Similar Content
By Rob R
Hi Guys my C81 has a 38 dual blade, side discharge mower deck (# 0537SC01) The deck belt also goes around the mandrels through the mule drive and also to the PTO so it's a huge belt. The current belt is stretched and ready to go. I believe it is around 1/2 X 142 inches but not sure was hoping one of you might have the correct size. Much appreciated. Rob
By Bill D
Found these at Lowe's. Same belts as TSC, just different packaging. The 86" I got was on clearance and is not being stocked anymore. They had sizes from 87" to 109" in 1/2". Not a lot of 5/8" belts that would be useful for our tractors.
By Ifixoldjunk
I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
By Tim Fenn
I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
By Shea Worden
Hey guys, my wheelhorse c81 got a new transmission last year and now it’s grinding when I drive. First thing the brake pulley is on a higher shaft and doesn’t work with the c81 brake rod and hardware. Second the bearing behind the intake pulleyhas fallen out, which I assume is the grinding sound. Is there a way I can fix it without taking the whole transmission apart? I don’t have enough knowledge to do that kind of repair. Thanks so much -Shea
