Duramax7man7
Quality Replacement Parts
Duramax7man7
Just wanted to give a public thank you to Lincoln at A-Z Tractors for sending me some quality used parts for my 1994 314h and 1991 520h!
Parts list...
520h- Paring brake lever, hood latch, air cleaner sensor and rear 1-1/8" hub
314h- Fuel tank, 2x headlights, steering collar and steering wheel
 All parts arrived with quick shipping as well as packed very well and all were quality products!
 Thanks a bunch sir! Will be coming to you for future purchases as well.
 God Bless you and yours!
  • Like 9
953 nut
A-Z will also be delivering to the Big Show next month, though I don't know if he has any more room on the truck after filling my order!  :ychain:
  • Like 4
T-Mo
I ordered a choke cable from him for my 416-8 and the prices were good, the shipping was fast, and the item was great.  A great vendor in my opinion.
denco7920
A-Z shipments are timely and great. Got my steering spindles and tie rods today!
Duramax7man7
Nice! I will be placing more orders with him that's for sure.
  • Similar Content
    • GeoC-120
      By GeoC-120
      The time has come for me to part with my trusty Wheel Horse and find it a new home. I am the second owner (since 2003) and it has always been stored in a garage.
      I am located about 2.5 hours Northeast and 140 miles from the Big Show for those who are attending.
      1975 C-120 Special, 8-speed (Model 1-0375, Ser. # 133357). Running (no smoke) 12 hp Tecumseh (Model HH120-120180E, rebuilt 1986). Rebuilt carb, new fuel pump, and new ignition module (in 2006). Good used replacement tank, original tank is included in the sale.  Brand-new battery, fuel filter, and shutoff valve installed 5/26. The transaxle case is cracked near the center flange and repaired with JB Weld.
      Solid 42” side discharge deck  (Model 5-1010) bearings replaced in 2005. Extra set of Gator mulching blades and spare hi-lift blades included.
      42” snow/dozer blade (Model 86-42bc010),  with Rear weights, tire chains and hardware.
      Parts: 4 NOS belts and 2 good used belts, NOS taillight lenses, used starter, used ignition module, more (see pic).
      1975 C Series Owner’s manual, 1975 WH accessory catalog, 5-1010 deck manual, original HH-120 manual, updated Tecumseh HH-120 technicians handbook.
      Selling entire package for $345.
      Deck/Blade/Weights/Parts alone are worth that!
      Please PM to contact
      HH120_running.mp4
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, the gas cylinder that assists my clutch in my 92 is spent. I’ve heard of people replacing the cylinder with a spring. I searched here and didn’t find a direct answer. What size, and number at a hardware store etc… is it? Thanks!
    • blu_stang
      By blu_stang
      Hi All, It's time for me to sell the D-250 I've had for the last 8 years.  It’s useable as is, or would be a great project bundle for further restoration.
      I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains.  Also included is an extensive part collection, nearly a second tractor worth.  I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine.  I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
      Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts.  There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
      The tractor engine runs smooth.  There are around 1050 original hours on it; It’s a 1976 edition.  Everything works, except the dash lights and the rear lights (disconnected b/c of fender).  I just haven't sorted out the wiring, but it is all there.  Headlights are good and working, as are all of the gears and levers.  The four tires are nearly new Carlisle Multi Trac, with nubs still on them.  The rear tires have been filled (ballasted) with Rim Guard for extra traction.  The hydraulic pump, front PTO clutch and brakes operate but could use a tune up.  I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat.  The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings.  The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows.  The rear fender needs a repair, but all pieces are available.  The plow and tiller are due for restoration.  The Points, Condenser and rotor have all been replaced and tuned in.  The battery is good.  I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours.  The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
      Here's a video of me mowing, this past summer.
      Transporting this haul in one trip will require a pickup truck and a large trailer.
    • Merl
      By Merl
      Newbie here and I have a 520-H that runs, but needs some TLC and some minor things fixed and/or adjusted. It comes with a like new tiller that I believe has only been used once and has paint still on the tines. I am the 2nd owner and I have personally never used the tiller. I am selling my previous home that I rent and where it has been stored. My current home's yard just isn't big enough to use a rider and I need to find a new home for it. I want to sell them together to simplify and I need them gone in the next 2 weeks. Please reach out with any questions and I'll do my best to answer. I am definitely not as knowledgeable as most of you on this forum, but figured somebody would like to fix it up, part it out and/or needs a tiller. Please email or text.
    • decvt79
      By decvt79
      I recently posted about issues with my transmission and have now identified the issue.   I removed the transmission cover and found that the final pinion bearing had failed.   Bearings and race in bottom of cover.   Now need to find replacement bearing and also a new filter.   Bearing part number from Toro is 93-0446 and is stamped with “Japan Nachi 6203”.  The gasket is Toro # 93-0478.   Any help verifying these part numbers for a TORO 270H model 72106 and also locating replacement parts or equivalents would be greatly appreciated.  My transmission serial number is 049132.  Thank you!
