Lee1977 7,813 #26776 Posted October 2 You have it looking good! I work on my driveway last week, and again on Monday. trying to keep the grass from taking it over, Share this post Link to post Share on other sites
kpinnc 19,107 #26777 Posted October 2 5 hours ago, Lee1977 said: You have it looking good! I work on my driveway last week, and again on Monday. trying to keep the grass from taking it over, Great to hear from you Don! It's been crazy here but we are beginning to settle into the new normal. I hope to be able to tinker in the next couple months so you'll have to come by once we get a little more construction done. 2 Share this post Link to post Share on other sites
Pullstart 71,564 #26778 Posted October 2 I had some dirt to dump out back. It’s been too long since I’ve Horsed around, so I took the long way home on Steve Oh Two. 5 8 Share this post Link to post Share on other sites
Racinbob 13,290 #26779 Posted October 6 The boss found this blade on FB for our daughters Commando 800. I made a trip to South Bend and brought it home. It came with the weights. It was dirty so I pressure washed it and also the 48" deck since mowing is done this year. Not bad for a 50+ year old deck. 8 5 Share this post Link to post Share on other sites
rjg854 13,455 #26780 Posted October 6 4 hours ago, Racinbob said: The boss found this blade on FB I trust you got the other pieces that complete that plow. Share this post Link to post Share on other sites
peter lena 10,127 #26781 Posted October 6 @Racinbob those plow blade set ups really come to life with, plow quadrant . linkage detailing , spindle bolts , flat washers , lube and lok nuts , let you dial in , perfect motion setting . many years on mine . build up on jack stands , roller stool around , so you can , VERIFY ,SMOOTH EASY FUNCTION . then install it on tractor , similar improvements on , pto lever set up , and mule drive function , again years in use , no problems at all , pete 1 Share this post Link to post Share on other sites
Racinbob 13,290 #26782 Posted October 6 (edited) 1 hour ago, rjg854 said: I trust you got the other pieces that complete that plow. I had already taken a couple things off it. If you look closely you'll see the lever to release the angle pin hanging on the lift hole. He had four blades and it was my choice with the weights. He didn't have any axle brackets. Edited October 6 by Racinbob 1 Share this post Link to post Share on other sites
sqrlgtr 4,226 #26783 Posted October 6 New drag link on 701 and made a little weight bracket out of a old repurposed mule drive. Its on the C160 but can use it on any tractor with mule drive hitch up front. Hood has about 1/2” clearance when fully tilted open. 6 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #26784 Posted October 6 Prepping some wheels I picked up from @Retired Wrencher for this winters plow tractor. Kinda neat that they were made by Firestone. Just grey primer went on tonight. I’ve had these never mounted Carlisle All-Trails on the shelf for a few years, will be nice to put em to work! 9 5 Share this post Link to post Share on other sites
Handy Don 17,737 #26785 Posted October 6 1 hour ago, sqrlgtr said: I'd want some handles or a lifting eye for moving that big fella around! 2 Share this post Link to post Share on other sites
sqrlgtr 4,226 #26786 Posted October 6 39 minutes ago, Handy Don said: I'd want some handles or a lifting eye for moving that big fella around! its actually several weights and hard to see but has individual handles in them, but you may have been pulling my chain. 1 1 Share this post Link to post Share on other sites
Bar Nuthin 3,646 #26787 Posted October 7 (edited) Got a few things accomplished on the 754 today. The governor spring finally showed up and I got it on. Installed new bearings in the front wheels. Replaced the idler pulley for the mower deck, only to realize the oil pan is on backwards! The drain pipe is coming out of the RH side and interferes with the idler pulley! Waiting on Lowell to get some of the seals I need back in stock before I go after the leaks (input, brake shaft, both axle seals) EDIT: (almost forgot) Shortly after this video I went full on @peter lena and hosed the entire thing down with PB Blaster! But she is definitely drivable now!!! Edited October 7 by Bar Nuthin almost forgot 1 4 Share this post Link to post Share on other sites
ebinmaine 81,284 #26788 Posted October 7 8 hours ago, Bar Nuthin said: Waiting on Lowell to get some of the seals I need back in stock before I go after the leaks (input, brake shaft, both axle seals) I believe those are easily obtainable from local sources using the numbers in the transmission chart 3 Share this post Link to post Share on other sites
Retired Wrencher 7,045 #26789 Posted October 7 12 hours ago, Sparky said: Prepping some wheels I picked up from @Retired Wrencher for this winters plow tractor. Kinda neat that they were made by Firestone. Just grey primer went on tonight. I’ve had these never mounted Carlisle All-Trails on the shelf for a few years, will be nice to put em to work! Wow Mike nice job on re pant the rims. Is this the final color. 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #26790 Posted October 7 29 minutes ago, Retired Wrencher said: Wow Mike nice job on re pant the rims. Is this the final color. No, it’s just the primer, although I do really like the grey! Going with Cottage White (linen beige) as the final color. Hoping to get a first coat on tonight 3 Share this post Link to post Share on other sites
Retired Wrencher 7,045 #26791 Posted October 7 That will work. What are you using these for? Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #26792 Posted October 7 25 minutes ago, Retired Wrencher said: That will work. What are you using these for? New rear tires for this winters plow rig. I posted a picture above of the tires I’ll be using 2 Share this post Link to post Share on other sites
Sodaking27 1,435 #26793 Posted October 7 New tires and wider rims on the 314H. Used VHT wheel paint. Not a fan of it. Turned out really rough. Re-sand and paint in the spring. Now to paint the wheel weights. Plan on using the 314 as my plow tractor this winter. Just had the driveway repaved, so going to try a poly edge on the blade and no chains. 7 2 Share this post Link to post Share on other sites
Stan50 257 #26794 Posted October 7 I installed homemade clevis hitch with modified receiver hitch, definetely I wouldn't do it once more , too much work involved but for now I don't have easy access to many WH parts. 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #26795 Posted October 7 First coat of finished color is on… 10 1 Share this post Link to post Share on other sites
ebinmaine 81,284 #26796 Posted October 7 33 minutes ago, Sparky said: finished color is Lookin good Mike. That's the shade me n BBT use. 1 Share this post Link to post Share on other sites
ebinmaine 81,284 #26797 Posted October 7 7 hours ago, Sodaking27 said: New tires and wider rims on the 314H. Used VHT wheel paint. Not a fan of it. Turned out really rough. Re-sand and paint in the spring. Wasn't aware they did a wheel specific paint. Usually good products overall. 7 hours ago, Sodaking27 said: Now to paint the wheel weights. Plan on using the 314 as my plow tractor this winter. Just had the driveway repaved, so going to try a poly edge on the blade and no chains. Weights? Fluid filled tires? My experience shows me... the more weight - the better. But we're on gravel rocks etc. 1 1 Share this post Link to post Share on other sites
Sodaking27 1,435 #26798 Posted October 7 (edited) 45 minutes ago, ebinmaine said: Wasn't aware they did a wheel specific paint. Usually good products overall. @ebinmaineThis is what I used. Weights? Fluid filled tires? My experience shows me... the more weight - the better. But we're on gravel rocks etc. Have a set of WH front and rear cast iron weights I’m going to use. Going to give that a try before adding any fluid. Driveway is level and only about 40 feet long. Edited October 7 by Sodaking27 1 Share this post Link to post Share on other sites
sqrlgtr 4,226 #26799 Posted October 8 (edited) Put wheel bearings in front wheels on the 701 today. Didn’t realize there was bushings instead of bearings in these 701 wheels but figured the bearings would be easier on the front spindles. I did notice that the drag link or the shouldered bolt (wheel horse calls it clevis pin part # 3949) in the drag link is wore pretty bad on left side and needs some attention. Edited October 8 by sqrlgtr 4 1 Share this post Link to post Share on other sites
peter lena 10,127 #26800 Posted October 8 @sqrlgtr got one for you , as usual HIDING IN PLANE SITE ! your front end tie rod area , nice improvement on that , been using heim joints for years , no failures , anyway , pto outer swing arm clip , with round hole end ? directly RELATED TO THAT ? HITCH PIN CLIP ON FRAME ,? what could you possibly do ? connect the loops wit a medium pull hooked extension spring ? you know what that does ? STOPS THE RELATED BUZZING AND RATTELING , TA DA ! as a millwright I was always looking for a problem elimination , BTW ANY BEARING I have with rubber side shields , guess what ? carefully remove shield , wipe out , carb cleaner flush . LUCAS GREEN XTRA HD , CHASSIS GREASE , walmart $ 7 , specs 550 deg flash point , polyurea , stays with bearing , WHAT A CONCEPT ! these COLLECTIVE DETAILS ARE A GAME CHANGER , my 3 horses are loaded with them , years in , no issues OR FAILURES , dare to try something , let me know , pete Share this post Link to post Share on other sites
