Similar Content
By Bbo44
SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
By Berco
Hello all. My battery in my 520LXI was going out, the lights would come on but the engine would not turn over. I put a 1.5 amp truckle charger on the battery when i left for a 4 days trip. I come back and the same. I also noticed i left the key in the run position (the hour meter did not run). I swap out batteries and now the mower is completely dead. When i turn the key - nothing. I verify the battery it good (13.04v), negative is connected to the engine block, voltage is good on the solenoid side of the starter. I out the key to run and try to jump to see if i can start and nothing. Not even a spark. I have used this mover for years and has 500 hours. Could the ignition switch or brake switch be bad? The seat switch is jumped.What else could cause my mower to be dead? Thank you in advance.
By Bill Murray
Looking for a replacement headlight assembly. I just bought a 520XI with a snowblower and I’m looking to fix the broken headlight before winter. Not sure if anybody knows of anybody selling one. I’ve been looking for a few months now. Thanks for any help.
By ToroMan
Good afternoon, looking for some help regarding a plow assembly for a 1999 520xi model # 73542. I'm told that a traditional Wheel Horse plow assembly will not fit this tractor, that the xi series requires a special plow assembly. Problem is, most of the people selling plow assemblies don't seem to know what they have, and I don't know what I need! I have included the supposed model numbers pulled from the Toro website, including that of a retrofit kit, but I'm not sure what that retrofit kit does! Does it enable me to fit a traditional Wheel Horse plow to an xi model? Don't know. One guy selling a plow knew what type of plow he had and told me it would not fit my tractor, stating "Lift link and handle are in the wrong locations."
Any help would be greatly appreciated. Just need to know what the hell I'm looking for, which might help me find it!
From Toro site:
Model #: 79355
48" Snow/Dozer Blade
Model #: 95-4090
48" Dozer Blade Retrofit Kit
Thanks!!!
By Berco
I have a transaxle from a 518XI that i have as a spare. I would like to put some caps on the two open hydraulic lines, but i am having some hard time figuring out the thread and type to mate with the existing tubing. Does anyone know the specs for can point me to a fitting that will work? thanks!
