and I am new to small engines. I have rebuilt numerous car/truck engines but never a kohler k. I have researched all available videos and really appreciate the small block tutorial by Prondzy. I am at reassembly stage, so my question is, related to timing marks. I have camshaft with centrifical advance which has a groove or line on spacer that engages pawls. does this groove line up with pointed part of casting on inner rim of gear? Also, there is a groove on opposite side of camshaft gear that I believe should align with pointed mark on casting of crankshaft. See attached pictures. Thanks for any help. Just want to be sure!
