Heatingman 971 #17176 Posted September 26, 2022 12 minutes ago, ineedanother said: Nice. There's a decent one at work, I might grease the skids with the guys over there for some future work Glad you brought it up, cause that lead me to put it on the tractor for a photo op. Thats when I noticed the one diamond plate cover was a 1/2” longer then the other, so I trimmed it down to match. Now I just need to finish painting. 2 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #17177 Posted September 26, 2022 11 hours ago, Heatingman said: Had some leftover diamond plate from the foot rests, so I made a pretty up cover for the battery. Just friction clamped in place with the battery holder. There is about a 1/8” or so gap above the battery for air movement in case the battery needs to breath. Side note: Really liked the look of @ebinmaine cinnamon horse motor cover, so I did the same with mine. Think it looks sharp. Really like that look. It's possible I may have to "borrow" your diamond plate idea as you did for our engine color. 😁 3 Share this post Link to post Share on other sites
ohiofarmer 3,358 #17178 Posted September 26, 2022 Gonna bring you guys along on this one. So far I have messed about with the carburetor and finally I removed it and used Flitz on the needle/seat. She runs nice now after sitting since 2018 Gotta take the seat and find off the rear because excessive noise underneath the side shield 🛡️ We're going in... 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #17179 Posted September 26, 2022 Some progress today on the Waldomobile . After removing paint and brown weld from some part yesterday . I used one of those plant hangers that you pound in the ground . Hung the parts , last night a lot of wind and a few drops of rain. Plant hanger is U shaped , parts on the ground. Hunted a round and found this metal ironing board ( why my wife had 3 ironing boards ??????? ). Hunted around for thin metal rod made S hooks and sprayed primer. Moved the 8 speed to portable shed where Waldomobile lives now and got it on motorcycle jack. Cleaned everything up and decided it is time for lunch. Need to prime and paint under the panels where trans goes . May tackle the seat pan , while everything dries. @squonkwonder if this tractor ever lived inside. 1 Share this post Link to post Share on other sites
squonk 43,362 #17180 Posted September 26, 2022 4 minutes ago, elcamino/wheelhorse said: @squonkwonder if this tractor ever lived inside. Judging by the wildlife I found on the seat............................. No! 3 Share this post Link to post Share on other sites
ohiofarmer 3,358 #17181 Posted September 26, 2022 (edited) 4 hours ago, ohiofarmer said: Gonna bring you guys along on this one. So far I have messed about with the carburetor and finally I removed it and used Flitz on the needle/seat. She runs nice now after sitting since 2018 Gotta take the seat and find off the rear because excessive noise underneath the side shield 🛡️ We're going in... We took everything off the machine,a lately purchased c160 auto and found that maybe it needs a fender washer in the belt tightening linkage. Now that she is opened up, time for a cleaning underneath the side shields and a filter and transmission oil change. It's nice to have it on the lift for an old man to get to it properly .Then the cleaning to keep the transmission cool and you can see where the vice grips clip on . That's where a small washer under the split pin might take out the vibration. I need to check if a NAPA Gold 1068 is the correct transmission filter and that should complete the comeback of this machine. Edited September 26, 2022 by ohiofarmer 4 Share this post Link to post Share on other sites
OldWorkHorse 3,080 #17182 Posted September 26, 2022 Rest of the plow parts and decals came in the mail today so my daughter and I went down to the shop and put the downforce bar on and she helped with the new decals I got and I added some plow markers for thos early mornings. Probly have to take the angle bar off and weld couple reinforcements on it, but does it's job and works great! Probably some rear facing lights next. 2 2 Share this post Link to post Share on other sites
peter lena 9,190 #17183 Posted September 26, 2022 @Heatingman , do all my plow sets ups off the tractor , why ? so you can rollerstool around it , build up your lever / linkage and detail it in for function , use a plastic / teflon pneumatic length in your cable pull to lever area , makes that 90, degree slide , much smother, also detail your spring pull pin to the quadrant , red grease , can / should engage like a rifle bolt . built up on milk crates , lets it sit just as it would under the tractor , what ever you build in , be the same on the tractor . pete 1 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #17184 Posted September 26, 2022 Oh @squonk Thanks for the big hole in the seat pan . You got a gallon of JB weld I can use ? 1 Share this post Link to post Share on other sites
squonk 43,362 #17185 Posted September 26, 2022 33 minutes ago, elcamino/wheelhorse said: Oh @squonk Thanks for the big hole in the seat pan . You got a gallon of JB weld I can use ? Too much gas! 2 Share this post Link to post Share on other sites
Blasterdad 3,044 #17186 Posted September 27, 2022 7 hours ago, ohiofarmer said: I need to check if a NAPA Gold 1068 is the correct transmission filter NAPA Gold 1410, Wix 51410 3 1 Share this post Link to post Share on other sites
WHGuy413 2,772 #17187 Posted September 27, 2022 After the boys and I went fishing this evening we ordered a pizza and hung out in the garage. Aiden bolted this seat frame on that has an ugly blue home made seat on it but he figured it was better than no seat at all. We plan on purchasing a seat for it just like the one I got for Alex’s Commando 8 this spring. We have plenty of other stuff to do to Aiden’s 1277 before it will Be running again. I need to find the dash I set aside for it, find where to buy throttle and choke cables (I had ordered some for Alex but can’t find the paper I wrote my info down on), I will probably re wire it and a few other parts have been scavenged for other tractors so I need to steal them Back. This thing ran pretty good but it smoked from the breather. pictured is Aiden, you have all met his younger brother Alex before. 6 7 Share this post Link to post Share on other sites
ebinmaine 71,853 #17188 Posted September 27, 2022 8 minutes ago, WHGuy413 said: find where to buy throttle and choke cables @Achto recommended http://psep.biz/store/toro_mower_cables.htm Seems to me it's the first and third cables listed. 2 1 Share this post Link to post Share on other sites
WHGuy413 2,772 #17189 Posted September 27, 2022 23 minutes ago, ebinmaine said: @Achto recommended http://psep.biz/store/toro_mower_cables.htm Seems to me it's the first and third cables listed. Thank you sir 2 Share this post Link to post Share on other sites
peter lena 9,190 #17190 Posted September 27, 2022 @OldWorkHorse that plow detailing , for function , will give you the best gains in all areas . example , squeeze lever on quadrant , swing point , after lubrication upgrade , tightened up the small pull rod starting point, eliminated , exces play , also snugged up spring pull point at quadrant start , amazing difference in response. very easy , effortless swing . years ago also added heim joints to my quadrant to lever point , used threaded rod , to bottom of quadrant m and back to lower lever start point , used 1/2 " fine threaded steel rod , male/ female heim joints . https://www.amazon.com/Steel-Inch-Female-Heim-Joint/dp/B075FGLBK2 , years later still easy / smooth solid , always experimenting , red grease , makes it work , pete 1 Share this post Link to post Share on other sites
Horse Newbie 7,372 #17191 Posted September 27, 2022 On 9/25/2022 at 8:17 PM, WHGuy413 said: Prevent twisting and falling. I’ve been doing this set up for prob 6 years or more and have never had an issue. Some 2x4 braces ( one each direction ) would go a long ways in keeping those uprights in place should they be accidentally bumped… 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #17192 Posted September 27, 2022 Further adventure of Waldo and his mobile. Ground the other foot rest today . Tried a flapper disk on the angle grinder and it worked better than the wire wheel. Had to use the wire wheel is some places. The end of the foot rest was bent all to H**l. Can 't figure what someone could have hit to mangle it that bad. Had to use HF cut off tool on it oh well less weight. Inspected the seat pan ( just primer on it ) .It looked good from a 100 yards. Kind of reminded me off orange peal , but particles of paint were standing straight up. I wiped the seat pan down with acetone before painting yesterday and let it dry. Flapper wheel put back to work , acetone wipe down. Ate lunch and rested for an hour. I then hit with primer again. I not trying to make a trailer queen , just a worker. 3 Share this post Link to post Share on other sites
squonk 43,362 #17193 Posted September 27, 2022 2 hours ago, elcamino/wheelhorse said: Further adventure of Waldo and his mobile. Ground the other foot rest today . Tried a flapper disk on the angle grinder and it worked better than the wire wheel. Had to use the wire wheel is some places. The end of the foot rest was bent all to H**l. Can 't figure what someone could have hit to mangle it that bad. Had to use HF cut off tool on it oh well less weight. Inspected the seat pan ( just primer on it ) .It looked good from a 100 yards. Kind of reminded me off orange peal , but particles of paint were standing straight up. I wiped the seat pan down with acetone before painting yesterday and let it dry. Flapper wheel put back to work , acetone wipe down. Ate lunch and rested for an hour. I then hit with primer again. I not trying to make a trailer queen , just a worker. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #17194 Posted September 27, 2022 Well drive on down here and take all the pictures you want. Got a question @squonk does your C 160 have the hinged seat pan? If so are there grommets in the holes where bolts go ? 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #17195 Posted September 27, 2022 14 minutes ago, elcamino/wheelhorse said: Well drive on down here and take all the pictures you want. Got a question @squonk does your C 160 have the hinged seat pan? If so are there grommets in the holes where bolts go ? Them thar hinge holes should oughtta have a (nylon?) Bushing around the bolt. 1 Share this post Link to post Share on other sites
squonk 43,362 #17196 Posted September 27, 2022 19 minutes ago, elcamino/wheelhorse said: Well drive on down here and take all the pictures you want. Got a question @squonk does your C 160 have the hinged seat pan? If so are there grommets in the holes where bolts go ? It's hinged and there are bushings on the bolts. They are kinda wore out like you and me! 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #17197 Posted September 27, 2022 But you have worn out faster. Share this post Link to post Share on other sites
ebinmaine 71,853 #17198 Posted September 27, 2022 24 minutes ago, squonk said: It's hinged and there are bushings on the bolts. They are kinda wore out like you and me! I understood that reference. All too well. 😬 1 Share this post Link to post Share on other sites
squonk 43,362 #17199 Posted September 27, 2022 1 hour ago, elcamino/wheelhorse said: But you have worn out faster. Because I move faster! 1 Share this post Link to post Share on other sites
ebinmaine 71,853 #17200 Posted September 28, 2022 I puttered around here and there in the yard today. Messed with the wheels and brakes on Cinnamon Horse C160. Took apart the top of a K341. @gwest_ca can you please tell me what year and usage this might be? Trina took her momma shopping and then commenced to her own puttering around here. 9 1 Share this post Link to post Share on other sites
