Ed Kennell
What have you done to your Wheel Horse today?
Lee1977
You have it looking good!  I work on my driveway last week, and again on Monday. trying to keep the grass from taking it over,
kpinnc
Great to hear from you Don! It's been crazy here but we are beginning to settle into the new normal. I hope to be able to tinker in the next couple months so you'll have to come by once we get a little more construction done. :thumbs:
Racinbob
The boss found this blade on FB for our daughters Commando 800. I made a trip to South Bend and brought it home. It came with the weights.
It was dirty so I pressure washed it and also the 48" deck since mowing is done this year.
Not bad for a 50+ year old deck.
  • Like 5
  • Excellent 2
rjg854
I trust you got the other pieces that complete that plow.
peter lena
@Racinbob  those plow blade set ups really come to life with, plow quadrant . linkage detailing , spindle bolts , flat washers , lube and lok nuts , let you dial in , perfect motion setting . many years on mine . build up on jack stands , roller stool around , so you can , VERIFY ,SMOOTH EASY  FUNCTION . then install it on tractor , similar  improvements on , pto lever set up , and mule  drive function , again  years in use , no  problems at all , pete
Racinbob
I had already taken a couple things off it. If you look closely you'll see the lever to release the angle pin hanging on the lift hole. :rolleyes: He had four blades and it was my choice with the weights. He didn't have any axle brackets.
Edited by Racinbob
sqrlgtr
New drag link on 701 and made a little weight bracket out of a old repurposed mule drive. Its on the C160 but can use it on any tractor with mule drive hitch up front. Hood has about 1/2” clearance when fully tilted open.
Sparky
  Prepping some wheels I picked up from @Retired Wrencher for this winters plow tractor. Kinda neat that they were made by Firestone. Just grey primer went on tonight.
   I’ve had these never mounted Carlisle All-Trails on the shelf for a few years, will be nice to put em to work!
  • Like 4
Handy Don
1 hour ago, sqrlgtr said:
I'd want some handles or a lifting eye for moving that big fella around! :rolleyes:
