19richie66 17,932 #176 Posted April 1, 2018 (edited) I see a new name for this tractor..... “Cinnamon” Edited April 1, 2018 by 19richie66 3 1 1 Share this post Link to post Share on other sites
PeacemakerJack 11,039 #177 Posted April 1, 2018 1 hour ago, ebinmaine said: I did a bit of painting !!!! I'm going to warn the color purists. It isn't red. But it's a color no other manufacturers use that I know of. I chose a satin to be more forgiving of the rough surface. Tank and wheels will be Navajo white. This is very interesting Eric! I, for one, would like to hear how you came up with the color combo. I’ll be looking forward to seeing the finished product now more than ever for sure. “Cinnamon” could be a great name like @19richie66 suggested... 3 Share this post Link to post Share on other sites
ebinmaine 80,400 #178 Posted April 1, 2018 1 hour ago, classiccat said: Lookin' good.... That's a killer white! Whether you like it or not... If i tilt my laptop just the right way.... that hood & pan are still red. The white is just a tiny bit more tan than the off white or antique white on WH. The cinnamon is pretty much reddish brown. ...or brownish red. 3 Share this post Link to post Share on other sites
ebinmaine 80,400 #179 Posted April 1, 2018 1 hour ago, 19richie66 said: I see a new name for this tractor..... “Cinnamon” 1 hour ago, PeacemakerJack said: This is very interesting Eric! I, for one, would like to hear how you came up with the color combo. I’ll be looking forward to seeing the finished product now more than ever for sure. “Cinnamon” could be a great name like @19richie66 suggested... You guys might be onto something there. Color choice was pretty much me just being. ..me. I ain't quite right and I'm ok with it. HAD to have something different, unique. We went to the big orange Box store. Stood in the paint aisle. Decided that this color "didn't suck" ... so we bought it. 1 7 Share this post Link to post Share on other sites
dells68 7,499 #180 Posted April 1, 2018 Never hurts to be yourself. My wife just wishes I'd be myself a little less often! 8 Share this post Link to post Share on other sites
ebinmaine 80,400 #181 Posted April 1, 2018 7 hours ago, dells68 said: Never hurts to be yourself. My wife just wishes I'd be myself a little less often! HAHAHAHA !!!!!! 2 Share this post Link to post Share on other sites
Achto 32,385 #182 Posted April 1, 2018 Interesting paint combo, can't wait to see the finished product. 3 Share this post Link to post Share on other sites
19richie66 17,932 #183 Posted April 1, 2018 (edited) The Cinnamon color is like a “Mauve” but you don’t sound like you are throwing up when you say it. Besides.... who wants a tractor named Mauve? Should look good all done up with those colors. Definitely something different. Edited April 1, 2018 by 19richie66 3 2 Share this post Link to post Share on other sites
ebinmaine 80,400 #184 Posted April 1, 2018 27 minutes ago, 19richie66 said: The Cinnamon color is like a “Mauve” but you don’t sound like you are throwing up when you say it. 2 Share this post Link to post Share on other sites
ebinmaine 80,400 #186 Posted April 2, 2018 Can any or all of you guys recommend a particular scraping tools such as a sized file or sized wire brush for scraping the rust out of the engine cooling fans? I don't have a sandblaster. Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #187 Posted April 2, 2018 I think when dad and I redone the Kohler on the CC original we use like a 1/2" diameter by 3-4" long wire brush on an electric drill , could use a die grinder might go faster but you'll loose more bristles faster, and lately I've been using a 1/2" think by 3-4" diameter drill mounted "paint stripper" from Walmart when cleaning up the underside of mower decks, hope this helps, Jeff. 2 2 Share this post Link to post Share on other sites
ebinmaine 80,400 #188 Posted April 3, 2018 2 hours ago, WVHillbilly520H said: hope this helps Oh yeah it do !! 1 2 Share this post Link to post Share on other sites
RandyLittrell 3,945 #189 Posted April 3, 2018 15 hours ago, ebinmaine said: Can any or all of you guys recommend a particular scraping tools such as a sized file or sized wire brush for scraping the rust out of the engine cooling fans? I don't have a sandblaster. Small round files and a strip of emery cloth folded up. Harbor Freight makes a little hand held sandblaster that actually works pretty good for small things. https://www.harborfreight.com/21-oz-hopper-gravity-feed-spot-blaster-gun-95793.html Randy 3 Share this post Link to post Share on other sites
ebinmaine 80,400 #190 Posted April 3, 2018 10 minutes ago, RandyLittrell said: Small round files and a strip of emery cloth folded up. Harbor Freight makes a little hand held sandblaster that actually works pretty good for small things. https://www.harborfreight.com/21-oz-hopper-gravity-feed-spot-blaster-gun-95793.html Randy Thank you for that listing Randy. I'll check that closer later on the bigger computer at home. How much CFM do you need to run that? Share this post Link to post Share on other sites
RandyLittrell 3,945 #191 Posted April 3, 2018 (edited) Not sure, I have a 5hp 60 gal compressor so I never have any problem with stuff like that. I think a smaller compressor will work, you will just have to do small areas at a time. Since it is gravity fed, it works better than siphon models. OK, I went and looked at the specs, it says 7cfm@90psi, so thats bigger compressor specs. Their smaller compressors only put out 4.7cfm@90, so it will work, just take a little longer. Randy Edited April 3, 2018 by RandyLittrell Share this post Link to post Share on other sites
ebinmaine 80,400 #192 Posted April 3, 2018 @RandyLittrell, Thanks again. I have a 220 volt, 3 horsepower, 30 or 40 gallon. But, I also have a smaller pancake style compressor I could put into the mix while I'm using the blaster. That would be a little inadequate but mostly functional. Not the kind of tool I would use very often anyways. " use what ya have" 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #193 Posted April 3, 2018 Your welcome, I have been at home with my back messed up and go see the surgeon tomorrow so I have had a lot of time on my hands. I don't use mine very often, but its really handy for some small things and $20 doesn't hurt the budget too much. Randy 1 Share this post Link to post Share on other sites
ebinmaine 80,400 #194 Posted April 3, 2018 3 minutes ago, RandyLittrell said: Your welcome, I have been at home with my back messed up and go see the surgeon tomorrow so I have had a lot of time on my hands. I don't use mine very often, but its really handy for some small things and $20 doesn't hurt the budget too much. Randy Well I hope everything goes correctly and you feel better! 2 Share this post Link to post Share on other sites
WHX?? 57,845 #195 Posted April 3, 2018 (edited) Yes thanks Randy will have to get one of those to do little stuff till my mother of all compressors and cabinet blaster ships come in! Edited April 3, 2018 by WHX16 3 Share this post Link to post Share on other sites
ebinmaine 80,400 #196 Posted April 15, 2018 Been doing a LOT of other stuff around the property now that we can get OUT side (until today) so I haven't spent much time on the Cinnamon horse. Today I wire brushed the new-to-me hubs I got from A-Z and tossed a coat of paint on them. My honey sprayed another coat on the hood as well. 3 2 Share this post Link to post Share on other sites
ebinmaine 80,400 #197 Posted May 27, 2018 I can't believe it's been over a month since I've touched this rig but we've been Sooooo busy!!!! Just a quick one today. I put the hubs and wheels on using a kit from @rmaynard. I need to be able to reposition it in the shop a bit. Next project is to tear apart the 8 speed and clean it from inside to eliminate a grinder style wheel bearing. 5 Share this post Link to post Share on other sites
19richie66 17,932 #198 Posted May 27, 2018 That makes it sooo much easier dealing with tires. Replacing all my lugs eventually with lug studs and nuts. Actually one of the best upgrades you can make on any garden tractor. 2 Share this post Link to post Share on other sites
ebinmaine 80,400 #199 Posted May 27, 2018 2 minutes ago, 19richie66 said: That makes it sooo much easier dealing with tires. Replacing all my lugs eventually with lug studs and nuts. Actually one of the best upgrades you can make on any garden tractor. They're on both of mine and will likely be on every one I ever own. 1 Share this post Link to post Share on other sites
Sarge 3,473 #200 Posted May 27, 2018 I use a few old Swiss pattern riffler files for cleaning/smoothing those engine fins on air-cooled units, they work excellent. Similar to these- https://www.amazon.com/Mercer-Abrasives-BCRIFS-Riffler-8-Piece/dp/B0052RQ4WE/ref=sr_1_86?s=power-hand-tools&ie=UTF8&qid=1527423281&sr=1-86&keywords=swiss+pattern+file+set Just avoid the Chinese made diamond type - they only last a few strokes before the grit layer comes off. On engines that are known to get worked hard or run hot, spending the time to smooth and clean up those fins goes a long way in helping service life. Not to mention, it helps keep debris from building up again. Sarge 3 Share this post Link to post Share on other sites
