bds1984 1,516 #76 Posted September 18, 2019 What are you going to do with that SS12? Share this post Link to post Share on other sites
Pullstart 71,098 #77 Posted September 18, 2019 3 hours ago, bds1984 said: What are you going to do with that SS12? Do you have any need for it? I thought I’d rob a few things off it then send it down the road. Share this post Link to post Share on other sites
bds1984 1,516 #78 Posted September 19, 2019 Possibly. Those old Sears are beginning to grow on me. Is the engine stuck? Share this post Link to post Share on other sites
Pullstart 71,098 #79 Posted September 19, 2019 47 minutes ago, bds1984 said: Possibly. Those old Sears are beginning to grow on me. Is the engine stuck? PM sent. Share this post Link to post Share on other sites
Pullstart 71,098 #80 Posted October 8, 2019 This afternoon I jacked Putt Putt up off the ground while I was watching paint dry on Hot Wheels and gave it a zero gravity grease job. I then realized that I borrowed a front wheel off him to mock up on Frank a while back... low and behold I mounted it backwards! I guess the bearings don’t care, right? 1 Share this post Link to post Share on other sites
Pullstart 71,098 #81 Posted October 23, 2019 Putt Putt made the trip to WI this weekend, where I tried out a 10” plow behind him. Probably too much I know, but it’s what I had. The day started out not so pretty, with the plow digging to China and pulling hard to the left. @Shynon taught me a bit about adjusting the plow share(?) to push away from the fresh earth and that straightened me out. I kept adjusting the suck point until it dug right to where it would pull easily and roll the earth well. The little tractor did pretty well, but I could easily use even more than the weights on it! I see how traction on the land side is much more difficult to find than fresh plowed earth. I could probably make due taking one weight off the right and adding it to the left. I’d also like to fluid fill these tires, or get a skinny set mounted up and filled for plowing too. That tractor sure is filthy! It’s ready for a bath, along with Hot Wheels. 2 3 Share this post Link to post Share on other sites
Tractorhead 9,217 #82 Posted October 23, 2019 Maybe filled tyres in combination with chains on the Grass side will do the Trick. Think it‘s worth a try, or is @pullstart land already completely plowed? 😂 2 Share this post Link to post Share on other sites
Pullstart 71,098 #83 Posted October 23, 2019 No yard, no field, no problem! 1 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #84 Posted October 23, 2019 But maybe Lawn of the Neighborhood 😂 1 1 Share this post Link to post Share on other sites
Achto 32,347 #85 Posted October 23, 2019 What's a property line?? One just never knows where the furrow may take you. 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #86 Posted October 23, 2019 Oh yeah, i believe he has a somebody call’s it „Plow fever“, what cannot be healing, It just can be supressed by Plow til end of Gas.. 😂 @Achto 😂😂😂😂😂👍 3 Share this post Link to post Share on other sites
Pullstart 71,098 #87 Posted October 25, 2019 They’d think there’s a real mole problem. Next thing you know, they’re tossing grub poison out there by the bucket! 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #88 Posted October 25, 2019 Offer them, you can Solve the Mole Problem while Plowing their Areal,😂 it was sometimes more effective instead of Poison..... a double (maybe tripple) Win Win situation... 😂😂😂😂😂😂 1 Share this post Link to post Share on other sites
Pullstart 71,098 #89 Posted April 9, 2020 A little Putt Putt update. Last year’s plow day was the last weekend Putt Putt has been out of the barn. The bolt holding the front axle pin came out and the axle was flopping around by just the rear hole. Today I fired him up and pulled him into the front shop to play with the idea dual gas out back. I decided before pulling the pin and going to a c-clip style, I’d try drilling and tapping the end and sticking a 3/8” bolt with a captive washer and lock washer in the hole. @ebinmaine you were asking the other day the best way to drill the center of a piece of round stock. I’d say I am pretty close eyeballing it! I used a center punch, 3/16” pilot drill and finally the 5/16” drill for the 3/8”-16 tap. what do y’all think about the duals? Yay? Nay? 2 2 Share this post Link to post Share on other sites
ebinmaine 80,279 #90 Posted April 9, 2020 4 minutes ago, pullstart said: duals? Yay !!! Share this post Link to post Share on other sites
ebinmaine 80,279 #91 Posted April 9, 2020 Nice work on that pin man! 1 1 Share this post Link to post Share on other sites
Pullstart 71,098 #92 Posted April 23, 2020 I found another baffle like the one in Putt Putt’s Cherry Bomb stack! It’s from the mufflers of my 2006 Honda Shadow Spirit 750. This one here has about 20 miles on the odometer! 1 Share this post Link to post Share on other sites
Pullstart 71,098 #93 Posted July 30, 2020 On 4/22/2020 at 8:26 PM, pullstart said: I found another baffle like the one in Putt Putt’s Cherry Bomb stack! It’s from the mufflers of my 2006 Honda Shadow Spirit 750. This one here has about 20 miles on the odometer! @Richcz28 here is the innards of Putt Putt’s stack 1 Share this post Link to post Share on other sites
Pullstart 71,098 #94 Posted September 3, 2020 I borrowed Putt Putt’s gas cap for Poppy because that was leaking so bad. I often see “what gas cap will fit my round hood?” and I often try to respond that a C10 gas cap will work with a little modification. Well, now I did a little video to show it. This works for round hoods, 953/1054’s, among probably many other tractors or brands. 3 Share this post Link to post Share on other sites
WHX?? 57,798 #95 Posted September 3, 2020 Thanks Kev was looking for a couple of those caps! 1 Share this post Link to post Share on other sites
Achto 32,347 #96 Posted September 3, 2020 (edited) 4 hours ago, pullstart said: I borrowed Putt Putt’s gas cap for Poppy because that was leaking so bad. I often see “what gas cap will fit my round hood?” and I often try to respond that a C10 gas cap will work with a little modification. Well, now I did a little video to show it. This works for round hoods, 953/1054’s, among probably many other tractors or brands. The right hand cap from a Shovel Head should be a direct replacement. I will confirm this tonight. Edited September 3, 2020 by Achto 1 Share this post Link to post Share on other sites
WHX?? 57,798 #97 Posted September 3, 2020 9 minutes ago, Achto said: The right hand cap from a Shovel Head should be a direct replacement. I will confirm this tonight. Yes do that ...somewhere I have those but petty banged up if I recollect Share this post Link to post Share on other sites
Pullstart 71,098 #98 Posted January 3, 2021 Here’s a picture of the girls and I riding around at @whfan74Scott’s last meet and greet / plow day! 2 1 2 Share this post Link to post Share on other sites
Pullstart 71,098 #99 Posted March 9, 2021 Putt Putt got a points cleaning today and some seat time. I sure have missed the rhythm of the ole K-181 and Cherry Bomb popping off! 5 1 Share this post Link to post Share on other sites
WHX?? 57,798 #100 Posted March 10, 2021 In my quest for front end parts for a '61 or 62 looks like that tractor has got full length tie rods instead of only one Kev. That would mean it has the triangle plate welded to the lower shaft and no drag link. I woulda thought that it would have shared the same front end parts as a say a 702? Which is just a single short tie rod and drag link. Your steering gear looks '63 ish. I need to look at the IPL for a 502 I guess. Share this post Link to post Share on other sites
