wallfish 20,042 #326 Posted May 12, 2018 6 hours ago, 19richie66 said: Plus I need to do some cleanup. I’m losing parts When you loose enough of them, and then go look'n for that one you now need, you'll find enough others to build another custom and get inspired! BUT you need to get finished the project which needed the part you were searching for in the first place which is now the only part you CAN"T find. It's quite a conundrum. 1 5 Share this post Link to post Share on other sites
953 nut 66,599 #327 Posted May 12, 2018 2 minutes ago, wallfish said: When you loose enough of them, and then go look'n for that one you now need, you'll find enough others to build another custom and get inspired! BUT you need to get finished the project which needed the part you were searching for in the first place which is now the only part you CAN"T find. It's quite a conundrum. 1 Share this post Link to post Share on other sites
wallfish 20,042 #328 Posted May 12, 2018 (edited) @953 nutIs that just a polite way of say'n I'm full of --it? Edited May 12, 2018 by wallfish 5 Share this post Link to post Share on other sites
19richie66 17,892 #329 Posted May 12, 2018 Lost me at conundrum 7 Share this post Link to post Share on other sites
squonk 46,859 #330 Posted May 12, 2018 What's a tractor without a few dents! 2 Share this post Link to post Share on other sites
squonk 46,859 #331 Posted May 12, 2018 I like the looks of that with just a motor, steering wheel, seat and a Rat Fink Shifter! 2 1 Share this post Link to post Share on other sites
19richie66 17,892 #332 Posted May 12, 2018 Well she’s a little farther along today. Waiting on some muscle to help me set the engine in it. 3 8 Share this post Link to post Share on other sites
19richie66 17,892 #333 Posted May 12, 2018 @squonk that’s as close as I can get. 2 7 1 Share this post Link to post Share on other sites
squonk 46,859 #334 Posted May 12, 2018 Shoulda put the chair in it! 3 Share this post Link to post Share on other sites
Aldon 4,832 #335 Posted May 12, 2018 Looks great 2 1 Share this post Link to post Share on other sites
953 nut 66,599 #336 Posted May 12, 2018 Gonna get a few questions about your Eaton from those who haven't been following along! 1 2 Share this post Link to post Share on other sites
WHX?? 56,847 #337 Posted May 12, 2018 Not a filter Richard ... that's the makings of the cup holder! 3 Share this post Link to post Share on other sites
19richie66 17,892 #338 Posted May 12, 2018 It wouldn’t fit on the other side with the 3point valve there. Im sorry but I tried. 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #339 Posted May 13, 2018 Can't wait to see how your power steering set up works. I have a one from a super cub and it should be very similar. Looking good by the way! Randy 1 Share this post Link to post Share on other sites
19richie66 17,892 #340 Posted May 13, 2018 3 minutes ago, RandyLittrell said: Can't wait to see how your power steering set up works. I have a one from a super cub and it should be very similar. Looking good by the way! Randy Thanks @RandyLittrell. It worked fantastic in the tractor it came out of so if it works like it did, I will be tickled red. The only problem I forsee is when my son welded the -6 fittings on the lines, I didn’t realize there are o-rings between the end fitting and the tube. I removed the outer ones but didn’t know about the inner. I thought the ends were part of the tube. Worse case I have to remove them and replace the o-ring and reflare and flatten the tube end. Already spoke to a guy that did the same thing to his cub 4x4 and he has had no problems since. We’ll see. 👍 3 Share this post Link to post Share on other sites
19richie66 17,892 #341 Posted May 13, 2018 13 hours ago, WHX17 said: Not a filter Richard ... that's the makings of the cup holder! Not gonna lie @WHX17 I have thought about where to put one. 2 2 Share this post Link to post Share on other sites
Achto 31,898 #342 Posted May 14, 2018 Been quietly following along. It's looking great so far. 3 1 Share this post Link to post Share on other sites
ebinmaine 79,144 #343 Posted May 14, 2018 9 minutes ago, Achto said: Been quietly following along. It's looking great so far. And, what he said. 1 1 Share this post Link to post Share on other sites
19richie66 17,892 #344 Posted May 14, 2018 Thanks guys. 2 Share this post Link to post Share on other sites
bmsgaffer 2,071 #345 Posted May 14, 2018 That thing is awesome! With all those hydraulics though on an Eaton, you may consider putting in a little thermostatic oil cooler and electric fan... I have a 522xi and the transaxle gets toasty hot with the power steering and the hydro rear end, and mine had a hard life running around a 60" deck for a guy who didnt care much. I think heat is the killer on these things. 1 Share this post Link to post Share on other sites
19richie66 17,892 #346 Posted May 14, 2018 Thanks Brandon. I have a 10” electric fan I thought about mounting in the fender panel blowing on the hydrostat fins. Not sure where I could mount a cooler without having to replumb it. May have room under the seat if I went with something like a small tranny cooler and computer sized fan. Thats the return side and I would possibly only need one more hose. Ill see how it goes. Also there was a sender in the bottom of the transaxle for a light I guess. Thought about putting in a trans heat guage using that hole. 3 Share this post Link to post Share on other sites
ebinmaine 79,144 #347 Posted May 14, 2018 8 minutes ago, 19richie66 said: Also there was a sender in the bottom of the transaxle for a light I guess. ....Thought about ...... putting in a trans heat guage using that hole. Richie, I don't think that is a - thought about. Especially in your warm climate. The few bucks and a little time to put that sending unit in could really be a savings later. 1 Share this post Link to post Share on other sites
19richie66 17,892 #348 Posted May 14, 2018 I promise Ill put one in but it may not happen till after the show. If I can get the cooling fan mounted at least it will be a plus till then. It’s raining all week so it gives me plenty of time to figure something out. 1 Share this post Link to post Share on other sites
bmsgaffer 2,071 #349 Posted May 14, 2018 1 hour ago, 19richie66 said: Thanks Brandon. I have a 10” electric fan I thought about mounting in the fender panel blowing on the hydrostat fins. Not sure where I could mount a cooler without having to replumb it. May have room under the seat if I went with something like a small tranny cooler and computer sized fan. Thats the return side and I would possibly only need one more hose. Ill see how it goes. Also there was a sender in the bottom of the transaxle for a light I guess. Thought about putting in a trans heat guage using that hole. I too have been considering putting a sensor to more accurately see the hydro temps, and while the XI technically has an oil temp gauge for the engine, its just "yellow-greeeeeeeeeen-yellow". I would really like some numbers to go with that. I am thinking about using electronic versions of these sensors (and other) and putting them all into a 'universal electronic gauge' so you can monitor them without adding a bunch of different gauges. Who knows, ive been talking about this for years though... 2 Share this post Link to post Share on other sites
bmsgaffer 2,071 #350 Posted May 14, 2018 I cant remember if I saw it earlier in the thread, did you put the plastic fan back on the eaton pulley? Without that belt driven fan I am not sure the Eaton would last very long, especially driving those huge tires! Did you swap out the gear-sets in the transmission for the larger tires or are you going for the higher top speed? Also something I cant remember if its in the thread or not. I would love to see this thing in person. Someday maybe I will make it up to the big show when the kids are a bit older. 1 Share this post Link to post Share on other sites
