FELOPZD
520H or 520Xi? HELP!!!
WNYPCRepair
57 minutes ago, FELOPZD said:
Haha...thanks! I do know that it's a smokin' deal.  I'm constantly looking for those
I wasn't really looking to replace my gt225, but was just doing my typical craigslist daily check-in.  I look for a bunch o' stuff as I'm sure many of you do, and with an open mind, I follow what looks like a winner.
Truth is, time and space are my issues. I can't even park my car in the garage right now due to a remodel, and I'm not a "leave it outside" kind of guy.  I really wanted the 520xi, but I can't verify the hours.  My GT225 has under 500 hrs, and has most of what the Xi has: hydro pedals, cruise, tight circle, electric pto, and safety features since in have young children.  Plus I already have a 42" blower for it that works great.
Sometimes we have to leave the best deals for someone else. I could easily justify, buy, store, sell what I don't need and basically have a free tractor, true.  But sense and situation has won over my conscience!
Have at it with no ill feelings!!
Like I said, he won't be back for a week, so that gives you all time to plan ;)
Did you look at the parts 520lxi? I am mostly interested in body parts, as my New Holland is rusting away from the PO leaving it outside.
FELOPZD
The parts lxi is running, has 1300hrs, and he plans on putting it back into service.  It had rusted floors, but he's replaced them. It had a rusted deck, but he's putting the 48 on it from the 520xi. I saw/heard it run and it runs smooth and quiet.
FELOPZD
So, he called me and asked if I was still interested.  I asked if any of you had contacted him, which he said not.  I went back to look closely and drive it (520xi).  It started, ran, engaged, cut, performed flawlessly and tight.  It is clear to me that it is not a 3000 hr machine.  It's in better shape than my gt225 and 42c with 475hrs.
Also learned it has power steering!  It whined a little on turns, but that's it.
When money talks started, I decided
I wanted his 520xi, 60" 78395 deck in like-new condition, and the single stage 42" blower 79365.  I offered $1300 for all and he took the offer!
I will be picking it up next week.  He decided to keep his father's 93 520h, but will be selling the lxi and z master shortly, within the next month or so.
Good price for what I got, assuming it's under 1000 hrs?
Also, side note:
Has anyone used the tiller for the xi? I found a new one still available and am considering it.  It would be more than the tractor though!
Forest Road
Sounds like a good deal! My power steering makes some noise. It's stored in a shed. When below freezing the power steering freezes up. Have to let it run 20 min or more before it'll defrost. Once defrosted its never given me any problems.
if you have a large plot to till it may be worth it. Personally I find it such a PIA to swap certain implements I'd probably put the cash toward a classic w a tiller.
WVHillbilly520H
Honesty only the 522xi, 520lxi and 523Dxi came factory stock with power steering, the 518 and 520xi manual steering only the whining you hear was possibly the "smart turn" feature while turning and yep if it's under 1000 hours with the big deck and thrower not a bad deal, look behind the dash for a power steering unit like I have pictured below then you'll know for sure, Jeff.
  • Similar Content
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • davidtmercer
      By davidtmercer
      Very good condition.
      Gauge wheels will need replaced but are currently functional
      No mule drive or PTO belt included
      Firm on price due to availability and condition
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
