Ed Kennell
What have you done to your Wheel Horse today?
WHX??
12 hours ago, c-series don said:
belt had jumped off the pulley and was wedged between the transmission and the pulley.
Had this happen on a tractor & turned out PO had monkeyed around with the idler tension and wrong spring on. Too much belt flop. Check the spring for being proper.
7473 shows up as the belt for a 417 hydro and gear jammer.
Guessing you have these but just in case ...
Belts for Riding Mowers.pdfChart Belts Tractor drive.pdfBelts_Mower_spindle_and_drive_belt_charts.pdf
Gotta be a tough one in this kinda weather Don ... hats off :handgestures-salute:
Pierce rigs ... made right here in Appleton WI. :thumbs2: Been in their plant many times.
Edited by WHX??
Desko
Made a make shift weight bar and used some old weights that were kicking around so I could get around with the 44” blower. Didn’t have a problem going anywhere but definitely had to watch backing up. Probably going to seek out some wheel weights this year though.
  • Like 5
Easton Rich
Here are the pictures of the new one if you haven't seen my wacko thread yet. I know some of you dont think its real yet, but I don't lie.
c-series don
Looks like it came with the super rare cutting board belt guard !! 😂👍🏻
  • Haha 7
SylvanLakeWH
Turn it on it's side and you can gut and clean roadkill... at the speeds these tractors achieve, it's a common problem...
 :auto-layrubber:
Edited by SylvanLakeWH
  • Haha 6
Easton Rich
Yes. I was very lucky to find it, it needs disinfected...
  • Haha 1
WHX??
Ventilation for a belt guard ala @cleat with a Greenlee punch.
Bit different pattern Cleat but should work.  Coulda had the spacing a little closer. Deburred with a step bit.20260127_102115.jpg.c748427742f561f588f4869da3553d75.jpg20260127_103712.jpg.e8e3a7b72dde8b3440ba290a7a24c41e.jpg
Speaking of step bits... @Pullstart was here... :lol:20260127_102135.jpg.73df9c9469a9f6f865299ac42c7c9761.jpg
Edited by WHX??
  • Like 5
  • Excellent 3
  • Haha 1
Ed Kennell
The 520H had been acting like it was starving for fuel during the tail end of the last storm clean up. I actually had to leave the warm cab and brave the cold to finish with the 312H.    I had installed an epump last fall and she had been running fine till now.   Time to find the problem before the next storm that is coming this Sat.
I pulled the line off near the carb and turned on the epump and got barely a dribble.  Nice thing about the epumps..you don't have to crank the engine to check for good fuel supply.
So, I went to the other end and pulled the line on the fuel tank petcock....not even a dribble. from the tank.   The petcock was clogged with dirt.  A good cleaning  of the petcock and flushing the tank and back together  and running like a happy ONAN should.
When installing this I like to coat it with vaseline then just start the valve in the grommet before pushing the grommet into the tank then push the valve barb into the grommet.
  • Like 4
  • Excellent 3
Shed
Has anybody ever looked into Guinness book of records to see if this is the longest running active form on one single topic? Today I was just looking through pictures of summer horses tired of snow and thought of this
  • Haha 1
Lane Ranger
Ed:  Interestingly I have found that debris does settle on top of this valve on several of the TORO model Wheel Horse tractors we have.   Seems like gasoline, dirt, dust, leaves, etc sometimes collect in these rear tanks enough that they can block this spot.
Cleaning the tank of all gasoline probably a good idea every four or five years.
Edited by Lane Ranger
  • Like 4
kpinnc
Especially true of tanks with a fuel level sender. They tend to drop rust...
Bill D
I always use the shut off valves with the built-in strainer screen.  Is that what you're using?
WHX??
Work on a 520 Ed Dog entailed taking out the gas tank. Full tank so drain it into a gas can and barely dribbled out. Took a day to let it run out. Pulled the rusty gas cock to check & replace an aged grommet and found @Bill D 's plugged strainer. I have been known to take off the strainer Bill figuring the inline filter will do it's job. Maybe not a good idea but the replacement valves have no screen.
Ed Kennell
Every valve I have pulled had a partially clogged and collapsed screen so I always remove the screens so any dirt can pass thru the valve to the inline filter that I can easily replace.   I have thought of replacing the valve and grommet with a 1/4"NPT bulkhead fitting that would have a much larger opening that would allow the dirt to exit the tank to the filter.   May have drill and tap the tank boss to accept the bulkhead fitting.    I have an inline filter near the tank and near the carb. with the epump in between the two filters.  The plastic tanks are not as bad as the metal tanks, but they still get dirt from the funnels and cans used during filling.
