Hoffertot
86-87 42" center pulley assembly
Hoffertot
Hello everyone,
I recently had some issues with the middle blade cutting grass while I was mowing. I decided to take the mower deck off. I believe I have found the problem, and that would be a missing bushing or spacer, but I can't seem to find it on any of the assembly documents I have. Could anyone help me verify if my assumptions are correct, or assist me if you see something else that is wrong? Here are some pictures to hopefully better show what I am referring to. The mower model I own is a 86 Wheel Horse 312-8 manual mower.
The first image is the mower deck itself, presumably a 0542ms04 ( this is the 42" deck). No identifiers on the actual deck.
The second image shows the pulley being referenced and the mount in which is suppose to attach to.
The third image is hard to see, but the actual spindle shaft sticks up higher that the pulley so tightening down the top bolt does not actually secure the pulley in place. This causes the pulley to spin with the belt, but the pulley is loose with respect to the spindle shaft.
The fourth image is the assembly drawing I have been referencing to troubleshoot the issue.
Any help or guidance would be appreciated. And this is my first post in the forums so if this has been answered before, or this post should be moved, please let me know.
Thanks!
gwest_ca
Suspect the spindle assemblies are like this one or older
The spindle and pulley are known as the double-D series with a 5/8" x 3/4" hole.
The mower blade center hole should be the same.
Garry
N3PUY
How is it possible for the pulley to spin on the shaft if both are "double D" ?
I'm guessing the pulley "double D" is worn into a circle.  I think I talked to a guy up the road last year that had the same problem.
A new pulley is required.  :think:
Hoffertot
Thanks for the quick responses. The other 2 pulleys are both double D onto the spindle shaft. This double pulley is not a double D shape, and this is why I wan wondering if I was missing an insert or adapter to mount to this pulley. The thickness of the part that slides over the shaft(shown in the picture below) is nearly an inch thick, I can't imagine it would spin and round the D shaft like that. I guess there is potential that it had the wrong pulley assembly installed on it when I purchased the unit.
There is a lot of slop between the shaft and pulley ID as shown in this picture. It was just being clamped down with a bolt and washer.
This picture shows the thickness of the pulley ID.
I had been mowing with this for about 2 years, and if that is incorrect, I'm surprised it lasted that long.
Thanks.
N3PUY
I would say that it was the correct "double D" pulley and has rounded out.  It is the same thing that happened to the neighbor's pulley.
The STEEL shaft is harder than the cast IRON pulley.
Hoffertot
Garry
Thanks for the manual Garry, you happened to post the one for a 77, is this what year you determined it to be from looking at the pictures? Or did you mean to send an 87 one? Are the pulleys the same?
gwest_ca
I think that was the last 42" deck model to use the double-D shafts. There is a list of decks on that page in the order they were produced so yours could be older and one of those.
There is also pages that show the spindle assemblies over the years that could be used to upgrade the assemblies. Nothing saying the newer decks could not have received older used replacements.
This is the next model of deck that was produced and it uses 3/4" spindle shafts and they are both 1977 models - a mid model year change.
Garry
RJS    Cutter
I am having a similar problem.  I hit a stump while cutting now the middle spindle shaft seems to not be attached to the pulley.  Is there a pin or key that may be sheared or was this the final straw that damaged the assembly.  I have not torn things apart yet, just figured it out and am at the research stage.  Any information you can give me would be appreciated.
Thank you.
Hoffertot
Thank you.
Sorry for the late reply. I think I have come to verdict that these guys are correct in saying that the double "D" pulley has rounded out on my rig. The part number for the pulley that replaces it is a Toro 106847, but I have not had a lot of luck finding any online. Seems like they are quite rare these days. It appears there is a round hole version of this pulley as well, but I am not entirely sure on how it is attached. Maybe press fit on the shaft, set screws, or just clamped? Maybe once you pull it apart, it will be obvious what the issue is.
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      I need the large metal pulley that houses the needle bearing and ball bearing with the two grooves.  The outer bearing seemingly wallowed out its hole and my welder guy cannot revive it.
      Shipping to Erie PA. 16509.
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 20 minutes south of Rt 80 or 15 minutes north of Rt 78 near Rt 33.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case broke a small piece off (about 1” long by 1/4” wide) on one side of the center flange and was repaired with JB Weld.
      Solid 42” side discharge deck (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included. Deck works as it should and is ready to cut.
      42” snow/dozer blade (Model 86-42BC01) with Rear weights, tire chains and hardware. Blade angles left and right and lifts correctly and is ready to plow.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $325 Or Best Offer - Deck/Blade/Weights/Parts alone are worth that!
      Will deliver within 50 miles of zip 18064. Delivery over 50 miles is negotiable.
      Please PM to contact
      HH120_running.mp4
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
