oliver2-44 11,760 #15251 Posted April 12, 2022 (edited) 19 hours ago, OutdoorEnvy said: @OutdoorEnvy are you going to clear coat those now Edited April 13, 2022 by oliver2-44 1 Share this post Link to post Share on other sites
JoeM 10,315 #15252 Posted April 12, 2022 3 hours ago, Ed Kennell said: It's off What a shame, having one that tight and key that good having the seal to fail. It will take another thirty years to grow back! 8 Share this post Link to post Share on other sites
Ed Kennell 47,474 #15253 Posted April 12, 2022 20 minutes ago, JoeM said: It will take another thirty years to grow back! I could coat it with Iodine before assembly.....that should speed up the weld process. 7 Share this post Link to post Share on other sites
peter lena 10,080 #15254 Posted April 12, 2022 @Maxwell-8 good call on that type of cutter , that longer side bite and ground rocker outer jaw edge , gives you a very solid mechanical advantage , bet that first try on a lubricant soaked , key is a good feeling , pete 2 Share this post Link to post Share on other sites
Achto 32,816 #15255 Posted April 12, 2022 I woke my C-141 from its long winters nap. After checking the air in the tires and the fluids, I promptly put it to work pulling the lawn sweeper around. This tractor runs sooo sweet. You would never know that the engine was locked up tight when I got it 3yrs ago. After soaking the cylinder with ATF for a week it turned over easily by hand. Followed up by the usual "It's been sitting for ??" clean up and tune up, It's been running great ever since. Doesn't even smoke on start up. 5 9 Share this post Link to post Share on other sites
ebinmaine 80,811 #15256 Posted April 12, 2022 1 hour ago, Ed Kennell said: I could coat it with Iodine before assembly.....that should speed up the weld process. Excellent idea Ed. 39 minutes ago, Achto said: . After soaking the cylinder with ATF for a week it turned over easily by hand. Nice save Dan!!! 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,474 #15257 Posted April 12, 2022 15 minutes ago, ebinmaine said: Excellent idea Ed. It works, I have used Iodine to create brown finishes on musket barrels like The Brown Bess. 5 Share this post Link to post Share on other sites
WHX?? 58,254 #15258 Posted April 13, 2022 On 4/11/2022 at 3:55 PM, JoeM said: Worked on putting together the first set of duals. Those Farm Specialist tires are tough to work with when your not trying to bugger up the rims. Talk about a Jane Fonda workout! Nice Joe what did you end up for width? 6 & some change & how much in between? I like the staggered lug look. Share this post Link to post Share on other sites
JoeM 10,315 #15259 Posted April 13, 2022 7 minutes ago, WHX?? said: how much in between? I like the staggered lug look About an inch. I was thinking about taking them apart and taking a little off but I am concerned #2 gravel will stick in between the tires, then again, Im probably not really going to use it..... just for show. ??? I was thinking about the ride when I lined up the tires. They are stiff buggers. 3 Share this post Link to post Share on other sites
WHX?? 58,254 #15260 Posted April 13, 2022 I run just a couple of psi in the outsides and 8 to 10 on the inside. Helps a little. 4 Share this post Link to post Share on other sites
8ntruck 9,315 #15261 Posted April 13, 2022 (edited) I pulled the 14-8 out from its winter slumber. Took the front blade off and put the 42" SD on. Needed to add air in one of the tires and a bit of oil to the crank case. Started up like normal. Got to schedule an oil change, transmission oil change, and the replacement of a tie rod that I wired back together last fall during leaf cleanup. Edited April 13, 2022 by 8ntruck 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,654 #15262 Posted April 13, 2022 (edited) Double post… Edited April 13, 2022 by SylvanLakeWH Share this post Link to post Share on other sites
SylvanLakeWH 32,654 #15263 Posted April 13, 2022 10 minutes ago, WHX?? said: I run just a couple of psi in the outsides and 8 to 10 on the inside. Helps a little. 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #15264 Posted April 13, 2022 6 hours ago, Ed Kennell said: It's off. The key was OK and in place. I know pulling on that flange is not a good practice, but that is what I had at the time. For the next one, I'll make a proper puller or borrow Lynns. @lynnmor Next challenge...get the key out. I cut a small notch in the end to get a chisel under and was able to tap it loose. Alll cleaned up and nice sliding fit going back together. The new NAPA seal will be in tomorrow. Mike. @squonk, I gave your number 11124 to my local guy and he says the new NAPA # is 27SS2259. $9.69 each @Ed Kennell did you coat the axle with anti-seize before you put the hub back on ? Share this post Link to post Share on other sites
Ed Kennell 47,474 #15265 Posted April 13, 2022 30 minutes ago, Horse Newbie said: did you coat the axle Not yet, but I will when the seal is delivered. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,997 #15266 Posted April 13, 2022 I’m surprised the leaking seals didn’t help keep the rust at bay. Persistent paid off ! 2 Share this post Link to post Share on other sites
ebinmaine 80,811 #15267 Posted April 13, 2022 7 hours ago, 8ntruck said: replacement of a tie rod Go big. The holes are likely egged a bit. Drill or grind them the next size up. I went to a 7/16" double male heim joint for all 4 and had someone make up a 3/4" or 7/8" diameter center rod. Cost is similar and that will outlast even a Wheelhorse. McMaster Carr has the parts. 1 Share this post Link to post Share on other sites
Ed Kennell 47,474 #15268 Posted April 13, 2022 10 hours ago, Wheelhorse#1 said: I’m surprised the leaking seals didn’t help keep the rust at bay. Persistent paid off ! The hub had 36 years to brown weld fast to the axle. The leak just started a few weeks ago and it may have soaked loose in the next 36 years, but 78yos don't plan that far ahead. 4 2 Share this post Link to post Share on other sites
peter lena 10,080 #15269 Posted April 13, 2022 @Achto on your c-141, bet that would suck up a , aerosol lubrication rub down , that dry red , would be oil stained , spray down , let it soak in a day, rub down with clean cloth , till dry . do it again , patina saved ! ever try some rislone zinc in that ? 2 0z for each qt of oil . been using that in all my stuff ,and the running ese is very evident , those hot oil changes , are a real flush out , looks like black coal oil . good back and forth with you , stay sane , pete 1 Share this post Link to post Share on other sites
squonk 48,184 #15270 Posted April 13, 2022 Fitted the deck onto the 1075 for some old-school mowing yesterday. First time I can remember having to mow before Easter. 3 Share this post Link to post Share on other sites
WHX?? 58,254 #15271 Posted April 13, 2022 13 hours ago, Horse Newbie said: pulling on that flange is not a good practice Not so bad on that style hub Ed. 1 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,997 #15272 Posted April 13, 2022 49 minutes ago, WHX?? said: Not so bad on that style hub Ed. 10-4 When needed I always go with the beefier style hub.Much more meat on them ! 2 Share this post Link to post Share on other sites
JoeM 10,315 #15273 Posted April 13, 2022 15 hours ago, Horse Newbie said: did you coat the axle with anti-seize before you put the hub back NO NO NO Never! You want it to stay together, not come apart! An integral part of the attachment system is the hub surface grip area on the shaft. The set screws apply the tension not the retenson. That is why it is critical for the hub bore and shaft to be on size. The shaft and hub will hold the best dry. 1 1 Share this post Link to post Share on other sites
Achto 32,816 #15274 Posted April 13, 2022 (edited) 1 hour ago, JoeM said: NO NO NO Never! Another can o worms. I use never seize on my axles and have not had an issue. The set screw holds more than you know. Even a taper lock pulley that gets tighter on the shaft when you tighten the bolts will slide off if there is no set screw. Been there, seen it happen on a 3ft pulley attached to a 7ft radiator fan. BTW the set screw on this set up is only a 5/16-18. Edited April 13, 2022 by Achto 1 1 Share this post Link to post Share on other sites
WHX?? 58,254 #15275 Posted April 13, 2022 2 hours ago, Wheelhorse#1 said: I always go with the beefier style hub But I am a purist with the weaker star hubs... ... 1 hour ago, JoeM said: NO NO NO Never! Gotta side with Dan on this one Joe. When I had to re-open up a 5060 tranny that I restoed I had to re-pull hubs that I antied and were still a bugger to get off. We do always add second set screws and practice the religion of checking them regular for tightness & full length keys for the plow mules. 3 1 Share this post Link to post Share on other sites
