Handy Don 16,799 #26301 Posted yesterday at 01:31 AM (edited) 23 hours ago, sqrlgtr said: me thinks the ball/tongue will still be even to top of axle and I tried making the hitch as tight as possible to tractor. Actually going to drill a new hole for the hitch pin and slid ball in another inch or so that will help also, I hope. .. This is going to be my firewood hauler at least thats the plan anyhow. Ive pulled some pretty heavy loads with a hitch that I made that goes on the sleeve type hitch and this one isn't much taller if any at all, just hated putting all that tongue weight on my lift cables . Moving the hitch closer to the tractor only modestly offsets the torque from the tongue weight. It does NOT change the torque caused by drag (the effort needed to pull the trailer along). A wheelie can happen extremely quickly with no time to react--and having a 600 lb tractor on your chest and a trailer tongue under your back can be, well, hurtful. As noted, locking the hitch snugly onto the ball and leaving the trailer’s jack wheel close to the ground can be a partial anti-wheelie solution, but if the jack wheel hangs up... Also, pay attention to the trailer tongue--putting the hitch ball in close, you may restrict your turning radius! If you have the option, modifying the trailer tongue so that its hitch is at or below the height of the tractor axle is the way to go. Edited yesterday at 01:34 AM by Handy Don Share this post Link to post Share on other sites
Blaine 89 #26302 Posted yesterday at 03:16 AM Success. IMG_1989.mov 1 4 Share this post Link to post Share on other sites
sqrlgtr 3,066 #26303 Posted 9 hours ago 17 hours ago, Handy Don said: If you have the option, modifying the trailer tongue so that its hitch is at or below the height of the tractor axle is the way to go. yeah it should be just level or a little bit below tractor axle and Most of the weight is on the 3/4' pin at bottom of trans so that will help a bunch. Share this post Link to post Share on other sites
adsm08 4,694 #26304 Posted 7 hours ago So Thursday, while getting ready for the show we found some holes in the boy's mower deck. This afternoon I had him strip it down to repair the shell. I will probably also replace the double belts and re-bearing the whole thing while it is apart. Meanwhile I was futzing with the 1076 I bought from @Ed Kennell at the show. I wanted to get the deck on and try it out as a mowing machine, but first I had to straighten the forks a bit: In the end I got the deck on, but there were other issues, and I ended up using the 855 to mow for the first time this year. The Commando has been dominating lawn care duty so far this year. 2 3 1 Share this post Link to post Share on other sites
lynnmor 8,864 #26305 Posted 6 hours ago May I suggest a visit to this webpage: 5 1 Share this post Link to post Share on other sites
mrc 1,088 #26306 Posted 5 hours ago (edited) hello adsm08, license plate for deck repair...NICE! also great to see a young man learning something besides computer/phone skills. regards mike Edited 5 hours ago by mrc 1 Share this post Link to post Share on other sites
adsm08 4,694 #26307 Posted 4 hours ago (edited) 29 minutes ago, mrc said: hello adsm08, license plate for deck repair...NICE! also great to see a young man learning something besides computer/phone skills. regards mike The license plates were already there when I got it. Ed even joked it's the only WH licensed to drive on the turn pike. I'm on the fence about trying to repair that deck. The area around the spindles seems pretty solid, there is a lot of metal that needs replaced everywhere else. It may be better to just look for a different deck. He much prefers working with his hands over doing computer things. He plays video games, and watches TV, and spends most of the evening most nights talking/texting his girlfriend, but he only has so much patience for a screen, or for sitting still, in a day. @lynnmor As for eye protection, we are well supplied with safety glasses, and use them when needed. Most of this job was done with hand tools, because we were working with carriage bolts, and impact guns strip the holes on carriage bolts. In regards to the picture that I'm sure prompted that comment, he wasn't running the gun, just looking under to line up on the bolt that he couldn't break loose by hand. The deck shell was plenty of protection in this case. Edited 4 hours ago by adsm08 2 2 Share this post Link to post Share on other sites
Ed Kennell 46,358 #26308 Posted 4 hours ago 10 minutes ago, adsm08 said: It may be better to just look for a different deck. Most of those side drive decks have seen a lot of use. The spindles in that one seemed really good. May have some value to someone rebuilding one. You may want to convert to a front mule drive if you look for a better deck. 2 Share this post Link to post Share on other sites
Bill D 2,949 #26309 Posted 4 hours ago (edited) I'm big on eye protection. I'd wouldn't be able to run trains anymore if I lost an eye. I had a coworker who had a deer head fall off the wall and puncture his eye. There's actually a video on YouTube about it. Edited 4 hours ago by Bill D Share this post Link to post Share on other sites
adsm08 4,694 #26310 Posted 4 hours ago 8 minutes ago, Ed Kennell said: You may want to convert to a front mule drive if you look for a better deck. I had also considered that. Took me five minutes to get the deck on, including straightening the mounting forks. Took me another 20 to figure out that goofy belt setup. Share this post Link to post Share on other sites
Handy Don 16,799 #26311 Posted 2 hours ago (edited) 4 hours ago, adsm08 said: This afternoon I had him strip it down to repair the shell. I will probably also replace the double belts and re-bearing the whole thing while it is apart. The cross-shaft bearings are probably ok, but the spindle bearings are probably worn. Part # 1508 spindle bearing (4) ==> Koyo B-1212 needle bearings. You’ll also need new seals 1303 oil seal (2) ==> Timken 312518. Be sure to help your apprentice out during spindle disassembly because the order of components is critical and, if it was a later model with thrust bearings, they’ll almost certainly look like greasy washers! (From the photo, there was a serious dearth of grease on the gears--they should be buried in grease!) Lastly, be prepared to put some shims behind one of the cross-shaft bevel gears (between the gear and the step in the shaft) upon reassembly to take out gear lash. It took me three times to get this right and in the end the shims left about .05” of lash to account for heat expansion. Good luck to you both! PM me if you come up with other questions. Edited 2 hours ago by Handy Don 1 1 Share this post Link to post Share on other sites
adsm08 4,694 #26312 Posted 2 hours ago 5 minutes ago, Handy Don said: The cross-shaft bearings are probably ok The inboard seals have fallen out of the cross shaft bearings and the guts appear to have been exposed for some time. They aren't super rotten, but they are patinaed to match the rest of the tractor. Share this post Link to post Share on other sites
Handy Don 16,799 #26313 Posted 2 hours ago 2 minutes ago, adsm08 said: The inboard seals have fallen out of the cross shaft bearings and the guts appear to have been exposed for some time. They aren't super rotten, but they are patinaed to match the rest of the tractor. Getting the bearings out of the holders is unpleasant and, though I’ve looked, I’ve never seen those parts separately at the show. I’m running the best pair from three donor decks. Share this post Link to post Share on other sites
Handy Don 16,799 #26314 Posted 2 hours ago Ju 11 minutes ago, Handy Don said: Getting the bearings out of the holders is unpleasant and, though I’ve looked, I’ve never seen those parts separately at the show. I’m running the best pair from three donor decks. Just found this in my notes: Staked cross shaft 1515 bearing changes to the 101480 bearing which is a 1630 2RS 1 Share this post Link to post Share on other sites
Bar Nuthin 2,542 #26315 Posted 2 hours ago Found some vintage tractor lights I liked and got them installed on the C-160 today. Pretty close to the ones I put on the C-120. Will probably end up getting an LED upgrade before winter. Also mounted a flag on the C-120. My neighbor volunteered me to join a 4th of July parade with him. I think we may have recruited a few more now. IMG_5367.MOV 2 Share this post Link to post Share on other sites
Blaine 89 #26316 Posted 8 minutes ago Hung the 36” gear drive under the 69 Raider 12 today just to get it out if the middle of the floor. The points conversion went well. This motor hasn’t been ran in decades. Before putting gas in it, I cleaned the carb which only had a little crud in the bowl, and i adjusted the valves. Should have had some breather gaskets on hand because they are hard as a brick and leaking a little, so that’s on the to do list. Need to do some wiring and both cables and change the fluid in the trans. Ordered the 6908 unicorn pulley and required idler standoff support, so the gear drive deck will work with the PT-6 pto. It shouldn’t be long until my 401 gets a well deserved break from its duties. The high back boat seat is very supportive for my lower back, but if i keep whacking my shin every time i get on it, it may have to go. Share this post Link to post Share on other sites
