12 hp Kohler
Suburban or Rj
12 hp Kohler
I saw this wheel horse for sale and I am trying to figure out if it is a suburban or Rj,parts on it look like a suburban and other parts look like an Rj 58 or 59, what are your opinions i would really like to know? I know the front axle is from a suburban but not sure about other parts.
IMG_1242.thumb.PNG.dd4c64713fcbe16535d5e94b78f60550.PNGIMG_1243.thumb.PNG.fdbcba452f179eaad2dbae7121ebf7b5.PNGIMG_1244.thumb.PNG.a47dae950a4f386da46d89a49a9af81a.PNGIMG_1245.thumb.PNG.41745a0540f2bad58a6f8099c43beac3.PNG
RedRanger
1961 Suburban 401 or a 400 with the wrong hood.
Def a sub. with 60 foot pads.
Steering column is in the wrong place.
Edited by RedRanger
AlwaysLookin80
Some one ruined it and moved the hood stand up and chopped up the hood, and wrong rear wheels. It's a suburban, and I'd only give 150 for it only because it's got a 4hp kohler 90 or 91 on it
RedRanger
Looks like they moved the engine forward which forced them to move the hood stand which forced them to butcher the steering rod which caused them to butcher the hood.....
Makes you wonder why people do what they do?
Depending how bad they butchered the steering, it could be fixed....with a replacement hood.
I'd agree on your price.  Needs to much fixin' to pay much more.
AlwaysLookin80
Yes sir, and actually I'd probably pass on it anyway at that price. Lol. To big a project. I'd do a C note probably to have the engine as a back up for something else I come across needing a engine.
Even looks like the gas tank is gone too
The original one anyway
953 nut
Front tires and rims are in good shape, few other good parts and pieces but as proud as sellers are of good hoods for suburbans it wouldn't be a good restoration candidate.   :twocents-02cents:
12 hp Kohler
Ok, the add says it's a 59 wheel horse and that's it, thanks for the info guys
RedRanger
Definitely not a 59 and not a RJ.
It's a 60 or 61.
My bet is on a 1961 401 based on the cut up hood and Kohler, but it also has 60 foot rests and 60 seat which could easily be bolted on.
Probably has about $300 in parts on it if it was to be parted out, assuming it runs good.
If you could find a cheap hood in nice shape (IF), it could be put back together.
Could be a good project, time permitting, but would probably cost more than it would be worth.
If you want a complete original, I'd keep looking.
If you want a project and not concerned with the cost then it has possibilities.
my $.02.
Heck, I've got a complete one with more invested than it's worth!  :lol:
Edited by RedRanger
Aldon
 No kidding. The one I saw recently you might find a whole project tractor and get the hood for free...
ACman
If I'm thinking the same one ... :ROTF:
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      21259 - F30-9 trans casting date = June 30, 1959
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • Keaton
      By Keaton
      i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • Jennifer
      By Jennifer
      Well my husband got new grownup toys!  Lol. Just wanted to post them on here to share!  Sure most seen for sale but they arrived yesterday at our back door glad we found them before it rained again!  Not sure why delivery person made the effort to go to the back of the house…. 🤔🤯
