Vernon 3 #1 Posted May 22, 2017 (edited) Hello I'm new here and need help. A friend brought me a 953 that he picked up to fix up for him and I got it running great, Even painted it for him. It has a cycle mower on it. Did a bunch of work on it . I was trying it out and it got stuck in gear and wouldn't come out so pull transmission out and pulled gear stick out and took a screw driver and got it out of gear. thought everything was ok until my wife says is this a crack in the rear of the rear end and sure enough it was.After all this work. Is there anything I can replace this transmission with ? I think this transmission is a 5047. Any help would be appreciated. Edited May 23, 2017 by Vernon 2 Share this post Link to post Share on other sites
WHX?? 58,324 #2 Posted May 22, 2017 Vernon, you have come to the right place for info on that transmission and rest assured others more knowledgeable, @953 nut, and @stevasaurus come to mind, than me on the intricacies of a 953 will be along. We might want to see pictures of that crack, it's possible it can be repaired. 4 Share this post Link to post Share on other sites
stevasaurus 23,861 #3 Posted May 22, 2017 Vernon, welcome to Red Square. Actually, the transmission (if original) would be a #5045. The #5047 would be the transmission that was used in it's place the next year. I am not sure what the difference would be between the 2 transmissions...it may be negledgeable (sp) and not even note worthy. Those transmissions are considered heavy duty and both have the bevel gear differential. Like Jim said...let us see some pictures of the crack...depending on how bad and where it is, it may be braised or welded. Transmissions that would bolt right in to replace what you have would be the #5045, #5047, #5051, #5058 and #5059. You could also find someone with a spare case or half of one. There is a reason it cracked...need to check all the pieces and see if anything stands out. Here is the manual for your transmission...you want to look at Section II. Let us know. Just click on the link below. 492-4004.pdf 2 Share this post Link to post Share on other sites
Vernon 3 #4 Posted May 22, 2017 Thanks for the quick comeback. I will take a pic. And tear it apart. I have a welding and machine shop so I'm not worried about welding welding the case. I'll take a pic when its apart. B a day before I can get it done. Thanks this is Neat forum 1 Share this post Link to post Share on other sites
WHX?? 58,324 #5 Posted May 22, 2017 1 hour ago, Vernon said: this is Neat forum Thank you Vern, This is the best place for anything related. These are really easy units to work on and other members here have parts & knowledge so no worry there. We like to think these transmissions are saveable. Yes let us know if you need a hand. 2 Share this post Link to post Share on other sites
stevasaurus 23,861 #6 Posted May 22, 2017 Here is a good thread with videos about putting together a transmission that is kind of like yours. This one has the regular differential with spider gears, but the rest is just like yours. It may help you figure out why the crack. Make sure you have the shallow side down when you open it up...also pull out the shifter. 1 Share this post Link to post Share on other sites
953 nut 70,057 #7 Posted May 22, 2017 2 hours ago, Vernon said: this is Neat forum With a little ingenuity you could transplant any Transaxle with 1 1/8" axles to a 953. One of mine has an eight speed from a 1967 model 1267 and all that was required was a couple of new holes in the frame mounting plate and swapping the axles to it (they are a bit longer. If the transmission if functioning properly you can probably save the one you have by welding it. Anxiously awaiting pictures! 3 Share this post Link to post Share on other sites
TravelinJavelin 621 #8 Posted May 23, 2017 hey there 953 nut would you do a thread on a tranny transplant of a 953 and what it took to do it? 1 Share this post Link to post Share on other sites
953 nut 70,057 #9 Posted May 23, 2017 I did this over a dozen years ago and didn't take any pictures. Share this post Link to post Share on other sites
TravelinJavelin 621 #10 Posted May 23, 2017 oh man that's a bummer but I thought i'd ask you seem like the expert on these models but I guess how hard was it to modify the new holes? to mate with the but plate of the frame? Share this post Link to post Share on other sites
953 nut 70,057 #11 Posted May 23, 2017 1 minute ago, TravelinJavelin said: how hard was it to modify the new holes? Just a bit of shade tree technology. Took a piece of file folder paper and taped it to the transaxle mounting plate on the frame and used a ball peen hammer to make holes where the bolt holes were (just like making a gasket). Next I lined up the holes on the transmission and bolted it in place with the two that lined up. Used the ball peen to make new holes in the paper and returned it to the mount. If memory serves me right I drilled one new hole and used a die grinder to elongate another. 3 Share this post Link to post Share on other sites
Vernon 3 #12 Posted May 23, 2017 Here are the pics. Where can I find a transmission or parts Share this post Link to post Share on other sites
953 nut 70,057 #13 Posted May 23, 2017 (edited) 6 hours ago, Vernon said: Here are the pics. Where can I find a transmission or parts Pictures didn't attach. I see that the photos are attached to post #1. Edited May 23, 2017 by 953 nut Share this post Link to post Share on other sites
stevasaurus 23,861 #14 Posted May 23, 2017 Put a want ad in the Classified Section on the main page. Check our vendors list...maybe @A-Z Tractor has the parts...send him a PM (personal message). @racinfool40 (Mike) may also have what you need...find him either here or Facebook at Wheel Horse Junkies. Share this post Link to post Share on other sites
953 nut 70,057 #15 Posted May 23, 2017 looks like we know what caused the crack in the case. Steve listed a lot of potential donors for a transaxle in post #3. As said before, you will need to use your axles and probably the shift lever too. At first I had hoped a little JB Weld on the crack would do the trick, but this is a bit beyond that. Hang on to the good parts, they may be able to save another horse down the line. 2 Share this post Link to post Share on other sites
Vernon 3 #16 Posted May 24, 2017 Thanks for all your help. I'm new to these wheelhorses. What model of tractors used transmissions that would work in this 953. I'm kinda lost when it comes to that. Share this post Link to post Share on other sites
stevasaurus 23,861 #17 Posted May 24, 2017 In that PDF in post #3 that I put in there...on page 4 is a transmission usage chart...I also listed the transmissions that should bolt right in in that post. You just need to open that up and take a look to get your answer. 1 Share this post Link to post Share on other sites
