SylvanLakeWH 32,776 #24576 Posted September 22, 2025 Sounds to me like you get a free zero turn if they don't return your unmolested... That is inexcusable... 1 Share this post Link to post Share on other sites
rjg854 13,408 #24577 Posted September 22, 2025 2 hours ago, Thetbone said: was told they "donated" my Wheelhorse!!!!!!! Share this post Link to post Share on other sites
Handy Don 17,634 #24578 Posted September 22, 2025 2 hours ago, Thetbone said: I called this morning and was told they "donated" my Wheelhorse! Might need an attorney. Start by writing down your own account of the transaction -- dates, calls, etc -- while it is fresh in your mind. 2 Share this post Link to post Share on other sites
Blue Chips 881 #24579 Posted September 22, 2025 (edited) 4 hours ago, peter lena said: @Blue Chips first thing I NOTICED , was the wide seal on that wheel bearing , ? for me thats an instant , easy removal clean out and regrease . think the use and abuse that these units regularly get , is worth regularly getting after . like lucas X HD green chassis grease , also polyurea rated , stays with it , think that hood hood looks fine , stay at it , pete I agree. If I can get to both sides of a rubber-sealed bearing, I can often pop both seals out and use my bearing packer to pump grease all the way through the bearing until the new grease comes out clean, as I'm doing in the photo below, and then re-install the seals. If I can only get to one side of a sealed bearing, I'll try to remove that seal and use a syringe like the one in the photo to pack grease into all of the spaces in and around the bearings and cage and then re-seal it. I'll look into the Lucas product you mentioned. And here's the bearing with the seals re-installed: Note: If I happen to be greasing a metal-shielded (non-contact shield) bearing with pressed-in shields, I leave the shields in place and try using my bearing packer, pumping the grease gun very slowly to avoid damage to the shields as the grease is slowly squeezed through the narrow gap between the metal shield and the inner race. If the metal shields are secured with C-clips, I can usually remove the C-clips and shields, grease the bearing, and then re-install the shields and C-clips. Edited September 22, 2025 by Blue Chips 3 Share this post Link to post Share on other sites
Thetbone 61 #24580 Posted September 22, 2025 Dealer just called, they found it and will have it tomorrow. Whew!!!!! He said it is just like it was. Share this post Link to post Share on other sites
Handy Don 17,634 #24581 Posted September 22, 2025 8 minutes ago, Thetbone said: Dealer just called, they found it and will have it tomorrow. Whew!!!!! He said it is just like it was. Makes me wonder if it was in an employee's (or owner’s) garage. 2 1 Share this post Link to post Share on other sites
ebinmaine 81,046 #24582 Posted September 22, 2025 2 hours ago, Thetbone said: Dealer just called, they found it and will have it tomorrow. Whew!!!!! He said it is just like it was. IMHO. This is a THOROUGHLY UNACCEPTABLE situation and the BBB should be notified along with scathing reviews online. ... AFTER your tractor is returned UNHARMED. 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,776 #24583 Posted September 22, 2025 3 hours ago, Handy Don said: Makes me wonder if it was in an employee's (or owner’s) garage. 25 minutes ago, ebinmaine said: IMHO. This is a THOROUGHLY UNACCEPTABLE situation and the BBB should be notified along with scathing reviews online. ... AFTER your tractor is returned UNHARMED. 1 Share this post Link to post Share on other sites
davem1111 2,432 #24584 Posted September 23, 2025 1 hour ago, ebinmaine said: IMHO. This is a THOROUGHLY UNACCEPTABLE situation and the BBB should be notified along with scathing reviews online. ... AFTER your tractor is returned UNHARMED. Holy crap! Don't they realize that telling you that could have induced a heart attack??!??! That is just sadistic. 3 Share this post Link to post Share on other sites
8ntruck 9,368 #24585 Posted September 23, 2025 (edited) Dock removal day today. Tapped Clyde, the C-197 for hauling duty. Got 5/7 done. I ran out of daylight and energy. For @c-series don and @rjg854: Clyde, the C-195 at work, hauling dock sections and at quitting time: Edited September 23, 2025 by 8ntruck 4 8 1 Share this post Link to post Share on other sites
oliver2-44 11,791 #24586 Posted September 23, 2025 50 minutes ago, 8ntruck said: Dock removal day today. Tapped Clyde, the C-197 for hauling duty. Got 5/7 done. I ran out of daylight and energy. For @c-series don and @rjg854: Clyde, the C-195 at work, hauling dock sections and at quitting time: What do your dock sections have for flotation? L 1 1 Share this post Link to post Share on other sites
702854boy 1,191 #24587 Posted September 23, 2025 Hopefully, if everything goes according to plan I'll be able to drive my 854 shortly after school because all I've got to do to it is finish making the ignition wire, put the seat on, and put the left rear tire on. However, I know how things are and a 30 minute job will turn into three hours. 6 1 Share this post Link to post Share on other sites
peter lena 10,103 #24588 Posted September 23, 2025 @8ntruck that lake shot is like going home for me , pontoon , kick boat fly fished for years , no noise , no wake , just a perfect roll cast for a hook up . scud / shrimp fly pattern , catch / release . pete 3 Share this post Link to post Share on other sites
8ntruck 9,368 #24589 Posted September 23, 2025 13 hours ago, oliver2-44 said: What do your dock sections have for flotation? L It is not a floating dock. I'm using the Tommy Dock system of connecting brackets, poles and feet. The dock sections are treated lumber. They get floated out into place, then I assemble the poles and feet and set them to level. Share this post Link to post Share on other sites
ebinmaine 81,046 #24590 Posted September 23, 2025 4 hours ago, 702854boy said: I know how things are and a 30 minute job will turn into three hours It's good that you understand this early in life. 3 Share this post Link to post Share on other sites
8ntruck 9,368 #24591 Posted September 23, 2025 4 hours ago, peter lena said: @8ntruck that lake shot is like going home for me , pontoon , kick boat fly fished for years , no noise , no wake , just a perfect roll cast for a hook up . scud / shrimp fly pattern , catch / release . pete The area of the lake in the picture is not a no wake zone. The weekenders on their jet skis make good use of it in hot weather. Been pretty quiet since Labor Day. Just a fully loaded pontoon (18'?) turning and burning for the last hurrah ride of the season last weekend. Share this post Link to post Share on other sites
Blue Chips 881 #24592 Posted September 23, 2025 (edited) 16 hours ago, 8ntruck said: Dock removal day today. Tapped Clyde, the C-197 for hauling duty. Got 5/7 done. I ran out of daylight and energy. When does the lake freeze over at your place? We have a floating dock that I plan to pull out around the first week of November, which should give me several weeks of breathing room until the river freezes, which might not be until well into December. We're living in Maine now, but I lived in Bemidji, MN for a couple of years, and by comparison, mid-coast Maine has relatively mild winters. I should add that when I first installed the dock, I used my 522xi with an attachment I made to move the gangway down to the shore, but now the gangway remains at the shore (I just pull the gangway in for the winter), so I haven't needed the 522xi again for that task. For removing the dock itself, I float it onto a flatbed trailer that I back into the water and pull it out with my truck. Because of the cross-braced 'stiff-arm' system, it's always a big job to take the dock out or put it in...usually requiring at least three neighbors to help me. Edited September 23, 2025 by Blue Chips 2 Share this post Link to post Share on other sites
Ed Kennell 47,750 #24593 Posted September 23, 2025 First day of fall. Dropped a couple decks and prepped for winter storage. 2 9 Share this post Link to post Share on other sites
peter lena 10,103 #24594 Posted September 23, 2025 @8ntruck that lake shot is like going home for me , pontoon , kick boat fly fished for years , no noise , no wake , just a perfect roll cast for a hook up . scud / shrimp fly pattern , catch / release . pete @8ntruck https://www.davescaddenpaddlesports.com/product-page/dave-scadden-s-raptor-lite-speed-x5 been using this type for years , have my FORCE FINS 30 plus years , fished the west with it , montana , utah , oregon , new england , my buddy john , has a similar set up . love to laugh at each other , swap flies , like a magic time . never a competition , just sharing a common love to fly fish . introduced my grandson to this , he loves it too. recently sent him flies , some extra gear I had , he is welding in ohio , great bass fishing out there , he will be home , here in a couple of weeks , grand kids love a solid hug , and talk , always done that , pete 1 Share this post Link to post Share on other sites
peter lena 10,103 #24595 Posted September 23, 2025 @Ed Kennell don't even have to tell me , I know what you are doin ! BREAK THE GRUNGE CYCLE ! screw eye on the wall stud heavy extension spring , wide open S shaped heavy wire , for easy connection , to lift frame area . so simple and effective . thank you for making my day , pete ! 2 Share this post Link to post Share on other sites
ebinmaine 81,046 #24596 Posted September 23, 2025 5 hours ago, Blue Chips said: comparison, mid-coast Maine has relatively mild winters. And getting warmer every year... 🙄 3 hours ago, Ed Kennell said: First day of fall. Dropped a couple decks and prepped for winter storage. Waste oil 🛢 soak? 1 Share this post Link to post Share on other sites
8ntruck 9,368 #24597 Posted September 23, 2025 5 hours ago, Blue Chips said: When does the lake freeze over at your place? We have a floating dock that I plan to pull out around the first week of November, which should give me several weeks of breathing room until the river freezes, which might not be until well into December. We're living in Maine now, but I lived in Bemidji, MN for a couple of years, and by comparison, mid-coast Maine has relatively mild winters. I should add that when I first installed the dock, I used my 522xi with an attachment I made to move the gangway down to the shore, but now the gangway remains at the shore (I just pull the gangway in for the winter), so I haven't needed the 522xi again for that task. For removing the dock itself, I float it onto a flatbed trailer that I back into the water and pull it out with my truck. Because of the cross-braced 'stiff-arm' system, it's always a big job to take the dock out or put it in...usually requiring at least three neighbors to help me. The lake usually starts to freeze over in December. Sometimes, there is enough ice to be on the lake around Christmas. The last few years it has been January before there is good ice on the lake. Not as many fishing shanties as there used to be, either. 1 Share this post Link to post Share on other sites
Ed Kennell 47,750 #24598 Posted September 23, 2025 1 hour ago, ebinmaine said: Waste oil 🛢 soak? Yes sir. 2 Share this post Link to post Share on other sites
Wvtroutbum81 327 #24599 Posted September 24, 2025 Patched the broken seat frame on my 314-8. One side was completely missing. some angle iron and flat stock was used. 8 4 Share this post Link to post Share on other sites
Blue Chips 881 #24600 Posted September 24, 2025 4 hours ago, ebinmaine said: And getting warmer every year... 3 hours ago, 8ntruck said: The lake usually starts to freeze over in December. Sometimes, there is enough ice to be on the lake around Christmas. The last few years it has been January before there is good ice on the lake. Not as many fishing shanties as there used to be, either. We're far enough inland that the salt water doesn't make it this far up the river, so it's subject to freezing. However, since we've lived in Maine (about 18 years now), it seems that the winters have been getting milder and the river ice is appearing later and breaking up earlier (and seems thinner, too). On a tractor topic, today I cleaned up and painted the GT18's vent screens, hood sides, and grille. I also took the foot rests apart to assess the rust situation. There's a fair amount of rust on the foot rests, enough to tempt me to use my grit blasting attachment for my pressure washer, which, when used with coal slag media, is much more aggressive than the glass bead media I currently have in my small blasting cabinet. However, blasting with grit and water is really messy, so I generally reserve that for multiple larger items or things with really deep rust. I think I'll try a less aggressive approach, like soaking the foot rests in paint remover overnight, and then using something like citric or phosphoric acid on the rust, which I think will be OK to use on the foot rests (I avoid using acid rust removers on high-strength or hardened steel parts, due to the potential for hydrogen embrittlement). The rust isn't as deep as it looks in the photos, but it's in a location under the rubber foot mats that traps water, so I want to do a thorough job of removing the rust and protecting the metal. I might use a two-part epoxy primer on the clean metal (or at least a couple of coats of self-etching primer/sealer, followed by a couple of coats of paint, and allow adequate curing time before reattaching the rubber mats, so that they don't poke through soft paint. The factory-approved New Holland paint in rattle cans seems to cure reasonably fast to the point where I can't scratch it with my fingernail, so I'm not bothering to use paint and hardener with an HVLP spray gun. 2 Share this post Link to post Share on other sites
