Devin 27 #1 Posted December 16, 2017 I was driving it around after I got it running smooth and the front left wheel fell off turns out it didnt have the bearing or whatever inside of the rim around the spindle so it was just the rim on the spindle and obviously the inside of the rim is way bigger than the spindle so i dont know where to get the bearing 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,279 #2 Posted December 16, 2017 Try this RedSquare vendor: https://www.wheelhorsepartsandmore.com/bearings.html 1 Share this post Link to post Share on other sites
Devin 27 #3 Posted December 16, 2017 @SylvanLakeWH Thank you for the link but now I have the problem of not knowing what exactly it is I need 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #4 Posted December 16, 2017 1 hour ago, Devin said: @SylvanLakeWH Thank you for the link but now I have the problem of not knowing what exactly it is I need Devin, a suggestion. Just keep the ons thread going. So we dont have to bounce all over the place following your adventure. Sounds like your doing good. Glenn 2 Share this post Link to post Share on other sites
Devin 27 #5 Posted December 16, 2017 @JERSEYHAWG / GlennAlright it just seems like after a day nobody looks at the thread anymore thats why I've bern making new ones 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #6 Posted December 16, 2017 10 minutes ago, Devin said: @JERSEYHAWG / GlennAlright it just seems like after a day nobody looks at the thread anymore thats why I've bern making new ones That's the problem to many threads. It's like jumping jacks. Glenn 1 Share this post Link to post Share on other sites
JPWH 6,334 #7 Posted December 16, 2017 Very time you add to your thread it will go back to the top. 2 1 Share this post Link to post Share on other sites
AMC RULES 37,195 #8 Posted December 17, 2017 Here you go Devin... you're all consolidated in one place now. 2 2 Share this post Link to post Share on other sites
AMC RULES 37,195 #9 Posted December 17, 2017 (edited) Devin, I think you'll find the C-175 is a beast of a machine...well worth all your hard effort to get it back up, and running. Edited December 17, 2017 by AMC RULES 1 1 Share this post Link to post Share on other sites
Devin 27 #10 Posted December 17, 2017 @AMC RULES It is and its fast I just gotta figure out what it is i need to fix that wheel Share this post Link to post Share on other sites
AMC RULES 37,195 #11 Posted December 17, 2017 Look at your other (good) wheel Devin... your missing part...looks like this? 1 Share this post Link to post Share on other sites
Devin 27 #12 Posted December 17, 2017 @AMC RULES There is so much grease I cant tell but I'm 90% sure that's it because I have never seen that in the broken wheel Share this post Link to post Share on other sites
AMC RULES 37,195 #13 Posted December 17, 2017 Only one way to find out Devin. Raise the front of your tractor, remove both front wheels... clean 'em up, do your inspection, find out what you're working with, or need. 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #14 Posted December 17, 2017 2 hours ago, Devin said: @AMC RULES It is and its fast I just gotta figure out what it is i need to fix that wheel I missed something, whats wrong with your wheel? Wobbly, loose? Glenn Craig gives good information, pay heed to him. Share this post Link to post Share on other sites
Devin 27 #15 Posted December 17, 2017 @JERSEYHAWG / GlennYes its wobbly and loose its fallen off twice and actually the second time i couldn't find the piece that holds it on so i need a new one of those little clamp things to hold it on as well unless i can find the original one but that is very unlikely ij the grass Share this post Link to post Share on other sites
bmsgaffer 2,053 #16 Posted December 22, 2017 That is called a C-clip, should be 3/4". Snap ring with appropriate pliers will hold the best if you have them. There is a VERY good chance that if you ran the wheel without bearings the wheel itself where the bearings seat will be damaged. Your new bearings will fall right out. Make sure that when you put the new bearings it that you gently tap the metal around the bearing so that it fits tightly and evenly, otherwise look to get a new used wheel. Also check your spindle to be sure its not worn out and damaged. You will ruin all your new bearings if it is. All of this stuff can be obtained from vendors on here like @Kelly or @A-Z Tractor or many people if you sift through the sale ads or place a wanted ad. 1 1 Share this post Link to post Share on other sites
Devin 27 #17 Posted December 22, 2017 1 hour ago, bmsgaffer said: That is called a C-clip, should be 3/4". Snap ring with appropriate pliers will hold the best if you have them. There is a VERY good chance that if you ran the wheel without bearings the wheel itself where the bearings seat will be damaged. Your new bearings will fall right out. Make sure that when you put the new bearings it that you gently tap the metal around the bearing so that it fits tightly and evenly, otherwise look to get a new used wheel. Also check your spindle to be sure its not worn out and damaged. You will ruin all your new bearings if it is. All of this stuff can be obtained from vendors on here like @Kelly or @A-Z Tractor or many people if you sift through the sale ads or place a wanted ad. Alright thank you the spindle a the rim are both still in great shape neither are damaged at all Share this post Link to post Share on other sites
953 nut 59,689 #18 Posted December 22, 2017 6 hours ago, bmsgaffer said: C-clip, should be 3/4". Snap ring Never had a 417, but both 418s and 310 all have cotter keys or a hairpin key. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #19 Posted December 22, 2017 Yes, its the C clip / snap ring, just had mine apart last week. Theres special pliars made for it, makes the removal and install a whole lot easier. Glenn Share this post Link to post Share on other sites
pfrederi 18,624 #20 Posted December 23, 2017 Wheel Horse kept changing the way hubs were secured. Cotter pins and hairpins E Clips External Snap rings 3/8" Bolts with a plastic plug in the bolt to lock the thread They called it Eslock... 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,498 #21 Posted December 23, 2017 E clip. I stand corrected. But that's it, how my wheel is secured. Glenn Share this post Link to post Share on other sites
Devin 27 #22 Posted December 23, 2017 Mine uses the external snap ring i should be able to find it at Wal-Mart if the website correct Share this post Link to post Share on other sites
953 nut 59,689 #23 Posted December 23, 2017 1 hour ago, Devin said: Mine uses the external snap ring i should be able to find it at Wal-Mart if the website correct Never have seen them at my Wal-Mart, but ACE Hardware or any good auto parts store will stock them. 1 Share this post Link to post Share on other sites
6wheeler 669 #24 Posted December 23, 2017 (edited) Both the external snap ring or C-clip will work. Incidentally, a body style washer with a 3/4" hole over the spindle and clipped can help finish a job without the wheel falling off. Taking the 5th on why I know that . If the hub didn't get too chewed up? Again, Taking the 5th . The bearings are easy to replace. Good Luck Pat Edited December 23, 2017 by 6wheeler 1 1 Share this post Link to post Share on other sites
953 nut 59,689 #25 Posted December 23, 2017 18 minutes ago, 6wheeler said: washer with a 5/8"s hole over the spindle and clipped can help finish a job without the wheel falling off. The spindle is 3/4" OD. 1 Share this post Link to post Share on other sites
