cleat 5,067 #21126 Posted April 9 The bracket under the cam plate has two studs welded to it. Unfortunately yours is missing one. You could really use this bracket and the tension washers. I have lots of tension washers due to converting to foot control but I don't have the bracket. 2 1 Share this post Link to post Share on other sites
ML3 867 #21127 Posted April 9 Took rat rod on 1st big shake down ride around neighborhood. Made it back without any issues. 1 7 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,473 #21128 Posted April 11 Well I was working the garden with the 312-8 plowing, etc. and then in between breaks it would not start. Dead, no clicking solenoid, nothing. Quick look and didn't see anything obvious so just jumped it from solenoid to finish the day out. Got to poking around on it today. The solenoid tested fine. Determined the start signal wire to the solenoid was not getting the 12v. So onto the switch...it was fine but cleaned it up while I was in there. Started tracing back the signal wire, mine was black with 2 purple lines, and came to the issue! Either while switching from Hi to Lo range, or working the brake the wire pulled off terminal at the PTO Safety switch. The other terminal was bent and nearly broke off. So I replaced that one and rerouted the wires to be less in the way of the shifting and brake lever bar. Still seems really tight but is better then it was and all connectors were holding tight. I'll know where to look if it happens again but can't complain about a free electrical repair that took less than an hour. They can be annoying but patience and just following one wire at a time usually gets you there. So the 312 is back to normal starting and I can sleep again... 3 5 Share this post Link to post Share on other sites
Sparky-(Admin) 19,693 #21129 Posted April 12 Removing all the weights except the rear inner weights…in preparation for a few mowings this year. Good time to check the rear hub set screws since they are a bit tough to service with the inner weights on. 3 5 Share this post Link to post Share on other sites
Sparky-(Admin) 19,693 #21130 Posted April 12 And of course, this is almost always a part of wrenching 2 5 3 Share this post Link to post Share on other sites
squonk 39,147 #21131 Posted April 12 That's a shaving nick for @Pullstart 11 Share this post Link to post Share on other sites
OutdoorEnvy 1,473 #21132 Posted April 12 (edited) Yeah if I'm not bleeding from a project I feel like I missed a step or didn't do it right Edited April 12 by OutdoorEnvy 8 Share this post Link to post Share on other sites
kpinnc 11,004 #21133 Posted April 12 6 minutes ago, OutdoorEnvy said: Yeah if I'm not bleeding from a project I feel like I missed a step or didn't do it right Sadly, this is true for me as well. 2 Share this post Link to post Share on other sites
ebinmaine 63,546 #21134 Posted April 12 17 minutes ago, OutdoorEnvy said: Yeah if I'm not bleeding from a project I feel like I missed a step or didn't do it right 9 minutes ago, kpinnc said: Sadly, this is true for me as well. BBT too 2 Share this post Link to post Share on other sites
Evguy 553 #21135 Posted April 12 8 minutes ago, ebinmaine said: BBT too I’m still healing from a tire swap gone wrong, slipped tire tool got me 1 Share this post Link to post Share on other sites
Sparky-(Admin) 19,693 #21136 Posted April 12 Now to stress test my Harbor Freight handtruck … had to add some wind to the tires 8 Share this post Link to post Share on other sites
peter lena 8,137 #21137 Posted April 12 @paulyv56 aerosol lubricating my finishes for years , very easy and so improving . like a 2 step , first penetrating oil , then regular , wipe down after recovery , have also used , penetrating oil as a paint recovery , then a cleaner wax , on a palm buffer , either way the paint comes out , and stays , looking good . pete 2 Share this post Link to post Share on other sites
peter lena 8,137 #21138 Posted April 12 @kpinnc, nice looking unit ! well kept ! love that twin , stay at it , pete 1 Share this post Link to post Share on other sites
ebinmaine 63,546 #21139 Posted April 12 1 hour ago, Evguy said: I’m still healing from a tire swap gone wrong, slipped tire tool got me I've gotten into several "discussions" with longish iron stuff over the years. My father is left handed. My mother is right handed. I write with my right hand. I cast a fishing rod with my right hand and reel with my left. I shoot archery right handed. A gun however is definitely left handed. I cannot switch the two. On the rare occasion I've played softball or baseball I bat right handed, and poorly. I had to be taught that if right handed one uses the left to catch with a glove. The was... odd. I can however switch hands to use many tools. I tell you all that to tell you this: Because my ridiculous brain sometimes can't decide which hand to use I do things bassackwards. I tried holding a crowbar with my left while swinging a small sledgehammer with my right. ... while having my arms basically crossed in front of the smash area. BBT says, do we think that's a good idea?? I later learned .. no. No it was not a good idea. On the plus side I had the wherewithal to laugh at just how ... not bright... that whole move was. 4 Share this post Link to post Share on other sites
Ed Kennell 36,095 #21140 Posted April 12 12 minutes ago, ebinmaine said: I've gotten into several "discussions" with longish iron stuff over the years. My father is left handed. My mother is right handed. I write with my right hand. write left hand even after several years of knuckle cracking by ruler wielding teachers that insisted I use my right hand I cast a fishing rod with my right hand and reel with my left. cast left hand reel right hand I shoot archery right handed. left hand. A gun however is definitely left handed. left hand also right eye dominate that mandates optics to shoot I cannot switch the two. no switch On the rare occasion I've played softball or baseball I bat right handed, and poorly. I had to be taught that if right handed one uses the left to catch with a glove. The was... odd. bat right only right to catch and left to throw only I can however switch hands to use many tools. left only is good for loosening screws and jar lids I tell you all that to tell you this: Because my ridiculous brain sometimes can't decide which hand to use I do things bassackwards. biggest problems are entering exit doors and using scissors with the left hand I tried holding a crowbar with my left while swinging a small sledgehammer with my right. ... while having my arms basically crossed in front of the smash area. BBT says, do we think that's a good idea?? I later learned .. no. No it was not a good idea. often shake hands with the left, but then this is proper for Boy Scouts On the plus side I had the wherewithal to laugh at just how ... not bright... that whole move was. Right is often wrong and left is sometimes right. 3 Share this post Link to post Share on other sites
ebinmaine 63,546 #21141 Posted April 12 12 minutes ago, Ed Kennell said: Right is often wrong and left is sometimes right. Sounds like you and I are on equal but opposite paths!! 1 Share this post Link to post Share on other sites
squonk 39,147 #21142 Posted April 12 57 minutes ago, ebinmaine said: I've gotten into several "discussions" with longish iron stuff over the years. My father is left handed. My mother is right handed. I write with my right hand. I cast a fishing rod with my right hand and reel with my left. I shoot archery right handed. A gun however is definitely left handed. I cannot switch the two. On the rare occasion I've played softball or baseball I bat right handed, and poorly. I had to be taught that if right handed one uses the left to catch with a glove. The was... odd. I can however switch hands to use many tools. I tell you all that to tell you this: Because my ridiculous brain sometimes can't decide which hand to use I do things bassackwards. I tried holding a crowbar with my left while swinging a small sledgehammer with my right. ... while having my arms basically crossed in front of the smash area. BBT says, do we think that's a good idea?? I later learned .. no. No it was not a good idea. On the plus side I had the wherewithal to laugh at just how ... not bright... that whole move was. Write right handed. Throw & Bat baseball left handed Golf: long shots left, short shots and putt right Hockey both right and left Bowl both hands. Have shot 2 balls at once a few times! horseshoes both Basket ball both Football left 2 2 Share this post Link to post Share on other sites
ranger 1,666 #21143 Posted April 12 I’m left handed? I write with my left hand, but everything else I can use either hand? Welding, painting, mainly r/h, but no problem using either? Projects, designs etc, I can visualise the end result in my mind’s eye. I can lay in a hot bath and come up with a ‘design’ for something, and can ‘see’ the finished article, and how I would make it, without making any drawings or plans. I read somewhere that left handed people have this ability? (Curse?). 2 Share this post Link to post Share on other sites
Beap52 607 #21144 Posted April 12 1 hour ago, ranger said: Projects, designs etc, I can visualise the end result in my mind’s eye. I can lay in a hot bath and come up with a ‘design’ for something, and can ‘see’ the finished article, and how I would make it, without making any drawings or plans. I read somewhere that left handed people have this ability? (Curse?). I know what you mean. I can build a room addition onto a house in my mind and pretty much have a days work laid out before I start. My helper never could visualize in his mind what I was talking about or doing. Once the project was done, he'd say "Oh, it's done but I don't know how it came together." I write with my right (porbably beat into submission by some well meaning teacher). Eat with my left. Could never play base ball as then only gloves available went onto my throwing hand so removing a glove to throw a ball resulted in my not being first round choice in our small town games. I believe I would have been more successful playing the banjo if I had a left handed one. I can drive a nail equally well with either hand. Even to this day giving me instructions using right or left causes me to stop and think "Eat with my left and write with my right." Share this post Link to post Share on other sites
ACman 7,561 #21145 Posted April 12 Did get the front tires changed out . This to this 2 9 Share this post Link to post Share on other sites
8ntruck 6,479 #21146 Posted April 13 (edited) 8 hours ago, Sparky said: And of course, this is almost always a part of wrenching One of the other teams at the robotics competition we attended last weekend had a white board with their question of the day - "What is your robot's name and what is its favorite food?" I wrote our answer - Axl, and his favorite food is knuckles. @ebinmaine - your comment on shooting makes it sound like you are left eyed. Edited April 13 by 8ntruck 1 1 Share this post Link to post Share on other sites
WHGuy413 2,545 #21147 Posted April 13 For the first time in a long long time the “twins” were both out doing yard work. I worked this morning and then came home to do some yard work. I try to base my timing of my yard work (thatching, aerating, fertilizing, etc) on when we do it at work. We started a couple weeks ago at work but it seems like every weekend it’s rained and kept me from doing it. Sure enough it poured twice while I was out. I only did the front yard and part of the side. The back which is the biggest piece of the property can wait. The twins are my 71 Bronco 14 and my 73 12 automatic. Both with 18hp vanguard v twins so that’s why we call them the twins. The 12 auto pulled the green thatcher (don’t hurt me gotta use what I have) and the bronco was on the vac system. Alex isn’t home this weekend. It definitely felt weird being able to drive a couple tractors of my own and do work with them. He usually jumps to do it as soon as I mention anything tractor work related. 4 8 Share this post Link to post Share on other sites
DevonianHorse 250 #21148 Posted April 13 Using the Horse to haul some logs with my Dad today for his log burner 2 5 1 Share this post Link to post Share on other sites
kpinnc 11,004 #21149 Posted April 13 3 hours ago, WHGuy413 said: Both with 18hp vanguard v twins Gotta love them Vanguards! 2 1 Share this post Link to post Share on other sites
ebinmaine 63,546 #21150 Posted April 14 What have I done to "my" Wheelhorse? Brought it somewhere else! Here's my Ole Man in his purple hat driving the C121 we built for him to mow with. 2 2 7 Share this post Link to post Share on other sites
