Similar Content-
			 By Vaughan32850 By Vaughan32850
 Let’s see all the RJ’s and suburbans that are in Europe / United Kingdom. Here’s my two RJ-58’s.
			By AndyZ
 Operator manual #A-5274
 Wiring
 6 pages 7.31MB
 Illustrated parts list link
 Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
 For 1970 electric clutch use Electro 12 model 1-7255
 2 pages 282KB
 We also have the 1971 tractor parts manual that followed
 1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
 1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
 New to this forum, Let’s see what other wheelhorse’s are in the UK, I’m in South Wales.
 RJ-58
 Lawn Ranger
 Commando 8
 C-120
 C-101
 C-160 Auto
			 By mmmmmdonuts By mmmmmdonuts
 My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
 Thoughts?
			 By ohiofarmer By ohiofarmer
 I am picking away at the k series on the raider10. Basically the Piston blew through at the ring grooves as it appears the rings may have had too large a gap. I can feel a slight erosion of the bore where the ring gaps All lined up, but not even close to catching a finger nail.
 I am hoping just hoping out the bore will get it back to round close enough that a ring job will do .
 In any case I can measure the bore and report back. Discipline demands that I do not tear this engine down right now as too many things are taking up my time.
 Just hoping the gurus can offer a bit of guidance
