ebinmaine 73,062 #17051 Posted September 18, 2022 9 minutes ago, AMC RULES said: Certainly not, the beginning 350 or so pages of this thread just mysteriously vanished that day. Yepp. I remember that. Share this post Link to post Share on other sites
Pullstart 67,110 #17052 Posted September 18, 2022 17 minutes ago, pfrederi said: The moles will be back.... Hopefully I’ll see ‘em pushing the dirt up too! POW 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,656 #17053 Posted September 18, 2022 11 minutes ago, Pullstart said: Hopefully I’ll see ‘em pushing the dirt up too! POW Caught @Pullstart on trail cam few minutes ago… 1 5 Share this post Link to post Share on other sites
Snoopy11 5,718 #17054 Posted September 18, 2022 Hooked up some "implements" and got some work done today! Each Horse pulls their own weight. One horsie: One horsie, two horsie Two horsie, three horsie... Don 4 3 Share this post Link to post Share on other sites
Hampton 95 #17055 Posted September 18, 2022 Finally got the rock shaft and tiller mount installed. Should be able to test and adjust it all tomorrow 5 Share this post Link to post Share on other sites
Pullstart 67,110 #17056 Posted September 18, 2022 @Heatingman that steering fan gear is the only other one I’ve seen with the holes in it. I’m not saying it’s rare, I just haven’t seen them much before.. I think your build deserves it’s own thread, so it won’t get lost in here! 5 1 Share this post Link to post Share on other sites
Ed Kennell 42,238 #17057 Posted September 18, 2022 3 hours ago, Heatingman said: @Ed Kennell What is that post mounted to? I want to do similar on my machine, and what material did you use for the pole? Conduit, copper, etc…? And does the wiring travel within the conduit? I used 1.5" PVC with the wiring inside and tapped into the tail light for power. The PVC slid inside steel conduit that was used on my rear weight /SMV sign bracket. 4 1 Share this post Link to post Share on other sites
oldblue1993 98 #17058 Posted September 19, 2022 Today I pulled out a winter project, both 701's have the dreaded 3rd gear issue. Well one is gonna be the guinea pig this winter and get the transmission opened up and see if I can repair one of em. 5 1 Share this post Link to post Share on other sites
ebinmaine 73,062 #17059 Posted September 19, 2022 30 minutes ago, oldblue1993 said: Today I pulled out a winter project, both 701's have the dreaded 3rd gear issue. Well one is gonna be the guinea pig this winter and get the transmission opened up and see if I can repair one of em. BOTH will be repairable. Getting into a Wheelhorse transmission is easy enough to do with basic hand tools and the knowledge base of Redsquare's members. 2 Share this post Link to post Share on other sites
Stormin 9,985 #17060 Posted September 19, 2022 Things haven't really gone to plan today. First of no photo's of the mod to the front mounting bar on the 42" deck. I did extend the locating fork but when I tried to fit it into the tachomatic, that was when I realised I'd made a boo boo. It wasn't that I should have extended, but the arms that attach to the deck. So I went to plan B. Remove the spacers I'd fitted to level the front end after I'd fitted the bigger diameter tyres. While doing that I noticed the left hand front wheel was well out of track. Why I don't know. I'll work that out at a later date. After I'd reset the tracking I decided to try some mowing. Things went reasonably well until the engine lost rev's. The rod from carb to governor arm had come adrift. Little circlip that holds it into the governor arm had disappeared. Took one off the C-125. While trying to fit that it went off to look for the missing one. Got a couple of small cable ties and that sorted that for now. Continued mowing the green and was just about to finish when the drive belt for the blades came off. That was when I said enough is enough. Removed the deck, cleaned it and the tractor and put them away. 3 4 Share this post Link to post Share on other sites
Handy Don 14,136 #17061 Posted September 19, 2022 17 minutes ago, Stormin said: Things haven't really gone to plan today ...gotta know when to hold 'em, know when to fold 'em... 1 Share this post Link to post Share on other sites
AMC RULES 37,211 #17062 Posted September 19, 2022 1 9 Share this post Link to post Share on other sites
ebinmaine 73,062 #17063 Posted September 19, 2022 6 minutes ago, AMC RULES said: Well now ain't that approximately an excellent transformation. How's the rust on the rest of that rig? 1 Share this post Link to post Share on other sites
AMC RULES 37,211 #17064 Posted September 19, 2022 Seat was the worst of it. 1 Share this post Link to post Share on other sites
kpinnc 14,754 #17065 Posted September 19, 2022 22 hours ago, Snoopy11 said: Two horsie, three horsie... Better watch out- these things tend to multiply if you aren't very careful... 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,878 #17066 Posted September 19, 2022 1 hour ago, AMC RULES said: Seat was the worst of it. The normal way of cleaning seems to work pretty good. 2 Share this post Link to post Share on other sites
Snoopy11 5,718 #17067 Posted September 19, 2022 5 minutes ago, kpinnc said: Better watch out- these things tend to multiply if you aren't very careful... I know, I know. They are about to conceive a behemoth if you haven't seen... https://www.wheelhorseforum.com/topic/100073-wheel-horse-718-z/?tab=comments#comment-1084631 Don 1 Share this post Link to post Share on other sites
AMC RULES 37,211 #17068 Posted September 19, 2022 32 minutes ago, EB-80/8inPA said: The normal way of cleaning seems to work pretty good. Sandblast cabinet. 3 1 Share this post Link to post Share on other sites
ebinmaine 73,062 #17069 Posted September 19, 2022 35 minutes ago, AMC RULES said: Sandblast cabinet. NIIIIICE. You get sick o' the cabinet I'll babysit that for ya... 1 Share this post Link to post Share on other sites
TonyToro 1,123 #17070 Posted September 20, 2022 @TonyToro Jr.and I worked on his pulling tractor (Last Minute) the past few days. We needed to add more weight to the tractor so he would be at 1050lbs with him driving. We got some heavy steel from the bargain bin at Logan Steel. I welded it all up and painted it flat black. We now have approx 110lbs hanging right under the gearbox. He also found some diamond plate there and wanted to make headlight cover. A couple upgrades done and hopefully they show a difference this Friday. 2 4 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #17071 Posted September 20, 2022 Love it it looks good 1 Share this post Link to post Share on other sites
Heatingman 971 #17072 Posted September 20, 2022 4 hours ago, AMC RULES said: Sandblast cabinet. What media are you using? What I use leaves a much more coarse finish. or were the pics after paint? Share this post Link to post Share on other sites
Heatingman 971 #17073 Posted September 20, 2022 (edited) Picked up a Wheelhorse dump cart, cleaned out the head on the motor, checked tappet clearance and inspected cylinder for scoring, and reassembled. Neglected to take a picture of the internals after cleaning. And gave the motor a coat of engine enamel. Edited September 20, 2022 by Heatingman 4 1 Share this post Link to post Share on other sites
kpinnc 14,754 #17074 Posted September 20, 2022 17 hours ago, Snoopy11 said: They are about to conceive a behemoth if you haven't seen... Yeah, that will be a monster! 1 Share this post Link to post Share on other sites
Ed Kennell 42,238 #17075 Posted September 20, 2022 (edited) I drained the diesel that has been soaking in the tranny for 2 weeks. It didn't look too bad. Probably flush again after I have it driving. Are these spindle gussets factory Richard? @953 nut Edited September 20, 2022 by Ed Kennell 3 Share this post Link to post Share on other sites
