classiccat
1981 Wheel Horse C85
classiccat
54 minutes ago, ebinmaine said:
Trina and I have done this on all our Horses and will add them to every other one we build.  :greetings-clappingyellow:
Doesn't help you now :P but I've found I need to remove that set screw on mine while installing the closest stud bolt.
Keep up the good work!!
Thanks Eric!
i had to remove it on one side only... cleared the other by the skin of its parkerized coating :lol:
  • Haha 2
classiccat
3/16 angle oughta hold my saddle in place.
Ignore my bubblegum welds for a moment and notice the right side is about 1/4” shorter to clear the swinging clutch switch tab.
Edited by classiccat
  • Excellent 3
classiccat
The short list is shrinking!
The body is installed and I was able to hook-up the brake linkage.
For the springs; I wanted to keep shiny, I addressed the rust and old paint with wire wheel, tumbler and evaporust...and instead of parkerizing, I sprayed with a coat of Amsoil MP (metal protectant).
Front wheels and motor mount.
Motor wanting to jump on her refreshed mount (I'm repainting the block this week).
Up Next: rear fender pan and shift plates.
Thanks for stoppin' by!  :greetings-wavingblue:
  • Excellent 2
bds1984
You could always make new shift plates like I did for my C165.
ebinmaine
That's puurrttyy
classiccat
We're almost finished with the engine restoration...
I stripped and repainted the block (wasn't a fan of the flat/satin engine paint...nor did I like the paint on the individual components).
paint on the carb, fuel pump and governor components was removed and polished the float bowl.  The governor was treated with Amsoil metal protectant (gold tint)
^^ I'm in the process of repainting the console... some paint edges needed to be feathered.
  • Excellent 4
Mikey the Monkey
youre doing an excellent job. i think i remember this tractor on craigslist last year. so happy you got it and are preserving it
classiccat
Thank you so much MtM!  I credit the previous owner for actually saving her from the scrap pile; he said that it was rotting away outside of a local service station.  His son had fun with it for a few years (racing stripes say it all!).
Here's the original ad:
classiccat
A little update on things around the garage.
some tweaks were made to the Parkerizing system.
57573994286__63D828A5-AC5D-49A9-9B0F-566E1A67A533.JPG.7928474cd7c7f6b4d5c109877816a402.JPG
I'm using a pot with a strainer...makes "retrieval" a cinch.  I've also ditched the white-gas coleman 533 stove for an electric hotplate...much better temperature control.
Lastly, I've gone with  DIY homebrew using a mixture of Klean Strip Metal Prep : Manganese dioxide : distilled water (I think tap water may have ruined my commercial brew).
I followed this guy's recipe to the "T"
classiccat
work on the tractor is progressing.
Solenoid and regulator installed with dedicated grounds.
The PTO limit switch bracket was roached...so I fabbed-up a new one out of flat stock.  Gave it some "texture" on the belt sander then coated with amsoil MP HD.  DVM to verify that the additional thickness didn't put the switch too far from the actuator.
  • Excellent 3
classiccat
After alot of JBWeld (extra holes, rust pits, etc.) & sanding, the hood is ready for lipstick.
flying-hood and flying-tractor face off...hopefully reunited really soon!
  • Excellent 4
Pullstart
Lookin’ good :handgestures-thumbupright:
ebinmaine
:text-yeahthat:
SylvanLakeWH
Love the Blackhoods!!!
looking beautiful!!!
:bow-blue:
classiccat
2 hours ago, ebinmaine said:
:text-yeahthat:
:bow-blue:
Thanks for stopping by the thread and hanging with me on the refresh fellas!
classiccat
Electrical should be about wrapped-up for this bad boy.
All of the connectors were missing but they weren't too hard to find.
The clutch switch came-up in a thread a few weeks back...that helped alot!
The Packard 56 series female terminals (for 14-16 wire) get the double crimp followed by solder
then some marine grade heat-shrink.  The connector came from amazon.
The PTO and ignition switch (and regulator) get the same terminals.  If you go this route, I recommend getting one of these crimp tools as well as a terminal removal tool
We'll tidy-up in here once I run the machine a few times; Initial checks passed w/ flying colors.
  • Excellent 4
classiccat
Hood painting continued this morning.
The inside as well as the outside-red were completed a few days back.
Once taped-off, I scuffed the red overspray then wet-sanded upto 1000g.
And now we finally have a Black Hood :ph34r:
^^^ I need to touch-up the red on those 2 side rails where the frog-tape didn't cover properly.
Thanks for stoppin' by!:greetings-wavingblue:
  • Excellent 5
953 nut
:text-coolphotos:              First class job on the wiring. Having dedicated grounds on a freshly painted tractor is a great idea.      :techie-idea:       . Paint is a very poor conductor of electricity!
Pullstart
That, plus I think I see a fingerprint on your garage door window through the black reflection!  :ychain:  Soooooo shiney!
What a top notch job on the whole tractor!
Mikerodrig27
You are doing a great job so far. That hood looks awesome
peter lena
terrific work on that , and attention to detail , having a  82 , c 85  myself , that  i recently magnum  re powered  i can relate to saving these great tractors. thank you for sharing , pete
classiccat
thanks *nut!   Generally I avoid using the vehicle as a conductor.  Strictly forbidden on aluminum boats.
this is what we drug home:
Thanks man!    Yeah, that rustoleum farm/implement far exceeded my expectations!  I believe it holds more solids...maybe they even snuck in some hardener and/or gloss enhancers.  Time will tell how she holds up!  I originally had planned to wet-sand / polish before putting down Terry's decals... might not even be necessary. :scratchead:
Thanks Mike!  It's amazing what some elbow grease (and ALOT of JBWeld) can transform!
You're very welcome Peter!  Thank you for tagging along!
classiccat
With the fender pan bolted down, we're waiting for this horse's saddle to arrive from out west!
(I purchased a unique :ph34r: c-series seat from @dw753...we'll see if you can guess what's different)
^^^ The hardware securing the fender pan to the tractor is actually new grade8 hw from TSC.  It "parkerizes" beautifully as long as you 1st remove the yellow coating prior to the acid simmer.
Some red side markers from TSC round-out the rear.
  • Excellent 4
Pullstart
I’m looking forward to seeing the finishing touches!
classiccat
Gave the muffler a little love (VHT flameproof).
gave the PTO hoop a little shine (sanded to 1000g & polished & sealed with sharkhyde)
found a cracked :wh: battery tray off of fleabay for 3 bucks + shipping.  We have just the cure for that sort of thing.
after a few coats of VHT vinyl dye...like a glove:
Time to leave the nest
  • Excellent 5
  • Similar Content
    • CS-17
      By CS-17
      Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
        I received it in non working order, I have since done the following repairs:   To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter.   To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted).    This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $1000 or best offer.   Please feel free to CALL me for details or any question!   THANKS for looking!
    • PWL216
      By PWL216
      I took off the drive belt today and brought it to Tractor Supply, measured it there and it was 1/2” x 81”. It’s old and stretched out so I bought an 80”. It went on fine but the tractor isn’t shifting into gear properly. Looking here and on the web, it seems the correct part number is 7473 and the size is 5/8”x82”. Is that correct? Maybe the PO had used the wrong size?
    • D_Mac
      By D_Mac
      So last fall I got this Dynamark riding mower for free. Engine ran but when you stepped on the clutch/brake it wouldn't disengage. Looking at it I noticed it was a new drive belt. I figured PO got the wrong belt so I looked up what I thought would be the correct belt and ordered it. When it came I removed the belt that was on it and it looked to be the exact same size as the new one. Put new one on and same thing. That was an 82 inch belt. So I looked again and saw that a similar model had an 85 inch belt so I ordered one of those..... close but no cigar ! Now I ordered an 86 inch and are waiting for it. In the mean time I noticed water had gotten into the gas tank. The gas cap was the style with a gage but the bubble is busted off. Since the cap goes through the hood on top water leaks in. I need a new cap but having the same issues finding correct one. I don't need one with a gauge just one the screws on tight. Any help works be appreciated as I am finding multiple part numbers.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Got my parts from Lincoln, governor gear and shaft. So, I started assembly today. Took me three tries to get that two-piece crank in, thankfully it was within spec when done so I didn't have to take it back apart to shim!  Got the crank in, lapped valves and ground to spec. I found this old aluminum fixture from a hospital bed oxygen filter mount and squared it up on belt sander that worked really well on valve stem. Progress at last, will finish up soon. Hope it runs well when done! Going to put it on my 653.
    • Kenneth R Cluley
      By Kenneth R Cluley
      Okay engine Guru's, newbie needs some help! Rebuilding older 8 horse and I am new to small engines. I have rebuilt numerous car/truck engines but never a kohler k. I have researched all available videos and really appreciate the small block tutorial by Prondzy. I am at reassembly stage, so my question is, related to timing marks. I have camshaft with centrifical advance which has a groove or line on spacer that engages pawls. does this groove line up with pointed part of casting on inner rim of gear? Also, there is a groove on opposite side of camshaft gear that I believe should align with pointed mark on casting of crankshaft. See attached pictures. Thanks for any help. Just want to be sure!
