Similar Content
By BruceK
Can I pick some brains please? It's just a thought at this stage but I'm wondering whether I could upgrade my C161 so I can get rid of my old Ferguson TEF tractor and topper to save on space and tidy up my outdoor area a bit. The trouble is I need to regularly cut a 2 acre paddock so want to be able to tow a decent finishing mower like a 4ft Wessex or something similar. Has anyone tried fitting a mechanical PTO to an old machine like this or will I have to stick to a self-powered tow-behind mower for the rough work? I could investigate putting in a more powerful engine if I can find one. Any ideas would be welcome. Thanks in advance
By TractorEd
I’ve decided to start this thread to keep this info together. It’s about this C-161 I have.
It showed up at my house one day around mid-2021 as a “parts” tractor.
I had no idea this was going to be left at my door, abandoned, tired, unwanted. I can’t remember a lot of what I was being told about it as I was staring at it wondering why I was chosen, apparently, as the one who was to strip it of it’s organs and transplant them into some other “being”.
By the time those who brought it left, even though I never said it until just now, I knew I was going to attempt to resuscitate her.
No longer an “it” she was certainly worthy of a shot at another life. 16 HP Kohler, Sunstrand Hydro and hydraulic lift! I had already fallen in love with the C-100 I grew up with that I later inherited, but this girl had something extra, something different about her that I thought was …
appealing.
Parts tractor? Not if I can $@%# help it!
She was glistening. Maybe it had something to do with the rain that day on the ride over. But she IS glistening!
By Team70R
Well I scored a gently used Briggs 900 series to repower my new 606! Doesn't have an air cleaner cover for it so I zip tied the filter on after I cleaned all the junk out of the carb and it ran good. Now it will rev slow and die after it idles a second. I'm guessing there's some more gunk in the carb that I either missed or broke free??
By elicountryboy1996
I have a wheel horse c161 Hydro, and I want to put on a stack type exhaust as the muffler that is currently on it appears to be to large and burns the paint on one side of the hood, what will I need to do this job, such as pipe size and stuff.
The picture is what I want my muffler and pipe to look like, it is not my tractor
By gwess
Hello,
So i finally got my Wheel Horse running after some work. I have rebuilt the carburetor and now I need to fine tune it. However, I have an issue. My engine idles lowest, but not all the way, at mid throttle. If i push the throttle down all the way my engine revs back up. While i go through the throttle i can witness the idle adjustment spring body go like this:
Throttle all the way open, Idle Spring and body all the way up.
Throttle midway, Idle spring and body close to all the way down.
Throttle closed, idle spring goes back up a bit to midway.
Any thoughts would be great.
Thank you,
